华三AP上连接的电脑和打印机不互通
2019-01-11提问
  • 1收藏,1713浏览
同一个AP下无线连接的笔记本不能访问有线连接的打印机
fywr 九段
粉丝:49人 关注:3人
胖AP需要关闭默认的用户隔离功能
wlan-client-isolation enable
undo wlan-client-isolation enable
我使用的是瘦AP,在AP的有线接口下undo port-isolate enable后仍然不行
zhiliao_94056 发表时间:2019-01-11
瘦AP的话,你有线打印机是连接在交换机么?首先是不是一个网段,不是一个网段的话,看看三层转发是不是通的,一个网段的话就得看二层是否打通,看你这个描述是个面板AP?
fywr 发表时间:2019-01-11
是打印机是接在AP的有线端口上的,笔记本连接的这个AP的无线信号,两个设备的IP地址在同一个网段
你配置的是集中转发的话,无线侧的流量是会先到AC,然后再从有线到AP,这中间你看有没有阻断的地方,AC上面有没有配置二层隔离
回复fywr:
配置的是本地转发
看下服务模板下是否配置了隔离
回复fywr:
没有配置隔离
你贴下配置吧
Ap上的map文件也一并贴出来
AC配置:[22:38:25]<AC-WX3520H>display current-configuration [22:38:25]# [22:38:25] version 7.1.064, Release 5208P03 [22:38:25]# [22:38:25] sysname AC-WX3520H [22:38:25]# [22:38:25] telnet server enable [22:38:25]# [22:38:25] irf mac-address persistent timer [22:38:25] irf auto-update enable [22:38:25] irf auto-merge enable [22:38:25] irf member 1 priority 1 [22:38:25]# [22:38:25] password-recovery enable [22:38:25]# [22:38:25]vlan 1 [22:38:25]# [22:38:25]vlan 2 [22:38:25] description AP-MGT [22:38:25]# [22:38:25]vlan 3 [22:38:25] description Server [22:38:25]# [22:38:25]vlan 4 [22:38:25] description HuLian [22:38:25]# [22:38:25]vlan 10 [22:38:25] description SHENDI-LJ [22:38:25]# [22:38:25]vlan 30 [22:38:25] description YYGS-OFFICE [22:38:25]# [22:38:25]vlan 40 [22:38:25] description YYGS-WORK [22:38:25]# [22:38:25]vlan 999 [22:38:25] description MGT [22:38:25]# [22:38:25]irf-port 1 [22:38:25]# [22:38:25]wlan service-template 1 [22:38:25] ssid SHENDI-LJ [22:38:25] vlan 10 [22:38:25] client forwarding-location ap vlan 10 [22:38:25] service-template enable [22:38:25]# [22:38:25]wlan service-template 2 [22:38:25] ssid YYGS-OFFICE [22:38:25] vlan 30 [22:38:25] client forwarding-location ap vlan 30 [22:38:25] service-template enable [22:38:25]# [22:38:25]wlan service-template 3 [22:38:25] ssid YYGS-WORK [22:38:25] vlan 40 [22:38:25] beacon ssid-hide [22:38:25] client forwarding-location ap vlan 40 [22:38:25] client-security authentication-mode mac [22:38:25] mac-authentication domain local-mac [22:38:25] service-template enable [22:38:25]# [22:38:25]interface NULL0 [22:38:25]# [22:38:25]interface Vlan-interface1 [22:38:25]# [22:38:25]interface Vlan-interface2 [22:38:25] ip address 10.0.64.3 255.255.248.0 [22:38:25]# [22:38:25]interface Vlan-interface999 [22:38:25] ip address 10.0.14.2 255.255.254.0 [22:38:26]# [22:38:26]interface GigabitEthernet1/0/1 [22:38:26]# [22:38:26]interface GigabitEthernet1/0/2 [22:38:26] description Link-To-7503_G4/0/2 [22:38:26] port link-type trunk [22:38:26] port trunk permit vlan all [22:38:26]# [22:38:26]interface GigabitEthernet1/0/3 [22:38:26]# [22:38:26]interface GigabitEthernet1/0/4 [22:38:26]# [22:38:26]interface GigabitEthernet1/0/5 [22:38:26]# [22:38:26]interface GigabitEthernet1/0/6 [22:38:26]# [22:38:26]interface GigabitEthernet1/0/7 [22:38:26]# [22:38:26]interface GigabitEthernet1/0/8 [22:38:26] port access vlan 999 [22:38:26]# [22:38:26]interface Ten-GigabitEthernet1/0/9 [22:38:26]# [22:38:26]interface Ten-GigabitEthernet1/0/10 [22:38:26]# [22:38:26] scheduler logfile size 16 [22:38:26]# [22:38:26]line class console [22:38:26] user-role network-admin [22:38:26]# [22:38:26]line class vty [22:38:26] user-role network-operator [22:38:26]# [22:38:26]line con 0 [22:38:26] user-role network-admin [22:38:26]# [22:38:26]line vty 0 31 [22:38:26] authentication-mode scheme [22:38:26] user-role network-operator [22:38:26]# [22:38:26] ip route-static 0.0.0.0 0 10.0.14.1 [22:38:26]# [22:38:26] undo info-center enable [22:38:26] undo info-center logfile enable [22:38:26]# [22:38:26] snmp-agent [22:38:26] snmp-agent local-engineid 800063A28038AD8EABCE6000000001 [22:38:26] snmp-agent community read Di$hiNi [22:38:26] snmp-agent sys-info version all [22:38:26] snmp-agent trap enable arp [22:38:26] snmp-agent trap enable radius [22:38:26] snmp-agent trap enable syslog [22:38:26] snmp-agent trap enable wlan ap [22:38:26] snmp-agent trap enable wlan capwap [22:38:26] snmp-agent trap enable wlan client [22:38:26] snmp-agent trap enable wlan client-audit [22:38:26] snmp-agent trap enable wlan load-balance [22:38:26] snmp-agent trap enable wlan mobility [22:38:26] snmp-agent trap enable wlan usersec [22:38:26]# [22:38:26] ssh server enable [22:38:26]# [22:38:26]domain local-mac [22:38:26] authentication lan-access local [22:38:26]# [22:38:26]domain system [22:38:26]# [22:38:26] domain default enable system [22:38:26]# [22:38:26]role name level-0 [22:38:26] description Predefined level-0 role [22:38:26]# [22:38:26]role name level-1 [22:38:26] description Predefined level-1 role [22:38:26]# [22:38:26]role name level-2 [22:38:26] description Predefined level-2 role [22:38:26]# [22:38:26]role name level-3 [22:38:26] description Predefined level-3 role [22:38:26]# [22:38:26]role name level-4 [22:38:26] description Predefined level-4 role [22:38:26]# [22:38:26]role name level-5 [22:38:26] description Predefined level-5 role [22:38:26]# [22:38:26]role name level-6 [22:38:26] description Predefined level-6 role [22:38:26]# [22:38:26]role name level-7 [22:38:26] description Predefined level-7 role [22:38:27]# [22:38:27]role name level-8 [22:38:27] description Predefined level-8 role [22:38:27]# [22:38:27]role name level-9 [22:38:27] description Predefined level-9 role [22:38:27]# [22:38:27]role name level-10 [22:38:27] description Predefined level-10 role [22:38:27]# [22:38:27]role name level-11 [22:38:27] description Predefined level-11 role [22:38:27]# [22:38:27]role name level-12 [22:38:27] description Predefined level-12 role [22:38:27]# [22:38:27]role name level-13 [22:38:27] description Predefined level-13 role [22:38:27]# [22:38:27]role name level-14 [22:38:27] description Predefined level-14 role [22:38:27]# [22:38:27]user-group system [22:38:27]# [22:38:27]local-user admin class manage [22:38:27] password hash $h$6$axhJ+KuL5VIyagQJ$uWqlEwxvQsShm9TVmW1QSqL2V2V38fp6IEiqe93IioYuCUyuo/KiD8rR9HDhov07m6anxpVpXxg1oG7rU9Gu2Q== [22:38:27] service-type ssh telnet http https [22:38:27] authorization-attribute user-role network-admin [22:38:27]# [22:38:27]local-user 000af5ea5acc class network [22:38:27] password cipher $c$3$a339AxxsqUB5o6fTIYPQFH/cwPJ4a4d0JmTdEEJO3Q== [22:38:27] service-type lan-access [22:38:27] authorization-attribute user-role network-operator [22:38:28] description ǹ [22:38:28]# [22:38:28]local-user 000b970cdda3 class network [22:38:28] password cipher $c$3$j+iDYGqyF7L79zC1Nc13Qu996vH8HxRJxI7iQer0RA== [22:38:28] service-type lan-access [22:38:28] authorization-attribute user-role network-operator [22:38:28] description 000b970cdda3 [22:38:28]# [22:38:28]local-user 000b970cde6e class network [22:38:28] password cipher $c$3$+P3ClMkqyeqVDndOLYVtkBUgCfcmEOfrYyMAGB5ayQ== [22:38:28] service-type lan-access [22:38:28] authorization-attribute user-role network-operator [22:38:28] description 000b970cde6e [22:38:28]# [22:38:28]local-user 000b970cdf60 class network [22:38:28] password cipher $c$3$93IoHJX655GQTk299jpAPJgjLnRRrV8lXthe2jqimQ== [22:38:28] service-type lan-access [22:38:28] authorization-attribute user-role network-operator [22:38:28] description 000b970cdf60 [22:38:28]# [22:38:28]local-user 000b970cdf7f class network [22:38:28] password cipher $c$3$JNg42Pecz0YbRetdZ4w/XRb/6iJ13jCrSRRVGFRyMw== [22:38:28] service-type lan-access [22:38:28] authorization-attribute user-role network-operator [22:38:28] description 000b970cdf7f [22:38:28]# [22:38:28]local-user 000b970ce9b6 class network [22:38:28] password cipher $c$3$CNumkDhJ3NI11cC54Vo0BpnZkNsMRErGLKx9ug/c5w== [22:38:28] service-type lan-access [22:38:28] authorization-attribute user-role network-operator [22:38:28] description 000b970ce9b6 [22:38:28]# [22:38:28]local-user 000b970ceb9a class network [22:38:28] password cipher $c$3$U+wrivuoT4Hqz2uzHFUKFhBaMA1rVthv8OGEmwZUgw== [22:38:28] service-type lan-access [22:38:28] authorization-attribute user-role network-operator [22:38:29] description 000b970ceb9a [22:38:29]# [22:38:29]local-user 0017c804cb9c class network [22:38:29] password cipher $c$3$rlLBReARHcGBnYXvs+SOOTLeNilYUmRwkdIrK3KYBA== [22:38:29] service-type lan-access [22:38:29] authorization-attribute user-role network-operator [22:38:29] description [22:38:29]# [22:38:29]local-user 0018de836287 class network [22:38:29] password cipher $c$3$QxPBaFGJf9L1XSorLfA4TRJcsq91d6EjqFcF1AAjkg== [22:38:29] service-type lan-access [22:38:29] authorization-attribute user-role network-operator [22:38:29] description [22:38:29]# [22:38:29]local-user 001cbf68935b class network [22:38:29] password cipher $c$3$Nev5J87KfmdoJ4Rumjnq3cVZrXwR9KGa6iSOfJCAYA== [22:38:29] service-type lan-access [22:38:29] authorization-attribute user-role network-operator [22:38:29] description [22:38:29]# [22:38:29]local-user 0026c679a5dc class network [22:38:29] password cipher $c$3$o/mFc1YfGlQL6NtxLOYqhdJOwUeBkAGcvTcc6Df2+g== [22:38:29] service-type lan-access [22:38:30] authorization-attribute user-role network-operator [22:38:30] description 溱ʼDZ [22:38:30]# [22:38:30]local-user 0061717a1f7f class network [22:38:30] password cipher $c$3$gdVYhGLp1zHHifpyAjLOJwAdUEHn83aLG9oFEg4URQ== [22:38:30] service-type lan-access [22:38:30] authorization-attribute user-role network-operator [22:38:30] description [22:38:30]# [22:38:30]local-user 044bed354e52 class network [22:38:30] password cipher $c$3$KTTWhO6RpiFSY0pmMBuPNi2/seFBqvdYxy/FqHtskQ== [22:38:30] service-type lan-access [22:38:30] authorization-attribute user-role network-operator [22:38:30] description [22:38:30]# [22:38:30]local-user 04e676ee80af class network [22:38:30] password cipher $c$3$2c7aM+tGNyVzhsYiQ268O7twdF9AfaOTPewG9/G1Bw== [22:38:30] service-type lan-access [22:38:30] authorization-attribute user-role network-operator [22:38:30] description ǰ̨֧ [22:38:30]# [22:38:30]local-user 04f7e4c32694 class network [22:38:30] password cipher $c$3$Dp4MqyqDMNNaLCWluCcyIMCkxfxRWCUhqBbGl4VV0A== [22:38:30] service-type lan-access [22:38:30] authorization-attribute user-role network-operator [22:38:30] description [22:38:30]# [22:38:30]local-user 08107a0e799e class network [22:38:30] password cipher $c$3$cBhFBWiMu1lUz4RsXUy1vYmANGbXIL2UAiY7zl7rqg== [22:38:30] service-type lan-access [22:38:30] authorization-attribute user-role network-operator [22:38:30] description P3 [22:38:30]# [22:38:30]local-user 083e8ebae269 class network [22:38:30] password cipher $c$3$bmLOdMroN8PosJYuy9/PoibXauB9XHamITErrryTKg== [22:38:30] service-type lan-access [22:38:30] authorization-attribute user-role network-operator [22:38:30] description [22:38:30]# [22:38:30]local-user 0c1dafcf6158 class network [22:38:30] password cipher $c$3$hsJzYGleIrHETh+JCtGpGojUUsw8JuztDDbFWxNKZg== [22:38:30] service-type lan-access [22:38:30] authorization-attribute user-role network-operator [22:38:30] description [22:38:30]# [22:38:30]local-user 102ab36012c1 class network [22:38:30] password cipher $c$3$C/zBRJH4vLxsaF39qOZWV9QOrSCPENm6htm3pQuXmA== [22:38:30] service-type lan-access [22:38:30] authorization-attribute user-role network-operator [22:38:30] description ʦ [22:38:30]# [22:38:30]local-user 102ab37c3ec4 class network [22:38:30] password cipher $c$3$pqSJghepOFR6NErAjtzV7Jtx3Z/2QVbcK0/GFTK+bQ== [22:38:30] service-type lan-access [22:38:30] authorization-attribute user-role network-operator [22:38:30] description [22:38:30]# [22:38:30]local-user 14bd61b44606 class network [22:38:30] password cipher $c$3$+jh+8II4yUTBp85KMJVSgws8iznT9xkjyQmDoP9ktQ== [22:38:30] service-type lan-access [22:38:30] authorization-attribute user-role network-operator [22:38:30] description [22:38:30]# [22:38:30]local-user 18f643deb733 class network [22:38:30] password cipher $c$3$g6ILFk645mQK5XGDysfokJNwOTOyqB7upGoYF+1kLw== [22:38:30] service-type lan-access [22:38:30] authorization-attribute user-role network-operator [22:38:30] description [22:38:30]# [22:38:31]local-user 24050f675ca2 class network [22:38:31] password cipher $c$3$09GFLb3dIgioL/ebWbAggnG+32CHrHMwTwIrvj1+RA== [22:38:31] service-type lan-access [22:38:31] authorization-attribute user-role network-operator [22:38:31] description MINI PTH [22:38:31]# [22:38:31]local-user 24050f78b5ab class network [22:38:31] password cipher $c$3$Nb4QC298Lpkgz9Pwx9wEw0cTNU5Ig8iKcCmcIVEkYQ== [22:38:31] service-type lan-access [22:38:31] authorization-attribute user-role network-operator [22:38:31] description P4 [22:38:31]# [22:38:31]local-user 24050f78b5af class network [22:38:31] password cipher $c$3$+RcW+x8pCmfwYtM8qoMOSxsAvePwOK3K9fBRNo2P1A== [22:38:31] service-type lan-access [22:38:31] authorization-attribute user-role network-operator [22:38:31] description P2 [22:38:31]# [22:38:31]local-user 24050f7b39c7 class network [22:38:31] password cipher $c$3$GYX/DF9GAdQd5Zk1gunRguCESBmqrxPN/+YFvr30dA== [22:38:31] service-type lan-access [22:38:31] authorization-attribute user-role network-operator [22:38:31] description P4 [22:38:31]# [22:38:31]local-user 24050f7f2067 class network [22:38:31] password cipher $c$3$aSRGnc7lHvqgHtvUPjMrzIHIoe8CSJhApP9+S2iZiA== [22:38:31] service-type lan-access [22:38:31] authorization-attribute user-role network-operator [22:38:31] description P2 [22:38:31]# [22:38:31]local-user 24050f7f2105 class network [22:38:31] password cipher $c$3$BZJQZsxlwc0HOVDY1UqXwceUQAZ2OIyaJxUAA4ITUA== [22:38:31] service-type lan-access [22:38:31] authorization-attribute user-role network-operator [22:38:31] description P1 [22:38:31]# [22:38:31]local-user 24050f7f212e class network [22:38:31] password cipher $c$3$JNLXAOab0Y15v2MpBLSPwcpMrmMx4dQGyvdWjxFsAg== [22:38:31] service-type lan-access [22:38:31] authorization-attribute user-role network-operator [22:38:31] description P3 [22:38:31]# [22:38:31]local-user 24050f82360a class network [22:38:31] password cipher $c$3$9Pphm1dOPHvwy+8WQ0sAj5HfF+Jm4H7JwHdGO0FqXg== [22:38:31] service-type lan-access [22:38:31] authorization-attribute user-role network-operator [22:38:31] description H4 [22:38:31]# [22:38:31]local-user 28f0765602a2 class network [22:38:31] password cipher $c$3$0QkAE6niaFRWwi9QozHWr0axV9EqnxBkQyTmgGGAQQ== [22:38:31] service-type lan-access [22:38:31] authorization-attribute user-role network-operator [22:38:31] description [22:38:31]# [22:38:32]local-user 2e337af8db63 class network [22:38:32] password cipher $c$3$DDtNUCTF1jTlWXHTAZS55mFrlcPe0x0lA3QXkXNO4Q== [22:38:32] service-type lan-access [22:38:32] authorization-attribute user-role network-operator [22:38:32] description [22:38:32]# [22:38:32]local-user 3052cb92830e class network [22:38:32] password cipher $c$3$/Ra/tmC0q2jBrLV9h5DILw4HKl4RZ2xt29jy1/GYmQ== [22:38:32] service-type lan-access [22:38:32] authorization-attribute user-role network-operator [22:38:32] description [22:38:32]# [22:38:32]local-user 3052cb94f24a class network [22:38:32] password cipher $c$3$RfTLJc/W+7OagyEE4LeBUYXbBk+triOamo9w3gLZFQ== [22:38:32] service-type lan-access [22:38:32] authorization-attribute user-role network-operator [22:38:32] description [22:38:32]# [22:38:32]local-user 3052cb98735b class network [22:38:32] password cipher $c$3$Ost3wfDle+P+M6xq9yY2ETUH0CGDr46WzuvA5/sg2Q== [22:38:32] service-type lan-access [22:38:32] authorization-attribute user-role network-operator [22:38:32] description [22:38:32]# [22:38:32]local-user 3052cb9ac745 class network [22:38:32] password cipher $c$3$W47lHmVlxbyYrsElzx729yCas9kkeQ7ArXnBPKooAQ== [22:38:32] service-type lan-access [22:38:32] authorization-attribute user-role network-operator [22:38:32] description [22:38:32]# [22:38:32]local-user 3052cbbca5c9 class network [22:38:32] password cipher $c$3$LjqAfK4qrhQvpriVWqzEaEkw2fS3YLmXeNIHTdcxMg== [22:38:32] service-type