无线MESH故障
2019-01-19提问
  • 1收藏,2036浏览
WX2510H  配合三台 WA4320-ACN-C  希望实现MESH,以下配置远端AP始终不能注册,mesh链路也没有建立,请教原因!
  1. version 7.1.064, ESS 5417P01
  2. #
  3. sysname H3C
  4. #
  5. wlan global-configuration
  6. region-code-lock enable
  7. #
  8. telnet server enable
  9. #
  10. port-security enable
  11. #
  12. dhcp enable
  13. #
  14. dns proxy enable
  15. dns server 202.106.0.20
  16. #
  17. lldp global enable
  18. #
  19. wlan mesh-policy mesh-cl
  20. link-maximum-number 5
  21. #
  22. wlan mesh-profile 1
  23. mesh-id 1
  24. mesh-profile enable
  25. #
  26. password-recovery enable
  27. #
  28. vlan 1
  29. #
  30. dhcp server ip-pool GKNMG-WIFI-DHCP
  31. gateway-list 192.168.166.1
  32. network 192.168.166.0 mask 255.255.255.0
  33. dns-list 192.168.166.1
  34. #
  35. wlan service-template gknmg-wifi
  36. ssid WIFI
  37. client max-count 100
  38. service-template enable
  39. #
  40. interface NULL0
  41. #
  42. interface Vlan-interface1
  43. ip address 192.168.166.1 255.255.255.0
  44. #
  45. interface GigabitEthernet1/0/5
  46. port link-mode route
  47. ip address 172.16.61.10 255.255.255.0
  48. undo dhcp select server
  49. #
  50. interface GigabitEthernet1/0/1
  51. port link-mode bridge
  52. poe enable
  53. #
  54. interface GigabitEthernet1/0/2
  55. port link-mode bridge
  56. poe enable
  57. #
  58. interface GigabitEthernet1/0/3
  59. port link-mode bridge
  60. poe enable
  61. #
  62. interface GigabitEthernet1/0/4
  63. port link-mode bridge
  64. poe enable
  65. #
  66. scheduler logfile size 16
  67. #
  68. line class console
  69. user-role network-admin
  70. #
  71. line class vty
  72. user-role network-operator
  73. #
  74. line con 0
  75. user-role network-admin
  76. #
  77. line vty 0 31
  78. authentication-mode scheme
  79. user-role network-operator
  80. #
  81. undo info-center logfile enable
  82. #
  83. domain system
  84. #
  85. domain default enable system
  86. #
  87. #
  88. user-group system
  89. #
  90. local-user admin class manage
  91. password hash $h$6$/iK3DKQZCBpDFfPK$8aUHAhh7ln/VPxGnQbyWFEsHJ68orwq/Ab525OZz0u3KNKnfmAr8gZwdLpnmMU0LAtGh055KIUvgEgMCWV0jlA==
  92. service-type telnet http https
  93. authorization-attribute user-role network-admin
  94. #
  95. netconf soap http enable
  96. #
  97. ip http enable
  98. ip https enable
  99. #
  100. smartmc tm username admin password cipher $c$3$dDthPpWpPwEjCW1pj02VgjwP2OcXXPWW enable
  101. #
  102. wlan auto-ap enable
  103. wlan auto-persistent enable
  104. #
  105. wlan ap-group default-group
  106. vlan 1
  107. #
  108. wlan ap MAP1 model WA4320-ACN-C
  109. serial-id 219801A0UG818BE000T3
  110. vlan 1
  111. radio 1
  112.   type dot11an
  113.   channel 153
  114.   radio enable
  115.   channel band-width 40
  116.   mimo 2x2
  117.   mesh-policy name mesh-cl
  118.   mesh-profile 1
  119.   mesh peer-mac-address 7c1e-067e-e840
  120. radio 2
  121.   type dot11gn
  122.   radio enable
  123.   channel band-width 20
  124.   service-template gknmg-wifi
  125. gigabitethernet 1
  126. #
  127. wlan ap MAP2 model WA4320-ACN-C
  128. serial-id 219801A0UG818BE000VQ
  129. vlan 1
  130. radio 1
  131.   type dot11an
  132.   channel 153
  133.   radio enable
  134.   channel band-width 40
  135.   mimo 2x2
  136.   mesh-policy name mesh-cl
  137.   mesh-profile 1
  138.   mesh peer-mac-address 7c1e-067e-e840
  139. radio 2
  140.   radio enable
  141.   mimo 2x2
  142.   service-template gknmg-wifi
  143. gigabitethernet 1
  144. #
  145. wlan ap MPP model WA4320-ACN-C
  146. serial-id 219801A0UG818BE000VM
  147. vlan 1
  148. radio 1
  149.   type dot11an
  150.   channel 153
  151.   radio enable
  152.   channel band-width 40
  153.   mimo 2x2
  154.   mesh-policy name mesh-cl
