我们有两台交换机做了堆叠:H3C S5800-32C
其中1/0/18和2/0/18这两个口做了Bridge-Aggregation
Bridge-Aggregation7配置如下:
GE1/0/18和2/0/18的流入流量是均衡的,但是流出流量几乎只从GE1/0/18上流出,而GE2/0/18的流量几乎不走
GE1/0/18的流量图如下:
GE2/0/18的流量图如下:
交换机的版本信息:
H3C Comware Platform Software
Comware Software, Version 5.20, Release 1211P09
Copyright (c) 2004-2012 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C S5800-32C uptime is 186 weeks, 4 days, 21 hours, 16 minutes
H3C S5800-32C with 2 Processors
1024M bytes SDRAM
4M bytes Nor Flash Memory
512M bytes Nand Flash Memory
Config Register points to Nand Flash
Hardware Version is Ver.B
CPLD Version is 003
BootRom Version is 215
[SubSlot 0] 24GE+4SFP Plus Hardware Version is Ver.B
[SubSlot 1] No Module
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
我这边端口下都配置了: link-aggregation mode dynamic link-aggregation load-sharing mode destination-ip source-ip 全局变量取消link-aggregation load-sharing mode local-first会有什么影响吗?
理论上没影响