lan-access [22:38:32] authorization-attribute user-role network-operator [22:38:32] description Ҷ1 [22:38:32]# [22:38:32]local-user 30b49e4b7061 class network [22:38:32] password cipher $c$3$jE8JJNGSXJINHv5Hc/2mOx1KfLBA5ewa//IezfWvTw== [22:38:32] service-type lan-access [22:38:32] authorization-attribute user-role network-operator [22:38:32] description 8 [22:38:32]# [22:38:32]local-user 30b49e4d272a class network [22:38:32] password cipher $c$3$freFv19Vpu+pfAaVnIAMKGsZBnt95HxyhppMhOzPiA== [22:38:32] service-type lan-access [22:38:32] authorization-attribute user-role network-operator [22:38:32] description [22:38:32]# [22:38:32]local-user 30b49e6999ef class network [22:38:32] password cipher $c$3$FlFoqMm+U6cXXXUdI8EyZaPVzlC2z3uAXr8zsVf6hA== [22:38:32] service-type lan-access [22:38:32] authorization-attribute user-role network-operator [22:38:32] description MINI¥ [22:38:32]# [22:38:32]local-user 30b49e746633 class network [22:38:32] password cipher $c$3$Huuvv9/nLEYPGKaz96fQ9v0A8C9pSiFAPFlMQPK/pg== [22:38:32] service-type lan-access [22:38:32] authorization-attribute user-role network-operator [22:38:32] description 6 [22:38:32]# [22:38:32]local-user 30b49e7776c8 class network [22:38:32] password cipher $c$3$rEGLaqHxFdb0ZSE9kLz75x7AatYsr36Ouu5SITWEkw== [22:38:32] service-type lan-access [22:38:32] authorization-attribute user-role network-operator [22:38:32] description 5 [22:38:32]# [22:38:32]local-user 30f7725c8533 class network [22:38:32] password cipher $c$3$5hd4M08GFPCEWgcCZPFSbXfnz101Lnrav3jF7YMs7A== [22:38:32] service-type lan-access [22:38:32] authorization-attribute user-role network-operator [22:38:32] description [22:38:32]# [22:38:32]local-user 34363b67c186 class network [22:38:32] password cipher $c$3$sANBgxl3ZyudLr2xNH80Vj1jlH89VRVE6jSnQcNk0w== [22:38:32] service-type lan-access [22:38:32] authorization-attribute user-role network-operator [22:38:32] description [22:38:32]# [22:38:32]local-user 34689529aaeb class network [22:38:32] password cipher $c$3$iBmwV+J63JbtB28+d1GFWAhIxsulPeUooma4RJ0g1A== [22:38:32] service-type lan-access [22:38:32] authorization-attribute user-role network-operator [22:38:32] description [22:38:32]# [22:38:32]local-user 38aa3c7ac534 class network [22:38:32] password cipher $c$3$xrDQZPrIHsmYsLxaiAAe9kRFIvBQRDJHE0ep57wT5w== [22:38:32] service-type lan-access [22:38:32] authorization-attribute user-role network-operator [22:38:32] description [22:38:32]# [22:38:32]local-user 40490f9afe14 class network [22:38:32] password cipher $c$3$XwWoeZ/ahOtsGXjN76tEcXyhshd55ge4NIzs7rg7qg== [22:38:32] service-type lan-access [22:38:32] authorization-attribute user-role network-operator [22:38:32] description 3-1 [22:38:32]# [22:38:33]local-user 4404448a63b2 class network [22:38:33] password cipher $c$3$hJDpTRJWkQd9PkSsTYSCl+VsdIdYH7+No9D+DswEkg== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description [22:38:33]# [22:38:33]local-user 4851b7f54263 class network [22:38:33] password cipher $c$3$Rbdyinmkk5wlsgG040WE27+bBYVX3xGF1anbXubbXg== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description 7 [22:38:33]# [22:38:33]local-user 4c3488f515f4 class network [22:38:33] password cipher $c$3$0RkBGEn2vz2CO01rZmTX4HV5myKrXWDq2+EDj6PTnA== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description [22:38:33]# [22:38:33]local-user 4c7c5f16379f class network [22:38:33] password cipher $c$3$RL/rQdHvUYt2cS2iK+5qCSl1385wA8RuZcFULLnS7Q== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description [22:38:33]# [22:38:33]local-user 54724f2d6002 class network [22:38:33] password cipher $c$3$O3wpLl9HVzGPCMZEsYZu78M8m3iynjeDjx9BbQ3e+g== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description Ҷ2 [22:38:33]# [22:38:33]local-user 548ca01f59b4 class network [22:38:33] password cipher $c$3$tnYZjrNssZncG4qRMSWSrL5bb16hELAC9m948ehHkA== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description [22:38:33]# [22:38:33]local-user 548ca0ef59b4 class network [22:38:33] password cipher $c$3$vYYzY5kNPtpoWED6ztl2B7YvoLs0M6k+9UE1JtZpyQ== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description [22:38:33]# [22:38:33]local-user 549f13864674 class network [22:38:33] password cipher $c$3$XvIjmdUytlXhY/Mis37UTke71i3KvnAXFhsbI3JuTA== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description ʢ [22:38:33]# [22:38:33]local-user 549f135a20b6 class network [22:38:33] password cipher $c$3$kQq11TWpWjtvzixzF4KNvGZzIViMfxkAo8W24TLLhA== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description [22:38:33]# [22:38:33]local-user 5800e3d3405d class network [22:38:33] password cipher $c$3$pLyMy9I8RlAxOpHqQNbcY5WBfg5Gxw9UY8JiRNIHOQ== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description [22:38:33]# [22:38:33]local-user 5800e3d43149 class network [22:38:33] password cipher $c$3$vLJaYnVN66V0K5y6YchR86jnFMJbMNuuvRnjkKE8aw== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description Ԭ [22:38:33]# [22:38:33]local-user 5800e3d42d71 class network [22:38:33] password cipher $c$3$iIC7SmvxN5v0psrJIBHMQQ6YesnF+gdd1BQz2y6YYA== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description [22:38:33]# [22:38:33]local-user 5800e3d42d77 class network [22:38:33] password cipher $c$3$11KkhdywdtfZAiyiHpbIPXkWeDQ8h46nun54PIf3bw== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description [22:38:33]# [22:38:33]local-user 58fb84a11b9d class network [22:38:33] password cipher $c$3$I6QIdfY+BLKe2qZDyIo8fAzGWsdpDmXbK27N7+RFVQ== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description 2 [22:38:33]# [22:38:33]local-user 58fb84a2a1e8 class network [22:38:33] password cipher $c$3$RFfZoayKxoC9Hwgez5NINRrXWgIN77rWGzstXfkFEQ== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description 1 [22:38:33]# [22:38:33]local-user 5c93a2943e44 class network [22:38:33] password cipher $c$3$cMo8mQ3Zk07QhomnxcVIUj7WW32H5VqUz3pDxqAz1Q== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description Ԭ [22:38:33]# [22:38:33]local-user 5c93a2943e5b class network [22:38:33] password cipher $c$3$W3IgzyP+lXzjcstsYxEIpVzXOJgNmYjxo6nWcZXOtw== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description [22:38:33]# [22:38:33]local-user 606dc78d09fd class network [22:38:33] password cipher $c$3$4nNplwlUYzaQ0RJQzlD+/tJCmx1LbBScV6oy96lt+w== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description [22:38:33]# [22:38:33]local-user 64a5c3bc6bc2 class network [22:38:33] password cipher $c$3$QnmfnGShISY0474/tmkSKhCzz1Q+/BiyqsbNA4m17Q== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description [22:38:33]# [22:38:33]local-user 6c25b950bf92 class network [22:38:33] password cipher $c$3$4rpfa2X6qOvyNiWBKJlzZ5Qov27VwvZoul5GNTKmsQ== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description [22:38:33]# [22:38:33]local-user 6c72e7b96b50 class network [22:38:33] password cipher $c$3$VeQHhLy09iBfO4ApluImqxBRNbXqEQGp3SO9M4bI9Q== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description Ӣ [22:38:33]# [22:38:33]local-user 6ce873be0b66 class network [22:38:33] password cipher $c$3$GBPqWDmsD4Qicy2Jal16sMYhNbvxqSnYNBS9X4IEqA== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description Χ [22:38:33]# [22:38:33]local-user 703eac6821c9 class network [22:38:33] password cipher $c$3$GQEzHzMM08ZlWED/jDTxXH+J/UTB5vLDjYCIz8Nsig== [22:38:33] service-type lan-access [22:38:33] authorization-attribute user-role network-operator [22:38:33] description [22:38:33]# [22:38:34]local-user 70e72cdb23ea class network [22:38:34] password cipher $c$3$fcnnEwIuxQE6cmMHVowHPzBVCCKzDczzXCp3OVs6Wg== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description [22:38:34]# [22:38:34]local-user 7451ba6fee5b class network [22:38:34] password cipher $c$3$KcmNO30uo4MHloeLww083kVGEI6aG6ZFBVP7fvtjXw== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description [22:38:34]# [22:38:34]local-user 74a52837d8cd class network [22:38:34] password cipher $c$3$RbPTAn0SVtvC012QTOWvvh+ryl3pG5Ki5ExY/pYQZA== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description [22:38:34]# [22:38:34]local-user 74dfbf0038af class network [22:38:34] password cipher $c$3$gDmu+kdublaaljzD3rq7pXzoZcY63CqGa1t4JVea2g== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description [22:38:34]# [22:38:34]local-user 74dfbf003a4a class network [22:38:34] password cipher $c$3$VGS+SEGEyPQ+4gAXcP3uAtx5WZc1GwgemhjEwnmeNw== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description Ҷ [22:38:34]# [22:38:34]local-user 74dfbf004e7f class network [22:38:34] password cipher $c$3$ys3c1zIeOYjScHleTn6N9I7RXJa0yw9xTkxh9EPnHg== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description Χ1 [22:38:34]# [22:38:34]local-user 74dfbf00536d class network [22:38:34] password cipher $c$3$UMi0HUtQINAEl8WxzWBi36RVI61dlg4Fjn1Af8iBBA== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description MINI¥3 [22:38:34]# [22:38:34]local-user 74e50b938144 class network [22:38:34] password cipher $c$3$TGmSA6vu6tHfG9u8Igdx9m0LHewCa4/BZhXM6m2kEg== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description [22:38:34]# [22:38:34]local-user 7c019123fa1b class network [22:38:34] password cipher $c$3$31kat5M4PHJeI4Rzx4JiM137aM6Z3X1p3BnTiTujhA== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description [22:38:34]# [22:38:34]local-user 844167412aee class network [22:38:34] password cipher $c$3$dNFbjvUtWqPiv848opQWkQeDoTbROGZu7VWp+nfA8w== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description [22:38:34]# [22:38:34]local-user 907a280155de class network [22:38:34] password cipher $c$3$aRusrbeBWcH6CG9hRX1rXjsigd9XPnBk5hl3nT8YLg== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description ΰ [22:38:34]# [22:38:34]local-user 908d6cd7a120 class network [22:38:34] password cipher $c$3$6LDNKXQ5km6SQZhlDi/7Uaa0CHRiB4AyMesFwEJ+IQ== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description [22:38:34]# [22:38:34]local-user 90b931718150 class network [22:38:34] password cipher $c$3$jaW74/eDvPx8UIhILS+pv/GKQHSTV/J6v0cV19GhJQ== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description [22:38:34]# [22:38:34]local-user 9801a7cccf35 class network [22:38:34] password cipher $c$3$IbCMxtU247Y7WuGsKr0sdNKyf5og+T1SW2RtrlcStA== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description [22:38:34]# [22:38:34]local-user 9cb6d00f1d75 class network [22:38:34] password cipher $c$3$oFAQlfR6lU/WuS/wwHCc3ATEpULpI0V9QQ77Zo6eZA== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description [22:38:34]# [22:38:34]local-user a0c5897035e1 class network [22:38:34] password cipher $c$3$1CGsgSTwv+JYqXbdhdRJOQ8Qjd5NkMszsWCrOuq+9g== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description [22:38:34]# [22:38:34]local-user a81b5a8bf986 class network [22:38:34] password cipher $c$3$14QV/DPXK6pwIipWKEW2KWN6IkaGmg5+E7AfBYXv/Q== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description [22:38:34]# [22:38:34]local-user ac2b6e86dea4 class network [22:38:34] password cipher $c$3$TLEwo2jZALlzKiGnK0dEtqcskjlx85nyHAIiK0yPBQ== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description Χ [22:38:34]# [22:38:34]local-user acd1b84cae5b class network [22:38:34] password cipher $c$3$X+alH8KUUc6Ar7dMY0fAl8ZHRK707sbjQLD5E8H+Vg== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description [22:38:34]# [22:38:34]local-user acd1b853fdd7 class network [22:38:34] password cipher $c$3$k4Cpy9oHC+ygMNyS7zVQ4r3tWStPQG7h4WnetoYbbA== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description 1¥ӡ [22:38:34]# [22:38:34]local-user ace010dd474f class network [22:38:34] password cipher $c$3$NNVgi2JBL/CUgE2Y8+V6TMJ+CoL+rQHQJOZTD7LWSQ== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description ʦ [22:38:34]# [22:38:34]local-user ace010dd5dc3 class network [22:38:34] password cipher $c$3$zsX4NaxSpqtcmgHAS9utBMU3hAaCJXSvoe9BhXl9eg== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description 0041 [22:38:34]# [22:38:34]local-user ace010e73439 class network [22:38:34] password cipher $c$3$w4Y0/Bu/Dr+Ll7E7b5Q5kb7CbY1F2Aj5qGLV2VRDkw== [22:38:34] service-type lan-access [22:38:34] authorization-attribute user-role network-operator [22:38:34] description Ҷ [22:38:34]# [22:38:35]local-user ace010ea636f class network [22:38:35] password cipher $c$3$gJSEiCm4VsY1xOXovLdg+xb1KoUp8XzFnMepgIk/ug== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description [22:38:35]# [22:38:35]local-user ace010ea6db2 class network [22:38:35] password cipher $c$3$r0uQfmG3gDQXdY2mLOpKO2UQOC0MO+TOVG6Y5MV3nQ== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description [22:38:35]# [22:38:35]local-user ace010ea79ef class network [22:38:35] password cipher $c$3$hI3GTn0d9BU6XwBWAhT+tBKkeiSAYtOmqJnf2/buaA== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description 溵 [22:38:35]# [22:38:35]local-user ace010ea7b65 class network [22:38:35] password cipher $c$3$SmYfQjLeMgAE6h2i4AFe8wNMDPZPeIOc+50/Mv2nEg== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description Χni [22:38:35]# [22:38:35]local-user ace010efdd62 class network [22:38:35] password cipher $c$3$OhTPV3aDlQtQsqXfvlxiKKk9/iygveLFmeqOzqCYpw== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description [22:38:35]# [22:38:35]local-user ace010f55ce3 class network [22:38:35] password cipher $c$3$kOKMGL95aKHHcydilmoafQLNtqQbpYoZdnc+TrqRhQ== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description [22:38:35]# [22:38:35]local-user ace010f566fb class network [22:38:35] password cipher $c$3$3IEhkk0GB5s9immye7UTinNFMzRzEVakm2uIAwhwfQ== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description 0030 [22:38:35]# [22:38:35]local-user ace010f572dc class network [22:38:35] password cipher $c$3$qwaQe1POMcJzZn8BLkIvagNxjFybyjn2PHYNkQUQmA== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description [22:38:35]# [22:38:35]local-user ace010f572dd class network [22:38:35] password cipher $c$3$gKa7dygF9A7SegYulSPT5nurnua66I2XZ3KXO8l2tQ== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description ׯ [22:38:35]# [22:38:35]local-user b01041662793 class network [22:38:35] password cipher $c$3$151WptceM7qNyXBaPYKAcyy37DEgk3VSXY1+QqaOnQ== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description [22:38:35]# [22:38:35]local-user b01041662d05 class network [22:38:35] password cipher $c$3$zNO4ifrVPO1IFlZWz4ArVT1dfg0J5KFTOwF0qgHV/A== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description P1gongcheng [22:38:35]# [22:38:35]local-user b01041664d5d class network [22:38:35] password cipher $c$3$02DWyLWSBvJIf65GV0YQRQ+YO57T+zqw9c0Dg2ELwg== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description [22:38:35]# [22:38:35]local-user b886879c7343 class network [22:38:35] password cipher $c$3$chI3Yi5WoFPGQzbaUzWg/PJxEXyYbV/Xa9hllOHCew== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description 2 [22:38:35]# [22:38:35]local-user b886879f0af5 class network [22:38:35] password cipher $c$3$6kcTquJyHsRfZ2WtBzpc3/gnEPzie/nhmF7zpippDA== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description 2 [22:38:35]# [22:38:35]local-user b886879f19f8 class network [22:38:35] password cipher $c$3$N6hNgef6/pRDNPzHlCs2x7sOHWwG48Hw2RdnIm56hA== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description 3 [22:38:35]# [22:38:35]local-user b88687e0397a class network [22:38:35] password cipher $c$3$MOqvSQUVGw9B9jn6D24AxNr75I6srHqXOPle/nn1bQ== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description MINI¥2 [22:38:35]# [22:38:35]local-user b88687e0485d class network [22:38:35] password cipher $c$3$W4+bp5hl3YKOeqT2JrAIfPx6yrlNnNLT3zWvUStGBg== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description ʢ [22:38:35]# [22:38:35]local-user b88687e04dee class