设备瘦AP wa4320改为胖模式,通过bootware版本模式导入版本,设备正常启动,输入dir查看版本时,报以下错误。
<WA4320-ACN>dir
% Unformatted device
设备重启后,出现错误,一直处在版本加载的现场,请问这是什么问题,谢谢!
Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extend BootWare The Extend BootWare is self-decompressing....................Done! **************************************************************************** * * * H3C WA4320-ACN BootWare, Version 1.15 * * * **************************************************************************** Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. Compiled Date : Mar 27 2017 CPU Type : ATHEROS AR9557 CPU L1 Cache : 32KB CPU Clock Speed : 720MHz Memory Type : SDRAM Memory Size : 256MB Memory Speed : 560MHz BootWare Size : 512KB Flash Size : 32MB PCB Version : Ver.B BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa4300_fat.bin! The main application file does not exist--flash:/wa4300_fat.bin! Starting to get the backup application file--flash:/backup.bin! The backup application file does not exist--flash:/backup.bin! Starting to get the secure application file--flash:/secure.bin! The secure application file does not exist--flash:/secure.bin! Booting App fails! Protocol (FTP or TFTP) : ftp Load File Name : wa4300_fat.bin Target File Name : wa4300_fat.bin Server IP Address : 192.168.1.1 Local IP Address : 192.168.1.50 Gateway IP Address : 0.0.0.0 FTP User Name : admin FTP User Password : password Loading...Failed! System is starting...
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
update试过,不行,一直加载不了
AP文件的名字必须为wa4300_fat.bin 才可以
