f1000s 配置IP ping 不通
2019-01-15提问
  • 1收藏,1717浏览
f1000s 0/0 口IP192.168.166.252 接交换机,pc 192.168.166.66  关pc 防火墙 也接同一交换机;相互间ping 不通。
<H3C>ping 192.168.166.252
  PING 192.168.166.252: 56  data bytes, press CTRL_C to break
    Reply from 192.168.166.252: bytes=56 Sequence=1 ttl=255 time=1 ms
    Reply from 192.168.166.252: bytes=56 Sequence=2 ttl=255 time=1 ms
    Reply from 192.168.166.252: bytes=56 Sequence=3 ttl=255 time=1 ms
    Reply from 192.168.166.252: bytes=56 Sequence=4 ttl=255 time=1 ms
    Reply from 192.168.166.252: bytes=56 Sequence=5 ttl=255 time=1 ms
  --- 192.168.166.252 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 1/1/1 ms
<H3C>ping 192.168.166.66
  PING 192.168.166.66: 56  data bytes, press CTRL_C to break
    Request time out
    Request time out
    Request time out
    Request time out
    Request time out
  --- 192.168.166.66 ping statistics ---
    0 packet(s) received
    100.00% packet loss
interface GigabitEthernet0/0
 ip address 192.168.166.252 255.255.255.0
interface GigabitEthernet0/1
interface GigabitEthernet1/0
 ip address 220.173.136.89 255.255.255.240
<H3C>dis ver
 H3C Comware Software
 Comware software, Version 3.40, Release 1623
 Copyright (c) 2004-2007 Hangzhou H3C Technologies Co., Ltd.
 All rights reserved.
 Without the owner's prior written consent, no decompiling
 nor reverse-engineering shall be allowed.
 H3C SecPath F1000-S uptime is 0 week, 0 day, 0 hour, 41 minutes
  CPU type: Mips BCM1125H 600MHz
  512M bytes DDR SDRAM Memory
  16M bytes Flash Memory
  Pcb      Version:3.0
  Logic    Version:2.0
  BootROM  Version:1.26
  [SLOT 0] 2GBE     (Hardware)3.0, (Driver)2.0, (Cpld)2.0
  [SLOT 1] 2GBE     (Hardware)3.0, (Driver)2.0, (Cpld)2.0
  [SLOT 2] NDEC     (Hardware)3.0, (Driver)3.3, (Cpld)2.0
[H3C]dis interface gigabit0/0
GigabitEthernet0/0 current state :UP
Line protocol current state :UP
Description : GigabitEthernet0/0 Interface
The Maximum Transmit Unit is 1500, Hold timer is 10(sec)
Internet Address is 192.168.166.252/24
IP Sending Frames' Format is PKTFMT_ETHNT_2, Hardware address is 000f-e26d-c40f
Media type is twisted pair, loopback not set, promiscuous mode not set
100Mb/s, Full-duplex,  link type is autonegotiation
Output flow-control is disabled, input flow-control is disabled
Output queue : (Urgent queuing : Size/Length/Discards)  0/50/0
Output queue : (Protocol queuing : Size/Length/Discards) 0/500/0
Output queue : (FIFO queuing : Size/Length/Discards)  0/75/0
    Last 300 seconds input rate 92.15 bytes/sec, 737 bits/sec, 1.25 packets/sec
    Last 300 seconds output rate 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec
    Input: 2588 packets, 193325 bytes, 2601 buffers
           2576 broadcasts, 4 multicasts, 0 pauses
           0 errors, 0 runts, 0 giants
           0 crc, 0 align errors, 0 overruns
           0 dribbles, 0 drops, 0 no buffers
           0 frame errors
    Output:3 packets, 192 bytes, 3 buffers
           2 broadcasts, 0 multicasts, 0 pauses
           0 errors, 0 underruns, 0 collisions
           0 deferred, 0 lost carriers
寂东 九段
粉丝:225人 关注:3人
1,端口有没有加入相应的域
2,有没有做域间策略,
粉丝:24人 关注:0人
防火墙默认全不通,需要放通安全策略
zhiliao_iwhyV 知了小白
如何放通安全策略?
配置发下来看看
不科学君 发表时间:2019-01-15