network [22:38:35] password cipher $c$3$fM+K9GtcIFrrzeSuJ6+xhv3fRtpCekzcFUCUSExVdA== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description 1 [22:38:35]# [22:38:35]local-user b88687e04dff class network [22:38:35] password cipher $c$3$D81/PF9JVM4tnUwoIdIZh2qd6apa5nqoMuleYa4XMQ== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description 4 [22:38:35]# [22:38:35]local-user bc1c81068ec7 class network [22:38:35] password cipher $c$3$YsHRhLu2Ihw4D2rm7mt3r741gSR21stKuPIjSSC9uA== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description ͶӰ [22:38:35]# [22:38:35]local-user bc9fefc6472c class network [22:38:35] password cipher $c$3$/cX0nvOQxC1OUN8ocBeHu440RviSjvWE+CGeqdKAuw== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description [22:38:35]# [22:38:35]local-user c0335ee05789 class network [22:38:35] password cipher $c$3$q+1InbinyeItUZPN0uGP/2gVUre/Xc0M4FORO+3Paw== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description ½1 [22:38:35]# [22:38:35]local-user c8f230739096 class network [22:38:35] password cipher $c$3$OG5iFESvPq5vOZ6nX7Vbm7b3YMGqlTW+IsqKaP/D4g== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description c8f230739096 [22:38:35]# [22:38:35]local-user c8ff286803c5 class network [22:38:35] password cipher $c$3$Wt8PexOsa1WYa76949wjHMHAUiXLfoEDaHZBb3sINw== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description ʦ [22:38:35]# [22:38:35]local-user c8ff28b57dfd class network [22:38:35] password cipher $c$3$C/d35Q6+39udd7YMTXJMR4wjK3E9P7qlchzXASkD4w== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description [22:38:35]# [22:38:35]local-user c8ff28d3d640 class network [22:38:35] password cipher $c$3$W82as2xBDO/HTp6UFMvGuZwgXrGmvGnuuAxyjsDxtg== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description [22:38:35]# [22:38:35]local-user d03311408a57 class network [22:38:35] password cipher $c$3$MajFjOxvVe8YfORYYWyffnHnvmxFX+68YM02wUljPg== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description [22:38:35]# [22:38:35]local-user d04f7ebbf42f class network [22:38:35] password cipher $c$3$96B/GwJvBB1bzEJU+CTB3JoetTp/hb845ufYTfUlMQ== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description ½ [22:38:35]# [22:38:35]local-user dc2b2a891077 class network [22:38:35] password cipher $c$3$lqaAmO9G67JQm1hW+wlYfoy9CdbTmE9pc+7zdEaJdQ== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description [22:38:35]# [22:38:35]local-user dc3714a91e92 class network [22:38:35] password cipher $c$3$lVFBlDrdGtxjoYF2/qtYcSYotpRWEqYDUci8mTeC3Q== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description [22:38:35]# [22:38:35]local-user dc86d823a2ee class network [22:38:35] password cipher $c$3$7ttu7UKGgLLFDQxY+AfkK76t0CnZz4DK88K2GWfwvw== [22:38:35] service-type lan-access [22:38:35] authorization-attribute user-role network-operator [22:38:35] description Ҷ [22:38:35]# [22:38:35]local-user dc9b9c192f18 class network [22:38:36] password cipher $c$3$Rrk9cKiTk8u5ywmYUEC2LelMXk2RDtYAp4elsmkYnw== [22:38:36] service-type lan-access [22:38:36] authorization-attribute user-role network-operator [22:38:36] description dc9b9c192f18 [22:38:36]# [22:38:36]local-user e0ddc03c8022 class network [22:38:36] password cipher $c$3$/7z8JdYG+5UNScZrn8lePEgADZakKk1fKcK3TjyuuQ== [22:38:36] service-type lan-access [22:38:36] authorization-attribute user-role network-operator [22:38:36] description [22:38:36]# [22:38:36]local-user e425e7274696 class network [22:38:36] password cipher $c$3$LgpkUU4xTrTpkn907tgYOgRSVKRGkd3pExX7FFKruQ== [22:38:36] service-type lan-access [22:38:36] authorization-attribute user-role network-operator [22:38:36] description [22:38:36]# [22:38:36]local-user e49a798d2258 class network [22:38:36] password cipher $c$3$i3PIditbuo51Lyuv0AmsS22bWYviWei+sm73vDam/Q== [22:38:36] service-type lan-access [22:38:36] authorization-attribute user-role network-operator [22:38:36] description [22:38:36]# [22:38:36]local-user f01b6cc51934 class network [22:38:36] password cipher $c$3$a+hq3vX/SMoueBLhMBSiReUt3WokMKvDSFB+EjY4EA== [22:38:36] service-type lan-access [22:38:36] authorization-attribute user-role network-operator [22:38:36] description [22:38:36]# [22:38:36]local-user f099bf82561c class network [22:38:36] password cipher $c$3$9NxlUg+um9xPUsx4BhoJ35EBo0TAIiJyQ30m/MZXEA== [22:38:36] service-type lan-access [22:38:36] authorization-attribute user-role network-operator [22:38:36] description [22:38:36]# [22:38:36]local-user f0f61c22e0c9 class network [22:38:36] password cipher $c$3$CL/yQqveG9x8pyRMvHw5KxACGSuNAhn7y+/WwbmeWA== [22:38:36] service-type lan-access [22:38:36] authorization-attribute user-role network-operator [22:38:36] description [22:38:36]# [22:38:36]local-user fc64ba547e50 class network [22:38:36] password cipher $c$3$0+exmRumz4/XgNTBuBHugRAU/q0TX0EQXOc+T5naSQ== [22:38:36] service-type lan-access [22:38:36] authorization-attribute user-role network-operator [22:38:36] description [22:38:36]# [22:38:36]local-user fcd733342ff2 class network [22:38:36] password cipher $c$3$Q2aVxzPPNdCozeOqMS8qbiL5+oBK8q2A4LMal7v3hg== [22:38:36] service-type lan-access [22:38:36] authorization-attribute user-role network-operator [22:38:36] description P1· [22:38:36]# [22:38:36]local-user fcdbb3c709ff class network [22:38:36] password cipher $c$3$QR1uZ1zg1CPb52Avv3P5XD+yUgYBO9HIlkuK6vv+7w== [22:38:36] service-type lan-access [22:38:36] authorization-attribute user-role network-operator [22:38:36] description [22:38:36]# [22:38:36]public-key peer 1.1.1.1 [22:38:36] public-key-code begin [22:38:36] 30819F300D06092A864886F70D010101050003818D0030818902818100A93EC4375548C108 [22:38:36] A44D4DEFFE7F650C92C6E26777C400C5CFE1DE38241009810F9BA8D64482CED0B0A52126BC [22:38:36] EA0D75DB67011E3960C3295A425032AABEB94F59202E906DF40DBB54080E2DAE888EF56FBD [22:38:36] C3197553F8B93DCC1D0F3BD3D6F572C6E36A9A0A8A79834924BB17263101CDAB77A8CB3CD8 [22:38:36] BD56C339C69978C77B0203010001 [22:38:36] public-key-code end [22:38:36] peer-public-key end [22:38:36]# [22:38:36]public-key peer 10.0.14.1 [22:38:36] public-key-code begin [22:38:36] 30819F300D06092A864886F70D010101050003818D0030818902818100C7198E166BACEC2E [22:38:36] B865FC3E6646F7F4D7850317EB3675FE0797466CC2A89B4669164EABB3A344CF0C341B918F [22:38:36] 141B5B96827B8047A65993B9BA44A9A8D68B6B40C785324D7A2B0204752BF25DABF5C64E0B [22:38:36] EF4C0E9434A3548FE675FE26D98316AA5DCDC3292CAFAE8DF51B822DCDACEA4C48AF91D413 [22:38:36] AD6AA2A0FDF2D362270203010001 [22:38:36] public-key-code end [22:38:36] peer-public-key end [22:38:36]# [22:38:36] ip http enable [22:38:36] ip https enable [22:38:36]# [22:38:36] wlan auto-ap enable [22:38:36] wlan auto-persistent enable [22:38:36]# [22:38:36]wlan global-configuration [22:38:36]# [22:38:36]wlan ap-group default-group [22:38:36] vlan 1 [22:38:36]# [22:38:36]wlan ap east-dptc1-ap05 model WA2620X [22:38:36] serial-id 219801A0KTM161002540 [22:38:36] map-configuration cfa0:/apcfg.txt [22:38:36] radio 1 [22:38:36] channel 157 [22:38:36] radio enable [22:38:36] service-template 1 vlan 10 [22:38:36] service-template 2 vlan 30 [22:38:36] service-template 3 vlan 40 [22:38:36] radio 2 [22:38:36] channel 6 [22:38:36] radio enable [22:38:36] service-template 1 vlan 10 [22:38:36] service-template 2 vlan 30 [22:38:36] service-template 3 vlan 40 [22:38:36]# [22:38:36]wlan ap east-dptc2-ap17 model WA2620X [22:38:36] serial-id 219801A0KTM161002565 [22:38:36] radio 1 [22:38:36] channel 161 [22:38:36] radio enable [22:38:36] service-template 1 vlan 10 [22:38:36] service-template 2 vlan 30 [22:38:36] service-template 3 vlan 40 [22:38:36] radio 2 [22:38:36] channel 6 [22:38:36] radio enable [22:38:36] service-template 1 vlan 10 [22:38:36] service-template 2 vlan 30 [22:38:36] service-template 3 vlan 40 [22:38:36]# [22:38:36]wlan ap east-jygy-kfzx-ap01 model WA4320i-ACN [22:38:36] serial-id 