MSG 360 -10升级过程断电导致flansh损坏了
2018-12-15提问
  • 1收藏,1267浏览
BootWare Validating... Press Ctrl+B to access EXTENDED-BOOTWARE MENU... Password recovery capability is enabled. Note: The current operating device is flash Enter < Storage Device Operation > to select device. ==========================<EXTENDED-BOOTWARE MENU>========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Skip Authentication for Console Login | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+Z: Access EXTENDED ASSISTANT MENU Ctrl+F: Format File System Ctrl+C: Display Copyright Enter your choice(0-9):
无法网线登陆WEBL界面还原配置,从CON口进入提示这些要怎么操作,有无详细指导书来操作恢复。
粉丝:57人 关注:0人
这个需要在命令行升级下版本了,具体可以参考v7路由器升级案例
轻轻松松配路由:https://zhiliao.h3c.com/topic/huati/1247
寂东 九段
粉丝:225人 关注:3人
找款tftp软件,用软件来上传版本,
1,重启设备,当出现Press Ctrl+B to access EXTENDED-BOOTWARE MENU...”时,键入<Ctrl+B>,系统进入BootWare主菜单:
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot
选择3,|<3> Enter Ethernet SubMenu
2. 进入以太网口子菜单
BootWare主菜单下键入<3>,可以进入以太网口子菜单,系统显示如下:
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash                                        |
|<1> Download Image Program To SDRAM And Run                               |
|<2> Update Main Image File                                                |
|<3> Update Backup Image File                                              |
|<4> Download Files(*.*)                                                   |
|<5> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
Enter your choice(0-5):
3. 修改以太网口参数
在以太网口子菜单下键入<5>,可以修改以太口参数,系统显示如下:
==========================<ETHERNET PARAMETER SET>==========================
|Note:       '.' = Clear field.                                            |
|            '-' = Go to previous field.                                   |
|         Ctrl+D = Quit.                                                   |
Protocol (FTP or TFTP) :tftp
Load File Name           :xxx.ipe
Target File Name         :xxx.ipe
Server IP Address        :192.168.100.12
Local IP Address         :192.168.100.142
Subnet Mask              :0.0.0.0
Gateway IP Address       :0.0.0.0
4. 进行版本下载
以升级主启动文件为例,键入<2>升级主启动文件:
Loading.....................................................................
下载完后,返回主界面,重启设备
