msr5660路由器配置l2tp无法建立会话
2018-11-22提问
  • 1收藏,1865浏览
disp l2tp tunnel可以看到所有隧道都是established状态
LocalTID RemoteTID State Sessions RemoteAddress RemotePort RemoteName
3632 864 Established 0 192.168.0.7 1701 ***.***
disp l2tp sessions可以看到会话established后立刻就消失。
设备回显信息显示VA不停的up/down
%Nov 22 03:48:47:056 2018 DC_UNI_3G_R5660_01 IFNET/3/PHY_UPDOWN: Physical state on the interface Virtual-Access0 changed to up.
%Nov 22 03:48:47:069 2018 DC_UNI_3G_R5660_01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Virtual-Access0 changed to up.
%Nov 22 03:48:47:258 2018 DC_UNI_3G_R5660_01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Virtual-Access0 changed to down.
%Nov 22 03:48:47:359 2018 DC_UNI_3G_R5660_01 IFNET/3/PHY_UPDOWN: Physical state on the interface Virtual-Access0 changed to down.
%Nov 22 03:48:47:796 2018 DC_UNI_3G_R5660_01 IFNET/3/PHY_UPDOWN: Physical state on the interface Virtual-Access0 changed to up.
radius服务器收不到任何认证消息。
路由器为l2tp接入,由另一台路由器做ipsec加密,用户认证方式为radius。
本次将原思科路由器更换为h3c路由器,思科路由器业务正常,正常情况下有十个l2tp隧道,300多个l2tp会话。根据思科路由器的配置进行的翻译。
运营商一根专线接入。
估计配置有啥问题,配置贴一下,然后在设备上开下边几个deb看看:
deb l2tp all
deb ppp all
deb radius packet
t d
t m
看看报文交互过程有没有什么异常
debug信息没有抓全,窗口时间太短,他上线终端太多。 只有少部分l2tp的。参考意义不大。 只有个Dropped an L2TP data packet 的报错。 *Nov 22 01:55:17:091 2018 DC_UNI_3G_R5660_01 L2TPV2/7/KDATA-PKT: -Slot=3; Successfully parsed the L2TP header (L2TP header length=6):TunnelID:50583,SessionID:54625,Type:0,Length:0,Sequence:0,Offset: 0,Priority:0 *Nov 22 01:55:17:091 2018 DC_UNI_3G_R5660_01 L2TPV2/7/KERROR: -Slot=3; Dropped an L2TP data packet. *Nov 22 01:55:17:097 2018 DC_UNI_3G_R5660_01 L2TPV2/7/KDATA-PKT: -Slot=3; Received an L2TP data packet: Source IP: 192.168.2.102 Destination IP: 10.2.39.50 Source port: 1701 Destination port: 1701 *Nov 22 01:55:17:097 2018 DC_UNI_3G_R5660_01 L2TPV2/7/KDATA-PKT: -Slot=3; Successfully parsed the L2TP header (L2TP header length=6):TunnelID:6570,SessionID:54487,Type:0,Length:0,Sequence:0,Offset: 0,Priority:0 *Nov 22 01:55:17:097 2018 DC_UNI_3G_R5660_01 L2TPV2/7/KERROR: -Slot=3; Dropped an L2TP data packet. *Nov 22 01:55:17:136 2018 DC_UNI_3G_R5660_01 L2TPV2/7/KDATA-PKT: -Slot=3; Received an L2TP data packet: Source IP: 192.168.2.103 Destination IP: 10.2.39.50 Source port: 1701 Destination port: 1701 *Nov 22 01:55:17:136 2018 DC_UNI_3G_R5660_01 L2TPV2/7/KDATA-PKT: -Slot=3; Successfully parsed the L2TP header (L2TP header length=6):TunnelID:29061,SessionID:54627,Type:0,Length:0,Sequence:0,Offset: 0,Priority:0
李小白 发表时间:2018-11-22
回复李小白:
这个是不是只deb了l2tp packet啊,看不出来原因呀
风干工程师肉干要不要 发表时间:2018-11-22
