s5500交换机
2018-11-26提问
  • 1收藏,937浏览
粉丝:0人 关注:4人
上端s5500三层交换机1台,下端s5100二层交换机3台,二层交换机用光模块分别接入在三层交换机光模块上?
1,如何配置光模块接口强制使用1000m速率,强制使用全双工模式。
2,如何配置接口支适应全双工半双工模式。
最好给个详细的配置命令?
本人小白,谢谢大神了。
粉丝:5人 关注:0人
1,进入到对应的接口下然后输入:speed 1000 即可。
2,进入到对应的接口下然后输入:duplex  auto 即可。
可以参考如下:
http://www.h3c.com/cn/d_201805/1081062_30005_0.htm
望采纳!
寂东 九段
粉丝:225人 关注:3人
设置接口强制千兆速率和全双工命令,在端口模式下  speed 1000;duplex full
有时协商可能有点问题,可以手工指定下千兆速率speed 1000,但是千兆光口只能工作在千兆全双工模式下,默认工作模式也是千兆全双工,
哦,那如何查看当前端口是否使用了全双工模式,是否走千兆速率?查看的命令是什么?
zhiliao_hBJab 发表时间:2018-11-26
回复zhiliao_hBJab:
dis interface g1/0/x(此处跟实际端口号)
寂东 发表时间:2018-11-26
GigabitEthernet1/0/25 current state: DOWN IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 0cda-41d2-2e7f Description: GigabitEthernet1/0/25 Interface Loopback is not set Media type is optical fiber,Port hardware type is No connector Unknown-speed mode, unknown-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled The Maximum Frame Length is 9216 Broadcast MAX-ratio: 100% Unicast MAX-ratio: 100% Multicast MAX-ratio: 100% Allow jumbo frame to pass PVID: 1 Mdi type: auto Link delay is 0(sec) Port link-type: trunk VLAN passing : 1(default vlan), 100 VLAN permitted: 1(default vlan), 100 Trunk port encapsulation: IEEE 802.1q Port priority: 0 Peak value of input: 0 bytes/sec, at 2000-04-29 05:58:32 Peak value of output: 0 bytes/sec, at 2000-04-29 05:58:32 Last 300 seconds input: 0 packets/sec 0 bytes/sec -% Last 300 seconds output: 0 packets/sec 0 bytes/sec -% Input (total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts Input (normal): 0 packets, - bytes 0 unicasts, 0 broadcasts, 0 multicasts Input: 0 input errors, 0 runts, 0 giants, 0 throttles 0 CRC, 0 frame, - overruns, 0 aborts - ignored, - parity errors Output (total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Output (normal): 0 packets, - bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Output: 0 output errors, - underruns, - buffer failures 0 aborts, 0 deferred, 0 collisions, 0 late collisions 0 lost carrier, - no carrier [H3C-GigabitEthernet1/0/25] 端口信息显示是全双工,速率走的千兆么
zhiliao_hBJab 发表时间:2018-11-27
回复zhiliao_hBJab:
你现在的问题是什么问题?你的这个口还是down状态,这是个光电复用口,得进入它对应的电口,shutdown,然后再进入25口,undo shutdown 才可以
寂东 发表时间:2018-11-27
