MSR-930 不小心把系统给格式化了,用什么办法刷和接什么头
2018-12-23提问
  • 1收藏,1337浏览
各位大师,一部小心在串口下吧系统给格式了,现在要什么办法恢复系统有BIN文件尝试几次都不成功,说下步奏谢谢
粉丝:9人 关注:4人
轻轻松松配路由:https://zhiliao.h3c.com/topic/huati/1247 中有升级的操作
寂东 九段
粉丝:225人 关注:3人
版本文件丢了,重新上传一个就可以了,但格式化后配置文件也没了,上传过版本文件后,是被是空配置,需要重新配置,找一个tftp软件上传版本,软件下载地址:
http://www.h3c.com/cn/Service/Document_Software/Software_Download/Router/Catalog/MSR_G2/MSR_93X/
用户名:yx800   密码:01230123
升级案例:
重启设备,当出现“Press Ctrl+B to enter extend boot menu...”时,键入<Ctrl+B>,系统提示:
BootWare password: Not required. Please press Enter to continue.
按下<Enter>键后,系统进入BootWare主菜单:
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+C: Display Copyright
Ctrl+F: Format File System
Enter your choice(0-9):
(2)      以太网子菜单
BootWare主菜单下键入<3>,进入以太网子菜单,系统显示如下:
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash                                        |
|<1> Download Application Program To SDRAM And Run                         |
|<2> Update Main Application File                                          |
|<3> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>
此界面再次选择     <3> Modify Ethernet Parameter
配置以太网口参数
在通过以太网口升级应用程序前,需要对AP的以太网口进行配置,请按如下进行配置:
BootWare主菜单中键入<3>,进入以太网子菜单,然后键入<5>进入以太网口配置菜单:
============================<ETHERNET PARAMETER SET>======================
|Note:       '.' = Clear field.                                          |
|            '-' = Go to previous field.                                 |
|          Ctrl+D = Quit.                                                |
Protocol (FTP or TFTP) :tftp
Load File Name         :xxxxx.bin    (软件名称)
Target File Name       :xxxxx.bin
Server IP Address      :192.168.0.1
Local IP Address       :192.168.0.50      (将连接的电脑地址设置成192.168.0.50,并启动tftp软件,将下载的版本文件 xxxxx.bin  放在tftp的根目录下)
Gateway IP Address     :
FTP User Name          :
FTP User Password      :
以上配置均完成后,在BootWare主菜单下键入<2> Update Main Application File  ,系统开始升级主应用程序:
升级完成后键入<0>,返回BootWare主菜单,然后键入<1>,启动系统