210235A1GQC14A000384 [22:38:37] priority 2 [22:38:37] map-configuration cfa0:/apcfg.txt [22:38:37] vlan 1 [22:38:37] radio 1 [22:38:37] channel 161 [22:38:37] radio enable [22:38:37] service-template 1 vlan 10 [22:38:37] service-template 2 vlan 30 [22:38:37] service-template 3 vlan 40 [22:38:37] radio 2 [22:38:37] channel 6 [22:38:37] radio enable [22:38:37] service-template 1 vlan 10 [22:38:37] service-template 2 vlan 30 [22:38:37] service-template 3 vlan 40 [22:38:37] gigabitethernet 1 [22:38:37] gigabitethernet 2 [22:38:37]# [22:38:37]wlan ap east-jygy-kfzx-ap02 model WA4320i-ACN [22:38:37] serial-id 210235A1GQC14A000599 [22:38:37] map-configuration cfa0:/apcfg.txt [22:38:37] vlan 1 [22:38:37] radio 1 [22:38:37] channel 165 [22:38:37] radio enable [22:38:37] service-template 1 vlan 10 [22:38:37] service-template 2 vlan 30 [22:38:37] service-template 3 vlan 40 [22:38:37] radio 2 [22:38:37] channel 11 [22:38:37] radio enable [22:38:37] service-template 1 vlan 10 [22:38:37] service-template 2 vlan 30 [22:38:37] service-template 3 vlan 40 [22:38:37] gigabitethernet 1 [22:38:37] gigabitethernet 2 [22:38:37]# [22:38:37]wlan ap east-p3-ap01 model WA2620X [22:38:37] serial-id 219801A0KTM161002760 [22:38:37] map-configuration cfa0:/apcfg.txt [22:38:37] radio 1 [22:38:37] channel 149 [22:38:37] radio enable [22:38:37] service-template 1 vlan 10 [22:38:37] service-template 2 vlan 30 [22:38:37] service-template 3 vlan 40 [22:38:37] radio 2 [22:38:37] channel 11 [22:38:37] radio enable [22:38:37] service-template 1 vlan 10 [22:38:37] service-template 2 vlan 30 [22:38:37] service-template 3 vlan 40 [22:38:37]# [22:38:37]wlan ap east-p3-ap02 model WA2620X [22:38:37] serial-id 219801A0KTM161002532 [22:38:37] map-configuration cfa0:/apcfg.txt [22:38:37] radio 1 [22:38:37] channel 153 [22:38:37] radio enable [22:38:37] service-template 1 vlan 10 [22:38:37] service-template 2 vlan 30 [22:38:37] service-template 3 vlan 40 [22:38:37] radio 2 [22:38:37] channel 6 [22:38:37] radio enable [22:38:37] service-template 1 vlan 10 [22:38:37] service-template 2 vlan 30 [22:38:37] service-template 3 vlan 40 [22:38:37]# [22:38:38]wlan ap east-p3-ap03 model WA2620X [22:38:38] serial-id 219801A0KTM161001438 [22:38:38] map-configuration cfa0:/apcfg.txt [22:38:38] radio 1 [22:38:38] channel 157 [22:38:38] radio enable [22:38:38] service-template 1 vlan 10 [22:38:38] service-template 2 vlan 30 [22:38:38] service-template 3 vlan 40 [22:38:38] radio 2 [22:38:38] channel 11 [22:38:38] radio enable [22:38:38] service-template 1 vlan 10 [22:38:38] service-template 2 vlan 30 [22:38:38] service-template 3 vlan 40 [22:38:38]# [22:38:38]wlan ap east-p3-ap04 model WA2620X [22:38:38] serial-id 219801A0KTM161002662 [22:38:38] map-configuration cfa0:/apcfg.txt [22:38:38] radio 1 [22:38:38] channel 161 [22:38:38] radio enable [22:38:38] service-template 1 vlan 10 [22:38:39] service-template 2 vlan 30 [22:38:39] service-template 3 vlan 40 [22:38:39] radio 2 [22:38:39] channel 6 [22:38:39] radio enable [22:38:39] service-template 1 vlan 10 [22:38:39] service-template 2 vlan 30 [22:38:39] service-template 3 vlan 40 [22:38:39]# [22:38:39]wlan ap east-p3-ap05 model WA2620X [22:38:39] serial-id 219801A0KTM161001625 [22:38:39] map-configuration cfa0:/apcfg.txt [22:38:39] radio 1 [22:38:39] channel 149 [22:38:39] radio enable [22:38:39] service-template 1 vlan 10 [22:38:39] service-template 2 vlan 30 [22:38:39] service-template 3 vlan 40 [22:38:39] radio 2 [22:38:39] channel 6 [22:38:39] radio enable [22:38:39] service-template 1 vlan 10 [22:38:39] service-template 2 vlan 30 [22:38:39] service-template 3 vlan 40 [22:38:39]# [22:38:39]wlan ap east-p3-ap06 model WA2620X [22:38:39] serial-id 219801A0KTM161002816 [22:38:39] map-configuration cfa0:/apcfg.txt [22:38:39] radio 1 [22:38:39] channel 165 [22:38:39] radio enable [22:38:39] service-template 1 vlan 10 [22:38:39] service-template 2 vlan 30 [22:38:39] service-template 3 vlan 40 [22:38:39] radio 2 [22:38:39] channel 11 [22:38:39] radio enable [22:38:39] service-template 1 vlan 10 [22:38:39] service-template 2 vlan 30 [22:38:39] service-template 3 vlan 40 [22:38:39]# [22:38:40]wlan ap east-p4-ap01 model WA2620X [22:38:40] serial-id 219801A0KTM161002564 [22:38:40] map-configuration cfa0:/apcfg.txt [22:38:40] radio 1 [22:38:40] channel 149 [22:38:44] radio enable [22:38:44] service-template 1 vlan 10 [22:38:44] service-template 2 vlan 30 [22:38:44] service-template 3 vlan 40 [22:38:44] radio 2 [22:38:44] channel 6 [22:38:44] radio enable [22:38:44] service-template 1 vlan 10 [22:38:44] service-template 2 vlan 30 [22:38:44] service-template 3 vlan 40 [22:38:44]# [22:38:44]wlan ap east-p4-ap02 model WA2620X [22:38:44] serial-id 219801A0KTM161002626 [22:38:44] map-configuration cfa0:/apcfg.txt [22:38:44] radio 1 [22:38:44] channel 153 [22:38:44] radio enable [22:38:44] service-template 1 vlan 10 [22:38:44] service-template 2 vlan 30 [22:38:44] service-template 3 vlan 40 [22:38:44] radio 2 [22:38:44] channel 6 [22:38:44] radio enable [22:38:45] service-template 1 vlan 10 [22:38:45] service-template 2 vlan 30 [22:38:45] service-template 3 vlan 40 [22:38:45]# [22:38:45]wlan ap east-p4-ap03 model WA2620X [22:38:45] serial-id 219801A0KTM153000459 [22:38:45] map-configuration cfa0:/apcfg.txt [22:38:45] radio 1 [22:38:45] channel 157 [22:38:45] radio enable [22:38:45] service-template 1 vlan 10 [22:38:45] service-template 2 vlan 30 [22:38:45] service-template 3 vlan 40 [22:38:45] radio 2 [22:38:45] channel 11 [22:38:45] radio enable [22:38:45] service-template 1 vlan 10 [22:38:45] service-template 2 vlan 30 [22:38:45] service-template 3 vlan 40 [22:38:45]# [22:38:45]wlan ap east-p4-ap04 model WA2620X [22:38:45] serial-id 219801A0KTM161002525 [22:38:45] map-configuration cfa0:/apcfg.txt [22:38:45] radio 1 [22:38:45] channel 161 [22:38:45] radio enable [22:38:45] service-template 1 vlan 10 [22:38:45] service-template 2 vlan 30 [22:38:45] service-template 3 vlan 40 [22:38:45] radio 2 [22:38:45] channel 11 [22:38:45] radio enable [22:38:45] service-template 1 vlan 10 [22:38:45] service-template 2 vlan 30 [22:38:45] service-template 3 vlan 40 [22:38:45]# [22:38:45]wlan ap east-p4-ap05 model WA2620X [22:38:45] serial-id 219801A0KTM161003442 [22:38:45] map-configuration cfa0:/apcfg.txt [22:38:45] radio 1 [22:38:45] channel 165 [22:38:45] radio enable [22:38:45] service-template 1 vlan 10 [22:38:45] service-template 2 vlan 30 [22:38:45] service-template 3 vlan 40 [22:38:45] radio 2 [22:38:45] channel 6 [22:38:45] radio enable [22:38:45] service-template 1 vlan 10 [22:38:45] service-template 2 vlan 30 [22:38:45] service-template 3 vlan 40 [22:38:45]# [22:38:45]wlan ap east-p4-ap06 model WA2620X [22:38:45] serial-id 219801A0KTM161001437 [22:38:45] map-configuration cfa0:/apcfg.txt [22:38:45] radio 1 [22:38:45] channel 149 [22:38:45] radio enable [22:38:45] service-template 1 vlan 10 [22:38:45] service-template 2 vlan 30 [22:38:45] service-template 3 vlan 40 [22:38:45] radio 2 [22:38:45] channel 11 [22:38:45] radio enable [22:38:45] service-template 1 vlan 10 [22:38:45] service-template 2 vlan 30 [22:38:45] service-template 3 vlan 40 [22:38:45]# [22:38:45]wlan ap east-p4-kfzx-ap01 model WA4320i-ACN [22:38:45] serial-id 210235A1GQC14A000189 [22:38:45] map-configuration cfa0:/apcfg.txt [22:38:45] vlan 1 [22:38:45] radio 1 [22:38:45] channel 36 [22:38:45] radio enable [22:38:45] service-template 1 vlan 10 [22:38:45] service-template 2 vlan 30 [22:38:45] service-template 3 vlan 40 [22:38:45] radio 2 [22:38:45] channel 11 [22:38:45] radio enable [22:38:45] service-template 1 vlan 10 [22:38:45] service-template 2 vlan 30 [22:38:45] service-template 3 vlan 40 [22:38:45] gigabitethernet 1 [22:38:45] gigabitethernet 2 [22:38:45]# [22:38:45]wlan ap south-dptc1-xz model WA4320i-ACN [22:38:45] serial-id 