MSR20-20 端口映射
2018-12-14提问
  • 1收藏,1034浏览
粉丝:0人 关注:2人
端口映射完,外网访问网站总是登录到路由器WEB管理界面
 # version 5.20, Release 2513P02, Standard # sysname msr20-20 # super password level 3 cipher $c$3$ecbDExt4twOIFnKvblt/ZPBYeVN3cB6CKA== # l2tp enable # domain default enable system # telnet server enable # dar p2p signature-file cfa0:/p2p_default.mtd # port-security enable # web idle-timeout 60 # password-recovery enable # acl number 3000 rule 10 permit ip source 20.13.2.0 0.0.0.255 destination 10.10.10.0 0.0.0.255 acl number 3001 rule 10 deny ip source 20.13.2.0 0.0.0.255 destination 10.10.10.0 0.0.0.255 rule 11 permit ip source 20.13.2.30 0 rule 12 permit ip source 20.13.2.31 0 rule 13 permit ip source 20.13.2.32 0 rule 14 permit ip source 20.13.2.33 0 rule 15 permit ip source 20.13.2.34 0 rule 16 permit ip source 20.13.2.35 0 rule 17 permit ip source 20.13.2.36 0 rule 18 permit ip source 20.13.2.37 0 rule 19 permit ip source 20.13.2.38 0 rule 20 permit ip source 20.13.2.39 0 rule 21 permit ip source 20.13.2.40 0 rule 22 permit ip source 20.13.2.253 0 rule 23 permit ip source 20.13.2.254 0 rule 25 permit ip source 20.13.2.21 0 # vlan 1 # domain system access-limit disable state active idle-cut disable self-service-url disable ip pool 1 192.168.8.2 192.168.8.100 # ike proposal 10 authentication-algorithm md5 # ike peer tobj pre-shared-key cipher $c$3$GMJIF9YRTcFmW+SZLpj5p1cqs6nDlyA33hS71A== remote-address 219.141.207.185 local-address 222.223.168.74 # ipsec transform-set tobj encapsulation-mode tunnel transform esp esp authentication-algorithm md5 esp encryption-algorithm des # ipsec policy tobj 10 isakmp security acl 3000 pfs dh-group1 ike-peer tobj transform-set tobj # user-group system group-attribute allow-guest # local-user admin local-user anhe password cipher $c$3$TJho90UHViGh9PMESDjkHH5DsBAGIUri9Q== authorization-attribute level 3 service-type telnet service-type web local-user ciming password cipher $c$3$N6dgDBhURxLH9IctcKJXMhRco5XnW6HrVc4qdw== authorization-attribute level 3 service-type ssh telnet local-user cmjm password cipher $c$3$7kCY7x89riJiOpOPsHtmMYv36OUG+dZ8cGYoqlWt+Q== authorization-attribute level 3 service-type ssh local-user cmjmzjk password cipher $c$3$na1jpBMTPies1gLNxi4Mim5nqsvNn6hWsVEx service-type ppp # cwmp undo cwmp enable # l2tp-group 1 undo tunnel authentication allow l2tp virtual-template 10 remote cmjm # interface Aux0 async mode flow link-protocol ppp # interface Cellular0/0 async mode protocol link-protocol ppp # interface Ethernet0/0 port link-mode route description connect_to_neiwang ip address 20.13.2.1 255.255.255.0 # interface Ethernet0/1 port link-mode route description connect_to_waiwang nat outbound 3001 nat server 1 protocol tcp global current-interface www inside 20.13.2.231 www ip address 222.223.168.74 255.255.255.224 ipsec policy tobj # interface Virtual-Template10 ppp authentication-mode chap remote address pool 1 ip address 192.168.8.1 255.255.255.0 # interface NULL0 # interface Vlan-interface1 # ip route-static 0.0.0.0 0.0.0.0 222.223.168.65 # snmp-agent snmp-agent local-engineid 800063A2035CDD70C333CC snmp-agent community read cmzy snmp-agent sys-info version all undo snmp-agent trap enable voice dial # ssh server enable ssh user admin service-type stelnet authentication-type password # load xml-configuration # load tr069-configuration # user-interface con 0 user-interface tty 13 user-interface aux 0 user-interface vty 0 4 authentication-mode scheme # return
zhiliao_mKKjb 知了小白
在对应的网口下配置
nat server 1 protocol tcp global current-interface 端口 inside 内网IP 端口
如果必须用80端口就把路由web界面关闭就可以了。
你好,怎样关闭路由web界面
zhiliao_66967 发表时间:2018-12-14
粉丝:24人 关注:13人
更换浏览器及PC测试,清理一下浏览器缓存。
更换后,还是这样
寂东 九段
粉丝:225人 关注:3人
这是因为路由器的web登录也用的80端口,所有,收到对80端口的请求,路由器就响应了,把路由器的web登录端口改掉,该成别的端口,系统视图下:
ip http port 8081
您好,更改后,还是无法访问
回复zhiliao_66967:
通过80端口能访问到路由器的登录界面,说明ip地址、端口都是能访问的,运营商那边应该是没问题的,问题可能还是在设置上,或者说内网里,路由器下有没有防火墙,
寂东 发表时间:2018-12-14
有,是透明模式,已放通20.13.2.231 80端口
回复zhiliao_66967:
测了一下,222.223.168.74 的80端口是通的,还是连到了路由器上,把路由器的web登录端口改掉,再去掉所有的过滤再测试看看
寂东 发表时间:2018-12-14
您好,ip http port 8081.防火墙已取消过滤,还是打不开, 局域网计算机 20.13.2.231可以访问网站,但***.***打不开