  155.   mesh-profile 1
  156.   mesh peer-mac-address 7c1e-067e-e260
  157.   mesh peer-mac-address 7c1e-067e-e8a0
  158. radio 2
  159.   type dot11g
  160.   radio disable
  161. gigabitethernet 1
  162. #
  163. cloud-management server domain oasis.h3c.com
  164. #
  165. return
粉丝:7人 关注:0人
1.1.1  Mesh网络基本组网配置举例(AC
1-10所示,要求组建一个Mesh网络,MPP通过交换机与AC连接,在MPPMAP 1MPPMAP 2之间使用射频工作模式为802.11n5GHz),工作信道号为149来建立Mesh链路,客户端能够通过MAP接入网络并访问网络资源。
图1-1 Mesh网络基本组网图
(1)       配置Mesh功能
# 创建一个编号为1Mesh Profile
<AC> system-view
[AC] wlan mesh-profile 1
# 配置Mesh ID1
[AC-wlan-mesh-profile-1] mesh-id 1
# 配置认证模式为SAE
[AC-wlan-mesh-profile-1] akm mode sae
# 配置预共享密钥为12345678
[AC-wlan-mesh-profile-1] preshared-key pass-phrase simple 12345678
# 开启Mesh Profile
[AC-wlan-mesh-profile-1] mesh-profile enable
[AC-wlan-mesh-profile-1] quit
(2)       配置无线服务模板
# 配置无线无线服务模板service1,配置SSIDmesh-network,并使能服务模板。
[AC] wlan service-template service1
[AC-wlan-st-service1] ssid mesh-network
[AC-wlan-st-service1] service-template enable
[AC-wlan-st-service1] quit
(3)       配置MPP
# 创建AP的模板,名称为mpp,型号名称选择WA4320i-ACN,并配置AP的序列号为210235A29G007C000020
[AC] wlan ap mpp model WA4320i-ACN
[AC-wlan-ap-mpp] serial-id 210235A29G007C000020
# Mesh Profile 1绑定到mppRadio 1口。
[AC-wlan-ap-mpp] radio 1
[AC-wlan-ap-mpp-radio-1] mesh-profile 1
# 配置射频类型为dot11n5GHz)。
[AC-wlan-ap-mpp-radio-1] type dot11an
# 配置射频工作信道为149
[AC-wlan-ap-mpp-radio-1] channel 149
# 开启Radio
[AC-wlan-ap-mpp-radio-1] radio enable
[AC-wlan-ap-mpp-radio-1] quit
# 配置MPP停止发送邻居探测请求。
[AC-wlan-ap-mpp] portal-service enable
[AC-wlan-ap-mpp] quit
(4)       配置MAP
# 创建AP的模板,名称为map1,型号名称选择WA4320i-ACN,并配置AP的序列号为210235A29G007C000050
[AC] wlan ap map1 model WA4320i-ACN
[AC-wlan-ap-map1] serial-id 210235A29G007C000050
# Mesh Profile 1绑定到map1Radio 1口。
[AC-wlan-ap-map1] radio 1
[AC-wlan-ap-map1-radio-1] mesh-profile 1
# 将无线服务模板service1绑定到map1Radio 1口。
[AC-wlan-ap-map1-radio-1] service-template service1
[AC-wlan-ap-map1-radio-1] type dot11an
# 配置射频工作信道为149
[AC-wlan-ap-map1-radio-1] channel 149
# MAP1的邻居白名单中添加MPPMAC地址,使MAP1仅与MPP建立Mesh连接,以避免环路的产生。
[AC-wlan-ap-map1-radio-1] mesh peer-mac-address 77a2-c25d-e316
# 开启射频功能。
[AC-wlan-ap-map1-radio-1] radio enable
[AC-wlan-ap-map1-radio-1] quit
[AC-wlan-ap-map1] quit
# 创建AP的模板,名称为map2,型号名称选择WA4320i-ACN,并配置AP的序列号为210235A29G007C000090
[AC] wlan ap map2 model WA4320i-ACN
[AC-wlan-ap-map2] serial-id 210235A29G007C000090
# Mesh Profile 1绑定到map2Radio 1口,并开启Radio
[AC-wlan-ap-map2] radio 1
[AC-wlan-ap-map2-radio-1] mesh-profile 1
# 将无线服务模板service1绑定到map2Radio 1口。
[AC-wlan-ap-map2-radio-1] service-template service1
[AC-wlan-ap-map2-radio-1] type dot11an
# 配置射频工作信道号为149
[AC-wlan-ap-map2-radio-1] channel 149
# MAP2的邻居白名单中添加MPPMAC地址,使MAP2仅与MPP建立Mesh连接,以避免环路的产生。
[AC-wlan-ap-map2-radio-1] mesh peer-mac-address 77a2-c25d-e316
# 开启射频功能。
[AC-wlan-ap-map2-radio-1] radio enable
[AC-wlan-ap-map2-radio-1] quit
[AC-wlan-ap-map2] quit
[AC] quit
# 完成以上配置后,在AC上可以通过display wlan mesh-link ap命令查看到MPPMAP 1MPPMAP 2Mesh链路已经成功建立。
<AC> display wlan mesh-link ap
AP Name: mpp
 Peer           Local          Status     RSSI Packets(Rx/Tx)
 4a9b-c5bb-e43f 77a2-c25d-e316 Forwarding 22   6058/1900
 a6b5-1c5a-22ff 77a2-c25d-e316 Forwarding 35   5354/1900
AP Name: map1
 77a2-c25d-e316 4a9b-c5bb-e43f Forwarding 22   1900/6058
AP Name: map2
 77a2-c25d-e316 a6b5-1c5a-22ff Forwarding 35   1900/5354
# 通过display wlan client命令可以查看到客户端成功的关联到了AP上。
<AC> display wlan client
Total number of clients: 1
MAC address    Username      AP name      RID  IP address                 VLAN ID
000f-e265-6400 N/A           mpp          1     1.1.1.1                   300
wlan mesh-policy mesh-cl 看典配里面这个策略是应该有配置相关参数的,可以参考一下。还有就是AP的位置是否合理。
ChanyiC 发表时间:2019-01-19
ap 的位置很近,有影响吗?
zhiliao_Jh2bR 发表时间:2019-01-19
有可能有影响,但是觉得还是配置上有些问题。可以看下刚才发的那个案例
