MSR930路由器配置只允许某网段IP可以SSH连接
2019-01-03提问
  • 1收藏,2037浏览
Crixus 零段
MSR930路由器,之前配置了只允许192.168.1.0的网段可以ssh连接,现在因其他关系需要取消这项配置,相关配置已经删除,可还是不能ssh连接,请大神帮忙看看哪里没有删干净。
 version 5.20, Release 2514P10
 sysname H3C
 super password level 3 cipher $c$3$Ci8D9wEmHG2EjKvxunMV6h21NC0CIBO9ot3LQ2o=
 domain default enable system
 dns proxy enable
 telnet server enable
 dar p2p signature-file flash:/p2p_default.mtd
 ndp enable
 ntdp enable
 cluster enable
 port-security enable
 password-recovery enable
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
dhcp server ip-pool 0
 static-bind ip-address 192.168.1.30 mask 255.255.255.0
dhcp server ip-pool vlan1 extended
 network ip range 192.168.20.30 192.168.20.200
 network mask 255.255.255.0
 gateway-list 192.168.20.1
 dns-list 192.168.20.1
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$CTOuI/Dy48o9V5RgBdshCAu9wevBYgx6FcLnacg=
 authorization-attribute level 3
 service-type telnet
 service-type web
cwmp
 undo cwmp enable
attack-defense policy 86 interface GigabitEthernet0/0
 signature-detect action drop-packet
 signature-detect fraggle enable
 signature-detect land enable
 signature-detect winnuke enable
 signature-detect tcp-flag enable
 signature-detect icmp-unreachable enable
 signature-detect icmp-redirect enable
 signature-detect tracert enable
 signature-detect smurf enable
 signature-detect source-route enable
 signature-detect route-record enable
 signature-detect large-icmp enable
 defense scan enable
  defense scan add-to-blacklist
 defense syn-flood enable
  defense syn-flood action drop-packet
 defense udp-flood enable
  defense udp-flood action drop-packet
 defense icmp-flood enable
  defense icmp-flood action drop-packet
interface Aux0
 async mode flow
 link-protocol ppp
interface Cellular0/0
 async mode protocol
 link-protocol ppp
 tcp mss 1024
interface Dialer10
 nat outbound
 nat server 1 protocol tcp global current-interface 10080 inside 192.168.20.224 www
 nat server 2 protocol tcp global current-interface 10023 inside 192.168.20.203 22
 nat server 4 protocol tcp global current-interface 18082 inside 192.168.20.224 8082
 nat server 5 protocol tcp global current-interface 18083 inside 192.168.20.224 8083
 nat server 3 protocol tcp global current-interface 18081 inside 192.168.20.224 8081
 nat server 6 protocol tcp global current-interface 10081 inside 192.168.20.224 81
 link-protocol ppp
 ppp chap user 17770327195
 ppp chap password cipher $c$3$/cUEkj6ClpHtVkro2Q1Xn5XxwQfQnDyXRMSD
 ppp pap local-user 17770327195 password cipher $c$3$WIpudgdUZLn5T+Y4tWaNEhTBPx6BqMwhX/kz
 ppp ipcp dns admit-any
 ppp ipcp dns request
 mtu 1492
 ip address ppp-negotiate
 tcp mss 1024
 dialer user username
 dialer-group 10
 dialer bundle 10
interface NULL0
interface Vlan-interface1
 ip address 192.168.20.1 255.255.255.0
 tcp mss 1024
 dhcp server apply ip-pool vlan1
 port link-mode route
 nat outbound
 pppoe-client dial-bundle-number 10
 attack-defense apply policy 86
interface GigabitEthernet0/1
 port link-mode bridge
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
 ip route-static 0.0.0.0 0.0.0.0 Dialer10
 ip route-static 192.168.1.0 255.255.255.0 192.168.25.2
 ip route-static 192.168.10.0 255.255.255.0 192.168.25.2
 dhcp enable
 ssh server enable
 dialer-rule 10 ip permit
 nms primary monitor-interface Dialer10
 load xml-configuration
 load tr069-configuration
user-interface tty 12
user-interface aux 0
user-interface vty 0 4
return
呵呵 九段
粉丝:27人 关注:0人
本地用户没有开SSH权限# local-user admin password cipher $c$3$CTOuI/Dy48o9V5RgBdshCAu9wevBYgx6FcLnacg= authorization-attribute level 3 service-type telnet service-type web #
local-user admin password cipher $c$3$CTOuI/Dy48o9V5RgBdshCAu9wevBYgx6FcLnacg= authorization-attribute level 3 service-type telnet service-type web 我在下面加一句 service-type ssh 就可以了吗?