210235A1GQC153900584 [22:38:45] map-configuration cfa0:/apcfg.txt [22:38:45] vlan 1 [22:38:45] radio 1 [22:38:46] channel 161 [22:38:46] radio enable [22:38:46] service-template 1 vlan 10 [22:38:46] service-template 2 vlan 30 [22:38:46] service-template 3 vlan 40 [22:38:46] radio 2 [22:38:46] channel 11 [22:38:46] radio enable [22:38:46] service-template 1 vlan 10 [22:38:46] service-template 2 vlan 30 [22:38:46] service-template 3 vlan 40 [22:38:46] gigabitethernet 1 [22:38:46] gigabitethernet 2 [22:38:46]# [22:38:46]wlan ap south-dptc2-xz model WA4320i-ACN [22:38:46] serial-id 210235A1GQC153900966 [22:38:46] map-configuration cfa0:/apcfg.txt [22:38:46] vlan 1 [22:38:46] radio 1 [22:38:46] channel 165 [22:38:46] radio enable [22:38:46] service-template 1 vlan 10 [22:38:46] service-template 2 vlan 30 [22:38:46] service-template 3 vlan 40 [22:38:46] radio 2 [22:38:46] channel 11 [22:38:46] radio enable [22:38:46] service-template 1 vlan 10 [22:38:46] service-template 2 vlan 30 [22:38:46] service-template 3 vlan 40 [22:38:46] gigabitethernet 1 [22:38:46] gigabitethernet 2 [22:38:46]# [22:38:46]wlan ap south-dtgc-ap03 model WA2620X [22:38:46] serial-id 219801A0KTM153000882 [22:38:46] map-configuration cfa0:/apcfg.txt [22:38:46] radio 1 [22:38:46] channel 157 [22:38:46] max-power 24 [22:38:46] radio enable [22:38:46] channel band-width 20 [22:38:46] service-template 1 vlan 10 [22:38:46] service-template 2 vlan 30 [22:38:46] service-template 3 vlan 40 [22:38:46] radio 2 [22:38:46] channel 11 [22:38:46] max-power 27 [22:38:46] radio enable [22:38:46] service-template 1 vlan 10 [22:38:46] service-template 2 vlan 30 [22:38:46] service-template 3 vlan 40 [22:38:46]# [22:38:46]wlan ap south-dtgc-ap04 model WA2620X [22:38:46] serial-id 219801A0KTM153000795 [22:38:46] map-configuration cfa0:/apcfg.txt [22:38:46] radio 1 [22:38:46] channel 161 [22:38:46] max-power 24 [22:38:46] radio enable [22:38:46] channel band-width 20 [22:38:46] service-template 1 vlan 10 [22:38:46] service-template 2 vlan 30 [22:38:46] service-template 3 vlan 40 [22:38:46] radio 2 [22:38:46] channel 11 [22:38:46] max-power 27 [22:38:46] radio enable [22:38:46] service-template 1 vlan 10 [22:38:46] service-template 2 vlan 30 [22:38:46] service-template 3 vlan 40 [22:38:46]# [22:38:46]wlan ap south-dtgc-ap11 model WA2620X [22:38:46] serial-id 219801A0KTM153000877 [22:38:46] map-configuration cfa0:/apcfg.txt [22:38:46] radio 1 [22:38:46] channel 165 [22:38:46] max-power 24 [22:38:46] radio enable [22:38:46] channel band-width 20 [22:38:46] service-template 1 vlan 10 [22:38:46] service-template 2 vlan 30 [22:38:46] service-template 3 vlan 40 [22:38:46] radio 2 [22:38:46] channel 6 [22:38:46] max-power 27 [22:38:46] radio enable [22:38:46] service-template 1 vlan 10 [22:38:46] service-template 2 vlan 30 [22:38:46] service-template 3 vlan 40 [22:38:46]# [22:38:46]wlan ap south-dtgc-ap14 model WA2620X [22:38:46] serial-id 219801A0KTM153000866 [22:38:46] map-configuration cfa0:/apcfg.txt [22:38:46] radio 1 [22:38:46] channel 149 [22:38:46] max-power 24 [22:38:46] radio enable [22:38:46] channel band-width 20 [22:38:46] service-template 1 vlan 10 [22:38:46] service-template 2 vlan 30 [22:38:46] service-template 3 vlan 40 [22:38:46] radio 2 [22:38:46] channel 11 [22:38:46] max-power 27 [22:38:46] radio enable [22:38:46] service-template 1 vlan 10 [22:38:46] service-template 2 vlan 30 [22:38:46] service-template 3 vlan 40 [22:38:46]# [22:38:46]wlan ap south-dtgc-ap21 model WA2620X [22:38:47] serial-id 219801A0KTM149002358 [22:38:47] map-configuration cfa0:/apcfg.txt [22:38:47] radio 1 [22:38:47] channel 153 [22:38:47] max-power 24 [22:38:47] radio enable [22:38:47] channel band-width 20 [22:38:47] service-template 1 vlan 10 [22:38:47] service-template 2 vlan 30 [22:38:47] service-template 3 vlan 40 [22:38:47] radio 2 [22:38:47] channel 6 [22:38:47] max-power 27 [22:38:47] radio enable [22:38:47] channel band-width 20 [22:38:47] service-template 1 vlan 10 [22:38:47] service-template 2 vlan 30 [22:38:47] service-template 3 vlan 40 [22:38:47]# [22:38:47]wlan ap south-dtgc-ap22 model WA2620X [22:38:47] serial-id 219801A0KTM149001424 [22:38:47] map-configuration cfa0:/apcfg.txt [22:38:47] radio 1 [22:38:47] channel 157 [22:38:47] max-power 24 [22:38:47] radio enable [22:38:47] channel band-width 20 [22:38:47] service-template 1 vlan 10 [22:38:47] service-template 2 vlan 30 [22:38:47] service-template 3 vlan 40 [22:38:47] radio 2 [22:38:47] channel 6 [22:38:47] max-power 27 [22:38:47] radio enable [22:38:47] service-template 1 vlan 10 [22:38:47] service-template 2 vlan 30 [22:38:47] service-template 3 vlan 40 [22:38:47]# [22:38:47]wlan ap south-dtgc-ap23 model WA2620X [22:38:47] serial-id 219801A0KTM153000891 [22:38:47] map-configuration cfa0:/apcfg.txt [22:38:47] radio 1 [22:38:47] channel 161 [22:38:47] max-power 24 [22:38:47] radio enable [22:38:47] channel band-width 20 [22:38:47] service-template 1 vlan 10 [22:38:47] service-template 2 vlan 30 [22:38:47] service-template 3 vlan 40 [22:38:47] radio 2 [22:38:47] channel 11 [22:38:47] max-power 27 [22:38:47] radio enable [22:38:47] service-template 1 vlan 10 [22:38:47] service-template 2 vlan 30 [22:38:47] service-template 3 vlan 40 [22:38:47]# [22:38:47]wlan ap south-dtgc-ap24 model WA2620X [22:38:47] serial-id 219801A0KTM149001308 [22:38:47] map-configuration cfa0:/apcfg.txt [22:38:47] radio 1 [22:38:47] channel 165 [22:38:47] max-power 24 [22:38:47] radio enable [22:38:47] channel band-width 20 [22:38:47] service-template 1 vlan 10 [22:38:47] service-template 2 vlan 30 [22:38:47] service-template 3 vlan 40 [22:38:47] radio 2 [22:38:47] channel 11 [22:38:47] max-power 27 [22:38:47] radio enable [22:38:47] service-template 1 vlan 10 [22:38:47] service-template 2 vlan 30 [22:38:47] service-template 3 vlan 40 [22:38:47]# [22:38:47]wlan ap south-dtgc-ap25 model WA2620X [22:38:47] serial-id 219801A0KTM153000787 [22:38:47] map-configuration cfa0:/apcfg.txt [22:38:47] radio 1 [22:38:47] channel 149 [22:38:47] max-power 24 [22:38:47] radio enable [22:38:47] channel band-width 20 [22:38:47] service-template 1 vlan 10 [22:38:47] service-template 2 vlan 30 [22:38:47] service-template 3 vlan 40 [22:38:47] radio 2 [22:38:47] channel 6 [22:38:47] max-power 27 [22:38:47] radio enable [22:38:47] service-template 1 vlan 10 [22:38:47] service-template 2 vlan 30 [22:38:47] service-template 3 vlan 40 [22:38:47]# [22:38:47]wlan ap south-dtgc-ap26 model WA4320i-ACN [22:38:47] serial-id 210235A1GQC166001364 [22:38:47] map-configuration cfa0:/apcfg.txt [22:38:47] vlan 1 [22:38:47] radio 1 [22:38:47] channel 153 [22:38:47] max-power 20 [22:38:47] radio enable [22:38:47] channel band-width 20 [22:38:47] service-template 1 vlan 10 [22:38:47] service-template 2 vlan 30 [22:38:47] service-template 3 vlan 40 [22:38:47] radio 2 [22:38:47] channel 11 [22:38:47] max-power 20 [22:38:47] radio enable [22:38:47] service-template 1 vlan 10 [22:38:47] service-template 2 vlan 30 [22:38:47] service-template 3 vlan 40 [22:38:47] gigabitethernet 1 [22:38:47] gigabitethernet 2 [22:38:47]# [22:38:47]wlan ap south-dtgc-ap27 model WA4320i-ACN [22:38:47] serial-id 210235A1GQC166001351 [22:38:47] map-configuration cfa0:/apcfg.txt [22:38:47] vlan 1 [22:38:47] radio 1 [22:38:47] channel 157 [22:38:47] max-power 20 [22:38:47] radio enable [22:38:47] channel band-width 20 [22:38:47] service-template 1 vlan 10 [22:38:47] service-template 2 vlan 30 [22:38:47] service-template 3 vlan 40 [22:38:47] radio 2 [22:38:47] channel 6 [22:38:47] max-power 20 [22:38:47] radio enable [22:38:47] service-template 1 vlan 10 [22:38:47] service-template 2 vlan 30 [22:38:47] service-template 3 vlan 40 [22:38:47] gigabitethernet 1 [22:38:47] gigabitethernet 2 [22:38:47]# [22:38:48]wlan ap south-dtgc-ap28 model WA4320i-ACN [22:38:48] serial-id 210235A1GQC166000969 [22:38:48] map-configuration cfa0:/apcfg.txt [22:38:48] vlan 1 [22:38:48] radio 1 [22:38:48] channel 161 [22:38:48] max-power 20 [22:38:48] radio enable [22:38:48] channel band-width 20 [22:38:48] service-template 1 vlan 10 [22:38:48] service-template 2 vlan 30 [22:38:48] service-template 3 vlan 40 [22:38:48] radio 2 [22:38:48] channel 6 [22:38:48] max-power 20 [22:38:48] radio enable [22:38:48] service-template 1 vlan 10 [22:38:48] service-template 2 vlan 30 [22:38:48] service-template 3 vlan 40 [22:38:48] gigabitethernet 1 [22:38:48] gigabitethernet 2 [22:38:48]# [22:38:48]wlan ap south-dtgc-ap29 model WA4320i-ACN [22:38:48] serial-id 210235A1GQC166001003 [22:38:48] map-configuration cfa0:/apcfg.txt [22:38:48] vlan 1 [22:38:48] radio 1 [22:38:48] channel 165 [22:38:48] max-power 20 [22:38:48] radio enable [22:38:48] channel band-width 20 [22:38:48] service-template 1 vlan 10 [22:38:48] service-template 2 vlan 30 [22:38:48] service-template 3 vlan 40 [22:38:48] radio 2 [22:38:48] channel 11 [22:38:48] max-power 20 [22:38:48] radio enable [22:38:48] service-template 1 vlan 10 [22:38:48] service-template 2 vlan 30 [22:38:48] service-template 3 vlan 40 [22:38:48] gigabitethernet 1 [22:38:48] gigabitethernet 2 [22:38:48]# [22:38:48]wlan ap south-dtgc-ap30 model WA4320i-ACN [22:38:48] serial-id 210235A1GQC166001365 [22:38:48] map-configuration cfa0:/apcfg.txt [22:38:48] vlan 1 [22:38:48] radio 1 [22:38:48] channel 149 [22:38:48] max-power 20 [22:38:48] radio enable [22:38:48] channel band-width 20 [22:38:48] service-template 1 vlan 10 [22:38:48] service-template 2 vlan 30 [22:38:48] service-template 3 vlan 40 [22:38:48] radio 2 [22:38:48] channel 11 [22:38:48] max-power 20 [22:38:48] radio enable [22:38:48] service-template 1 vlan 10 [22:38:48] service-template 2 vlan 30 [22:38:48] service-template 3 vlan 40 [22:38:48] gigabitethernet 1 [22:38:48] gigabitethernet 2 [22:38:48]# [22:38:48]wlan ap south-dtgc-ap31 model WA4320i-ACN [22:38:48] serial-id 210235A1GQC166001340 [22:38:48] map-configuration cfa0:/apcfg.txt [22:38:48] vlan 1 [22:38:48] radio 1 [22:38:48] channel 153 [22:38:48] max-power 20 [22:38:48] radio enable [22:38:48] channel band-width 20 [22:38:48] service-template 1 vlan 10 [22:38:48] service-template 2 vlan 30 [22:38:48] service-template 3 vlan 40 [22:38:48] radio 2 [22:38:48] channel 6 [22:38:48] max-power 20 [22:38:48] radio enable [22:38:48] service-template 1 vlan 10 [22:38:48] service-template 2 vlan 30 [22:38:48] service-template 3 vlan 40 [22:38:48] gigabitethernet 1 [22:38:48] gigabitethernet 2 [22:38:48]# [22:38:48]wlan ap south-dtgc-ap32 model WA4320i-ACN [22:38:48] serial-id 210235A1GQC166001346 [22:38:48] map-configuration cfa0:/apcfg.txt [22:38:48] vlan 1 [22:38:48] radio 1 [22:38:48] channel 157 [22:38:48] max-power 20 [22:38:48] radio enable [22:38:48] channel band-width 20 [22:38:48] service-template 1 vlan 10 [22:38:48] service-template 2 vlan 30 [22:38:48] service-template 3 vlan 40 [22:38:48] radio 2 [22:38:48] channel 11 [22:38:48] max-power 20 [22:38:48] radio enable [22:38:48] service-template 1 vlan 10 [22:38:48] service-template 2 vlan 30 [22:38:48] service-template 3 vlan 40 [22:38:48] gigabitethernet 1 [22:38:48] gigabitethernet 2 [22:38:48]# [22:38:48]wlan ap south-dtgc-ap33 model WA4320i-ACN [22:38:48] serial-id 210235A1GQC166001361 [22:38:48] map-configuration cfa0:/apcfg.txt [22:38:48] vlan 1 [22:38:48] radio 1 [22:38:48] channel 161 [22:38:48] max-power 20 [22:38:48] radio enable [22:38:48] channel band-width 20 [22:38:48] service-template 1 vlan 10 [22:38:48] service-template 2 vlan 30 [22:38:48] service-template 3 vlan 40 [22:38:48] radio 2 [22:38:48] channel 6 [22:38:48] max-power 20 [22:38:48] radio enable [22:38:48] service-template 1 vlan 10 [22:38:48] service-template 2 vlan 30 [22:38:48] service-template 3 vlan 40 [22:38:48] gigabitethernet 1 [22:38:48] gigabitethernet 2 [22:38:48]# [22:38:48]wlan ap south-dtgc-ap35 model WA2620X [22:38:48] serial-id 219801A0KTM167000227 [22:38:48] map-configuration cfa0:/apcfg.txt [22:38:48] radio 1 [22:38:48] channel 165 [22:38:48] max-power 24 [22:38:48] radio enable [22:38:48] channel band-width 20 [22:38:48] service-template 1 vlan 10 [22:38:48] service-template 2 vlan 30 [22:38:48] service-template 3 vlan 40 [22:38:48] radio 2 [22:38:48] channel 6 [22:38:48] max-power 27 [22:38:48] radio enable [22:38:48] service-template 1 vlan 10 [22:38:48] service-template 2 vlan 30 [22:38:48] service-template 3 vlan 40 [22:38:48]# [22:38:48]wlan ap south-dtgc-ap36 model WA2620X [22:38:48] serial-id 219801A0KTM167000288 [22:38:48] map-configuration cfa0:/apcfg.txt [22:38:48] radio 1 [22:38:48] channel 149 [22:38:48] max-power 24 [22:38:48] radio enable [22:38:48] channel band-width 20 [22:38:48] service-template 1 vlan 10 [22:38:48] service-template 2 vlan 30 [22:38:48] service-template 3 vlan 40 [22:38:48] radio 2 [22:38:48] channel 11 [22:38:48] max-power 27 [22:38:48] radio enable [22:38:48] service-template 1 vlan 10 [22:38:48] service-template 2 vlan 30 [22:38:48] service-template 3 vlan 40 [22:38:48]# [22:38:48]wlan ap south-dtgc-ap37 model WA2620X [22:38:48] serial-id 219801A0KTM167000249 [22:38:48] map-configuration cfa0:/apcfg.txt [22:38:48] radio 1 [22:38:48] channel 153 [22:38:48] max-power 24 [22:38:48] radio enable [22:38:48] channel band-width 20 [22:38:48] service-template 1 vlan 10 [22:38:48] service-template 2 vlan 30 [22:38:48] service-template 3 vlan 40 [22:38:48] radio 2 [22:38:48] channel 11 [22:38:48] max-power 27 [22:38:48] radio enable [22:38:48] service-template 1 vlan 10 [22:38:48] service-template 2 vlan 30 [22:38:48] service-template 3 vlan 40 [22:38:48]# [22:38:48]wlan ap south-dtgc-ap38 model WA2620X [22:38:48] serial-id 219801A0KTM167000203 [22:38:48] map-configuration cfa0:/apcfg.txt [22:38:48] radio 1 [22:38:48] channel 157 [22:38:48] max-power 24 [22:38:48] radio enable [22:38:48] channel band-width 20 [22:38:48] service-template 1 vlan 10 [22:38:48] service-template 2 vlan 30 [22:38:48] service-template 3 vlan 40 [22:38:48] radio 2 [22:38:48] channel 6 [22:38:48] max-power 27 [22:38:48] radio enable [22:38:48] service-template 1 vlan 10 [22:38:48] service-template 2 vlan 30 [22:38:48] service-template 3 vlan 40 [22:38:48]# [22:38:48]wlan ap so
zhiliao_94056 发表时间:2019-01-11
配置粘贴格式有点乱,看了下你几个服务模板下配置了隔离 user-isolation enable,同时AC上vlan500 1000等也是开启了二层隔离的,不知道你终端是哪个vlan,哪个服务模板
fywr 发表时间:2019-01-11
回复fywr:
我服务模板里没有看到配置了user-isolation enable啊,我用户时属于vlan30的
不好意思,看错了,AP的map文件里的内容单独贴一下,另外你电脑是无法ping通打印机?
回复fywr:
对,电脑ping不通打印机,上网什么的没有问题 AP配置: <<< Log from 10.0.14.2 started 一月 11, 2019, 16:45:46 >>> <south-dtgc-ap27> dis <south-dtgc-ap27>display cu <south-dtgc-ap27>display current-configuration # version 7.1.064, Release 2208P03 # sysname south-dtgc-ap27 # telnet server enable # lldp global enable # password-recovery enable # vlan 1 # vlan 2 # vlan 10 # vlan 20 # vlan 30 # vlan 40 # vlan 999 # interface NULL0 # interface Vlan-interface1 ip address dhcp-alloc # interface GigabitEthernet1/0/1 port link-type trunk port trunk permit vlan 1 to 2 10 20 30 40 999 # interface GigabitEthernet1/0/2 port access vlan 30 # interface WLAN-Radio1/0/1 # interface WLAN-Radio1/0/2 # scheduler logfile size 16 # line class console user-role network-admin # line class vty user-role network-operator # line con 0 user-role network-admin # line vty 0 4 user-role network-operator set authentication password hash $h$6$fPUlaD8TF3BoWOVO$apuJyFFYH1K/esEIjQcxFDXu r60um1blGeRuYD8lnLUJcn+2rQS6IQc784XSSgAvMdZxUA9lp449oklnCyR4oA== # line vty 5 63 user-role network-operator # undo gratuitous-arp-learning enable # domain system # domain default enable system # user-group system # return <south-dtgc-ap27> <<< Log from 10.0.14.2 ended 一月 11, 2019, 16:45:59 >>>
