WX3024 Mac地址认证不成功
2017-10-21提问
  • 1收藏,1724浏览
任务要求:配置AC和建立RAIDUS服务器(Win2008_r2),手持终端(PDA和手机)需要通过MAC地址认证放行
问题:MAC地址只处于连接状态,不能成功验证通过
1508560564(1)1508560757(1)
以下是命令行:
 sysname H3C
 domain default enable system
 telnet server enable
 port-security enable
 oap management-ip 192.168.6.250 slot 0
 wlan auto-ap enable
 password-recovery enable
 wlan capture file-name SnifferRecord
接口配置(略)
radius scheme mac
 primary authentication 192.168.6.253
 primary accounting 192.168.6.253
 key authentication cipher $c$3$xwQerkLRnNejWOuUGcohWGb6T3AKAHYWFQ==
 key accounting cipher $c$3$a+bOgUuQpN4m8HdNToOTCpAuXumaL6BLNw==
 user-name-format without-domain
domain mac
 authentication default radius-scheme mac
 authorization default radius-scheme mac
 accounting default radius-scheme mac
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
domain system
 state active
 idle-cut disable
dhcp server ip-pool 0
 network 192.168.6.0 mask 255.255.255.0
 gateway-list 192.168.6.251
wlan service-template 4 crypto
 ssid zhw65
 beacon ssid-hide
 bind WLAN-ESS 3
 cipher-suite ccmp
 security-ie rsn
 service-template enabl
 port link-type trunk
 port trunk permit vlan all
 mac-authentication domain mac
interface WLAN-ESS3
 port access vlan 22
 port-security port-mode mac-and-psk
 port-security tx-key-type 11key
 port-security preshared-key pass-phrase cipher $c$3$ay9FOLDMM2sdMEPrGtHXZJTdKKWI0ptqsubBQAxT
wlan ap ap-40 model WA2620i-AGN id 40
 serial-id 219801A0CNC15C001803
 radio 1
 radio 2
  service-template 1
  service-template 4
  service-template 5
  radio enable
xiaoyu 九段
粉丝:69人 关注:0人
全局把mac-authentication功能打开,另外你那个物理接口上的mac认证删除一下,如果还是不行,可以先尝试本地mac地址认证看看。