Crixus 发表时间:2019-01-03
大佬,还是不行,最新配置看三楼
回复Crixus:
不行就开调试看看咯
呵呵 发表时间:2019-01-03
寂东 九段
粉丝:225人 关注:3人
user-interface vty 0 4 (这个接口下添加上认证)
 authentication-mode scheme
local-user admin
service-type ssh   (如果你以前用ssh登录,这项应该是已经有的,现在怎么没有了呢,没有就添加上吧,)
好的,我试试
还是不行,最新配置如下 # version 5.20, Release 2514P10 # sysname H3C # super password level 3 cipher $c$3$Ci8D9wEmHG2EjKvxunMV6h21NC0CIBO9ot3LQ2o= # domain default enable system # dns proxy enable # telnet server enable # ssh server enable # dar p2p signature-file flash:/p2p_default.mtd # ndp enable # ntdp enable # cluster enable # port-security enable # password-recovery enable # vlan 1 # domain system access-limit disable state active idle-cut disable self-service-url disable # dhcp server ip-pool vlan1 extended network ip range 192.168.20.30 192.168.20.200 network mask 255.255.255.0 gateway-list 192.168.20.1 dns-list 192.168.20.1 # user-group system group-attribute allow-guest # local-user admin password cipher $c$3$CTOuI/Dy48o9V5RgBdshCAu9wevBYgx6FcLnacg= authorization-attribute level 3 service-type telnet service-type web service-type ssh # cwmp undo cwmp enable # attack-defense policy 86 interface GigabitEthernet0/0 signature-detect action drop-packet signature-detect fraggle enable signature-detect land enable signature-detect winnuke enable signature-detect tcp-flag enable signature-detect icmp-unreachable enable signature-detect icmp-redirect enable signature-detect tracert enable signature-detect smurf enable signature-detect source-route enable signature-detect route-record enable signature-detect large-icmp enable defense scan enable defense scan add-to-blacklist defense syn-flood enable defense syn-flood action drop-packet defense udp-flood enable defense udp-flood action drop-packet defense icmp-flood enable defense icmp-flood action drop-packet # interface Aux0 async mode flow link-protocol ppp # interface Cellular0/0 async mode protocol link-protocol ppp tcp mss 1024 # interface Dialer10 nat outbound nat server 1 protocol tcp global current-interface 10080 inside 192.168.20.224 www nat server 2 protocol tcp global current-interface 10023 inside 192.168.20.203 22 nat server 4 protocol tcp global current-interface 18082 inside 192.168.20.224 8082 nat server 5 protocol tcp global current-interface 18083 inside 192.168.20.224 8083 nat server 3 protocol tcp global current-interface 18081 inside 192.168.20.224 8081 nat server 6 protocol tcp global current-interface 10081 inside 192.168.20.224 81 link-protocol ppp ppp chap user 17770327195 ppp chap password cipher $c$3$/cUEkj6ClpHtVkro2Q1Xn5XxwQfQnDyXRMSD ppp pap local-user 17770327195 password cipher $c$3$WIpudgdUZLn5T+Y4tWaNEhTBPx6BqMwhX/kz ppp ipcp dns admit-any ppp ipcp dns request mtu 1492 ip address ppp-negotiate tcp mss 1024 dialer user username dialer-group 10 dialer bundle 10 # interface NULL0 # interface Vlan-interface1 ip address 192.168.20.1 255.255.255.0 tcp mss 1024 dhcp server apply ip-pool vlan1 # interface GigabitEthernet0/0 port link-mode route nat outbound nat server 1 protocol tcp global current-interface 10080 inside 192.168.20.224 www nat server 2 protocol tcp global current-interface 10023 inside 192.168.20.203 22 nat server 4 protocol tcp global current-interface 18082 inside 192.168.20.224 8082 nat server 5 protocol tcp global current-interface 18083 inside 192.168.20.224 8083 nat server 3 protocol tcp global current-interface 18081 inside 192.168.20.224 8081 nat server 6 protocol tcp global current-interface 10081 inside 192.168.20.224 81 pppoe-client dial-bundle-number 10 attack-defense apply policy 86 # interface GigabitEthernet0/1 port link-mode bridge # interface GigabitEthernet0/2 port link-mode bridge # interface GigabitEthernet0/3 port link-mode bridge # interface GigabitEthernet0/4 port link-mode bridge # ip route-static 0.0.0.0 0.0.0.0 Dialer10 ip route-static 192.168.1.0 255.255.255.0 192.168.25.2 ip route-static 192.168.10.0 255.255.255.0 192.168.25.2 # dhcp enable # ssh server enable # dialer-rule 10 ip permit # nms primary monitor-interface Dialer10 # load xml-configuration # load tr069-configuration # user-interface tty 12 user-interface aux 0 user-interface vty 0 4 local-user admin service-type ssh authentication-mode scheme # return
回复Crixus:
系统视图下,加上这条命令:ssh user admin service-type stelnet authentication-type password,vty接口下,加上这条命令:user-interface vty 0 4, authentication-mode scheme
寂东 发表时间:2019-01-03
Crixus 知了小白
最新配置如下,还是不能ssh连接路由器
 sysname H3C
 dns proxy enable
 ssh server enable
 ndp enable
 ntdp enable
 cluster enable
vlan 1
domain system
 state active
 idle-cut disable
user-group system
local-user admin
 service-type telnet
 service-type web
 service-type ssh
cwmp
 undo cwmp enable
 defense scan enable
interface Aux0
 async mode flow
 link-protocol ppp
 async mode protocol
 link-protocol ppp
 tcp mss 1024
interface Dialer10
 nat outbound
 link-protocol ppp
 mtu 1492
 tcp mss 1024
 dialer-group 10
 dialer bundle 10
interface NULL0
 tcp mss 1024
 nat outbound
 dhcp enable
 ssh server enable
local-user admin
service-type ssh
return
