S5500交换机
2018-11-27提问
  • 1收藏,1093浏览
粉丝:0人 关注:4人
GigabitEthernet1/0/25 current state: DOWN IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 0cda-41d2-2e7f Description: GigabitEthernet1/0/25 Interface Loopback is not set Media type is optical fiber,Port hardware type is No connector Unknown-speed mode, unknown-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled The Maximum Frame Length is 9216 Broadcast MAX-ratio: 100% Unicast MAX-ratio: 100% Multicast MAX-ratio: 100% Allow jumbo frame to pass PVID: 1 Mdi type: auto Link delay is 0(sec) Port link-type: trunk VLAN passing : 1(default vlan), 100 VLAN permitted: 1(default vlan), 100 Trunk port encapsulation: IEEE 802.1q Port priority: 0 Peak value of input: 0 bytes/sec, at 2000-04-29 05:58:32 Peak value of output: 0 bytes/sec, at 2000-04-29 05:58:32 Last 300 seconds input: 0 packets/sec 0 bytes/sec -% Last 300 seconds output: 0 packets/sec 0 bytes/sec -% Input (total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts Input (normal): 0 packets, - bytes 0 unicasts, 0 broadcasts, 0 multicasts Input: 0 input errors, 0 runts, 0 giants, 0 throttles 0 CRC, 0 frame, - overruns, 0 aborts - ignored, - parity errors Output (total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Output (normal): 0 packets, - bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Output: 0 output errors, - underruns, - buffer failures 0 aborts, 0 deferred, 0 collisions, 0 late collisions 0 lost carrier, - no carrier [H3C-GigabitEthernet1/0/25]
此端口信息现在是走的全双工,速率跑千兆么?
zhiliao_i8SDm 知了小白
千兆以太网1 / 0 / 25当前状态: DOWN IP数据包帧类型: PKTFMT _ ETHNT _ 2,硬件地址: 0cda - 41 D2 - 2e7f描述:千兆以太网1 / 0 / 25接口环回未设置媒体类型为光纤,端口硬件类型为无连接器未知速度模式,未知双工模式链路速度类型为自动协商,链路双工类型为自动协商流量控制未启用最大帧长度为9216广播最大比率: 100 %单播最大比率
Port hardware type is No connector Unknown-speed mode, unknown-duplex mode 目前端口没有连接线缆为down状态,双工模式和速率均显示的是未知模式。
寂东 九段
粉丝:225人 关注:3人
在确保光线路通的情况下,得进入这个口对应的电口,shutdown,然后再进入25口,undo shutdown 才可以  ,这是个光电复用口
