WA4330-ACN 文件已经删除,新的版本导入显示空间不足
2017-10-23提问
  • 1收藏,2248浏览
我把现象给复制出来了,麻烦各位给看下
Display all file(s) in flash:
 'M' = MAIN      'B' = BACKUP      'S' = SECURE      'N/A' = NOT ASSIGNED
|NO. Size(B)   Time                 Type   Name                            |
里面什么也没有,导入版本文件后
Enter your choice(0-3): 2
Loading.....................................................................
..........Done!
11062272 bytes downloaded!
Updating File flash:/wa4300_fat.bin
The space is not enough
Failed!
再看文件还是空的
粉丝:12人 关注:7人
目前还是瘦版本,重新上传胖版本吧。
我上传的就是胖版本,我需要给转成瘦的
乔老师 发表时间:2017-10-23
回复乔老师:
目前启动信息还是瘦版本的,建议上传操作记录。。。另外版本是不是下载错了?
战五渣 发表时间:2017-10-23
fywr 九段
粉丝:49人 关注:3人
可以尝试格式化一下
怎么格式化?
乔老师 发表时间:2017-10-23
===============================<File CONTROL>=============================== |Note:the operating device is flash | |<1> Display All File(s) | |<2> Set Application File type | |<3> Delete File | |<0> Exit To Main Menu | ============================================================================ Enter your choice(0-3): 3 Deleting the file in flash: 'M' = MAIN 'B' = BACKUP 'S' = SECURE 'N/A' = NOT ASSIGNED ============================================================================ |NO. Size(B) Time Type Name | |No file in the current device! | ============================================================================
乔老师 发表时间:2017-10-23
选择删除的话,也是看不到文件的
乔老师 发表时间:2017-10-23
余sir 八段
粉丝:25人 关注:0人
选1试试,格式化一下
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
Starting to get the main application file--flash:/wa4300_fit.bin!
The main application file does not exist--flash:/wa4300_fit.bin!
Starting to get the backup application file--flash:/backup.bin!
The backup application file does not exist--flash:/backup.bin!
Starting to get the secure application file--flash:/secure.bin!
The secure application file does not exist--flash:/secure.bin!
Booting App fails!
Trying to get the IP address from the DHCP server......
已经格式化成功了,胖转瘦就出现这个
