S3100-52TP-SI
2018-12-07提问
  • 1收藏,1303浏览
lxys 一段
S3100-52TP-SI固件怎么升级?
寂东 九段
粉丝:225人 关注:3人
准备个tftp软件,然后从官网下载设备固件,升级案例:
升级说明文档和软件下载地址:http://www.h3c.com/cn/Service/Document_Software/Software_Download/Switches/Catalog/H3C_S3100/H3C_S3100/
账号:yx800  密码:01230123
升级过程:
重启ap,当出现“Press Ctrl+B to enter extend boot menu...”时,键入<Ctrl+B>,系统提示:
BootWare password: Not required. Please press Enter to continue.
按下<Enter>键后,系统进入BootWare主菜单:
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+C: Display Copyright
Ctrl+F: Format File System
Enter your choice(0-9):
(2)      以太网子菜单
BootWare主菜单下键入<3>,进入以太网子菜单,系统显示如下:
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash                                        |
|<1> Download Application Program To SDRAM And Run                         |
|<2> Update Main Application File                                          |
|<3> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>
此界面再次选择     <3> Modify Ethernet Parameter
配置以太网口参数
在通过以太网口升级应用程序前,需要对AP的以太网口进行配置,请按如下进行配置:
BootWare主菜单中键入<3>,进入以太网子菜单,然后键入<5>进入以太网口配置菜单:
============================<ETHERNET PARAMETER SET>======================
|Note:       '.' = Clear field.                                          |
|            '-' = Go to previous field.                                 |
|          Ctrl+D = Quit.                                                |
Protocol (FTP or TFTP) :tftp
Load File Name         :S31SI_E-CMW310-R2215P16.bin
Target File Name       :S31SI_E-CMW310-R2215P16.bin
Server IP Address      :192.168.0.1
Local IP Address       :192.168.0.50      (将连接的电脑地址设置成192.168.0.50,并启动tftp软件,将下载的版本文件该名成S31SI_E-CMW310-R2215P16.bin,并放在tftp的根目录下)
Gateway IP Address     :
FTP User Name          :
FTP User Password      :
以上配置均完成后,在BootWare主菜单下键入<2> Update Main Application File  ,系统开始升级主应用程序:
升级完成后键入<0>,返回BootWare主菜单,然后键入<1>,启动系统
粉丝:10人 关注:1人
固件升级是什么意思,就是升级版本吗?
详情见版本说明书
http://www.h3c.com/cn/d_201312/810643_30005_40.htm#_Toc374697192
B.1 通过命令行远程升级
下面例子中的应用程序的名字不是实际的应用程序,只是用来说明升级的过程。
用户在本地计算机上运行FTP Server,注意配置了用户名和密码,以及正确的文件所在目录(假设IP地址为10.10.110.1)。同时用户通过Telnet远程登录到交换机上,利用FTP将主机程序传送到交换机上。
假设主机程序为SWITCH.binBOOTROM程序为SWITCH.btm。在用户通过Telnet远程登录到交换机上后,进行下列操作。
第一步:通过FTP将软件下载到交换机上。
<H3C> ftp 10.10.110.1
Trying ...
Press CTRL+K to abort
Connected.
User(none):lyt
Password:
230 Logged in successfully
[ftp] get SWITCH.bin SWITCH.bin
[ftp] get SWITCH.btm SWITCH.btm
[ftp] bye
第二步,加载BOOTROM
<H3C> boot bootrom SWITCH.btm
please wait ...
Bootrom is updated!
第三步,加载主机软件。
<H3C> boot boot-loader SWITCH.bin
<H3C> display boot-loader
The app to boot at the next time is: flash:/SWITCH.bin
<H3C> reboot(重启前请确认其他配置是否保存,防止重启后造成配置丢失)
通过以上操作即可完成BOOTROM和主机软件的加载。需要注意的是,加载主机软件必须通过reboot命令重起交换机才能使加载成功。如果Flash memory空间不够,可以首先完成BOOTROM的加载,然后删除flash中的部分程序文件(建议删除已不使用的某主机程序),再将加载用的主机程序通过FTP上载到交换机来完成主机程序的加载。注意,在加载过程中不可断电。
如果Flash memory空间不够,可以首先完成BOOTROM的升级,然后再将主机程序通过FTP上载到交换机上完成主机程序的升级。
