MSR2600与ER3200G2都是域名,在做主模式IPSEC的时候会因ip变动导致无法连接
2019-01-10提问
  • 1收藏,1539浏览
零段
MSR2600的配置代码中这一段#ike peer v5 proposal 1 pre-shared-key cipher $c$3$jNmFZRpJxkAMsrIVwMoYWJ8014PJfMpLhg== remote-address  ***.***  /  这个域名是对端ER3200G2的。 remote-address 113.116.57.250      /再次查看的时候就是显示ip地址#这个地址然后就固定了 。当对端ER3200G2的ip地址发送动态变化后,VPN就断开了。请问这种情况怎么处理
按道理配置的时候写的是固定域名了 msr2600应该一直连接才对。
是不是代码写的有问题?
请指教了 谢谢了
不应该呀,如果配置的是域名,配置上是不会自动改成ip地址的呀
知了小白
是不是配置有问题呢 以下是配置
MSR2600配置
 version 5.20, Release 2514P14
 sysname MSR2600
 domain default enable system
 dns resolve
 dns proxy enable
 telnet server enable
 port-security enable
 password-recovery enable
acl number 3002
 rule 0 permit ip source 192.168.2.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
acl number 3333
 rule 0 deny ip source 192.168.2.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
 rule 5 permit ip
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
ike proposal 1
 encryption-algorithm 3des-cbc
 dh group2
 authentication-algorithm md5
ike peer v5
 proposal 1
ipsec transform-set v5
 encapsulation-mode tunnel
 transform esp
 esp authentication-algorithm md5
 esp encryption-algorithm 3des
ipsec policy v5 1 isakmp
 security acl 3002
 ike-peer v5
 transform-set v5
dhcp server ip-pool vlan1 extended
 network ip range 192.168.2.16 192.168.2.254
 network mask 255.255.255.0
 gateway-list 192.168.2.1
 dns-list 114.114.114.114 202.96.128.86
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$0Yu/gQOnbonGYdaV9U6Btq0aes6GlTV+UXcL
 authorization-attribute level 3
 service-type telnet
 service-type web
cwmp
 undo cwmp enable
ddns policy ***.***
 url ***.***/dyndns/update?system=dyndns&hostname=<h>&myip=<a>
 username bestcare2017
 password cipher $c$3$qPLj7v6f9MYFOnk2pvmMwntaH8M3ga+1okSF
interface Aux0
 async mode flow
 link-protocol ppp
interface Cellular0/0
 async mode protocol
 link-protocol ppp
 ipsec no-nat-process enable
interface Dialer10
 nat outbound 3333
 link-protocol ppp
 ppp chap user 075500873715@163.gd
 ppp chap password cipher $c$3$Z2w3wlqpN5jG5P5FvJGT1buk6/qzu+amUZCA
 ppp pap local-user 075500873715@163.gd password cipher $c$3$/JF3XnTrRTwu8r9zAid
jml/3iKQaE8/eIP2X
 ppp ipcp dns admit-any
 ppp ipcp dns request
 mtu 1200
 ip address ppp-negotiate
 tcp mss 1024
 dialer user username
 dialer-group 10
 dialer bundle 10
 ipsec policy v5
 ddns apply policy ***.*** fqdn ***.***
interface NULL0
interface Vlan-interface1
 ip address 192.168.2.1 255.255.255.0
 dhcp server apply ip-pool vlan1
interface GigabitEthernet0/0
 port link-mode route
 ip address 192.168.3.2 255.255.255.0
interface GigabitEthernet0/1
 nat outbound 3333
 pppoe-client dial-bundle-number 10
interface GigabitEthernet0/2
 port link-mode bridge
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
 ip route-static 0.0.0.0 0.0.0.0 Dialer10
 dhcp enable
 dialer-rule 10 ip permit
 nms primary monitor-interface GigabitEthernet0/0
 load xml-configuration
 load tr069-configuration
user-interface tty 12
user-interface aux 0
user-interface vty 0 4
 authentication-mode scheme
return
[MSR2600]dis ike sa
    total phase-1 SAs:  0
    connection-id  peer                    flag        phase   doi
     1468          <unnamed>               NONE        1       IPSEC
  flag meaning
  RD--READY ST--STAYALIVE RL--REPLACED FD--FADING TO--TIMEOUT RK--REKEY
