H3C S5120交换机神器的问题
2019-01-22提问
  • 1收藏,1425浏览
s5120交换机  做了一个链路合组 组设置为TRUNK 允许所有VLAN通过,然后把物理端口25 26口加到静态链路聚合组里。然后24口配置成ACESS口,这个口添加到VLAN 526里,接了个笔记本电脑。出现的故障是,26口会自己SHUTDOWN 然后DIS INT GI1/0/26显示是管理型关闭,如果在这个口执行UNDO SHUT 这个口链路会起来,然后24居然自动SHUTDOWN,如果24口执行UNDO SHUT 后26口又会SHUT唉,好神奇,请看下面附件中的配置吧
<AF-HJ>dis cu
 version 5.20, Release 2220P02
 sysname AF-HJ
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 domain default enable system
 telnet server enable
 undo ip http enable
 password-recovery enable
vlan 1
vlan 172
 description 监控
vlan 174
 description 广播
vlan 175
 description 一卡通
vlan 176
 description 消防
vlan 178
 description 青山系统
vlan 179
vlan 189
vlan 524
 description 雪场
vlan 526
 description 办公网
vlan 1712
vlan 2001
vlan 3001
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$QKliWyN4Ab1mTEdZMINO+L2IyDtbN4f6vlZyGg==
 service-type telnet
 stp enable
interface Bridge-Aggregation1
 port link-type trunk
 undo port trunk permit vlan 1
 port trunk permit vlan 2 to 4094
 stp disable
 dhcp-snooping trust
interface NULL0
interface Vlan-interface179
interface Vlan-interface3001
 ip address 100.100.1.253 255.255.255.0
 port trunk permit vlan 172 174 to 175 189 524 526 1712 2001 3001
 port trunk permit vlan 172 174 189 524 526 1712 2001 3001
 port trunk permit vlan 174 179 189 524 526 1712 2001 3001
interface GigabitEthernet1/0/4
 port trunk permit vlan 172 174 189 524 to 534 1712 2001 3001
interface GigabitEthernet1/0/5
 port trunk permit vlan all
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
 port access vlan 526
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
 shutdown
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
 shutdown
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
 shutdown
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
 shutdown
interface GigabitEthernet1/0/25
 port link-aggregation group 1
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
 shutdown
interface GigabitEthernet1/0/28
 shutdown
nqa entry imclinktopologypleaseignore ping
 type icmp-echo
  destination ip 100.100.1.252
  frequency 270000
 dhcp-snooping
 ip route-static 0.0.0.0 0.0.0.0 100.100.1.254
 undo info-center enable
 snmp-agent
 snmp-agent local-engineid 800063A203586AB14CC314
 snmp-agent community read hxcr
 snmp-agent community write hxcw
 snmp-agent community write shh123321
 snmp-agent sys-info version all
 snmp-agent target-host trap address udp-domain 10.52.9.200 params securityname shh123321 v2c
 nqa schedule imclinktopologypleaseignore ping start-time now lifetime 630720000
 load xml-configuration
user-interface aux 0
user-interface vty 0 4
 authentication-mode scheme
user-interface vty 5 15
return
<AF-HJ>int gi
<AF-HJ>sys
[AF-HJ]int gi 1/0/24
[AF-HJ-GigabitEthernet1/0/24]dis this
 shutdown
return
[AF-HJ-GigabitEthernet1/0/24]dis int gi
[AF-HJ-GigabitEthernet1/0/24]dis int GigabitEthernet 1/0/24
 GigabitEthernet1/0/24 current state: DOWN ( Administratively )
 IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 586a-b14c-c55b
 Description: GigabitEthernet1/0/24 Interface
 Loopback is not set
 Media type is twisted pair
 Port hardware type is  1000_BASE_T
 Flow-control is not enabled
 The Maximum Frame Length is 9216
 Broadcast MAX-ratio: 100%
 Unicast MAX-ratio: 100%
 Multicast MAX-ratio: 100%
 Allow jumbo frame to pass
 PVID: 526
 Mdi type: auto
 Port link-type: access
  Tagged   VLAN ID : none
  Untagged VLAN ID : 526
 Port priority: 0
 Last clearing of counters:  Never
 Peak value of input: 0 bytes/sec, at 00-00-00 00:00:00
 Peak value of output: 0 bytes/sec, at 00-00-00 00:00:00
 Last 300 seconds input:  0 packets/sec 0 bytes/sec -%
 Last 300 seconds output:  0 packets/sec 0 bytes/sec -%
 Input (total):  0 packets, 0 bytes
 Input (normal):  0 packets, 0 bytes
         0 CRC, 0 frame, 0 overruns, 0 aborts
         0 ignored, 0 parity errors
 Output (normal): 0 packets, 0 bytes
 Output: 0 output errors, 0 underruns, 0 buffer failures
         0 lost carrier, 0 no carrier
[AF-HJ-GigabitEthernet1/0/24]dis int GigabitEthernet 1/0/26
 GigabitEthernet1/0/26 current state: UP
 IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 586a-b14c-c55d
 Description: GigabitEthernet1/0/26 Interface
 Loopback is not set
 Media type is optical fiber,Port hardware type is 1000_BASE_LX_SFP
 1000Mbps-speed mode, full-duplex mode
 PVID: 1
 Mdi type: auto
 Port link-type: trunk
  VLAN passing  : 172, 174-176, 178-179, 189, 524, 526, 1712, 2001, 3001
  VLAN permitted: 2-4094
  Trunk port encapsulation: IEEE 802.1q
 Port priority: 0
 Peak value of input: 2035966 bytes/sec, at 2000-04-26 15:29:47
 Peak value of output: 14998575 bytes/sec, at 2000-04-26 15:30:17
 Last 300 seconds input:  6078 packets/sec 2008207 bytes/sec 2%
 Last 300 seconds output:  15769 packets/sec 14987146 bytes/sec 12%
 Input (total):  4974254 packets, 1552415041 bytes
         4837338 unicasts, 96107 broadcasts, 40809 multicasts, 0 pauses
 Input (normal):  4974254 packets, - bytes
         0 CRC, 0 frame, - overruns, 0 aborts
         - ignored, - parity errors
 Output (total): 12889118 packets, 12628348573 bytes
         12880145 unicasts, 7867 broadcasts, 1106 multicasts, 0 pauses
 Output (normal): 12889118 packets, - bytes
         0 lost carrier, - no carrier
zhiliao_VGmDf 知了小白
24 26口下面的设备是否形成了一个环路?
粉丝:9人 关注:4人
配置时候,有没有提示什么信息?
一些正常,没有错误提示
看了,没有什么问题。24口和26口没有什么关系。目前24都不是手工shutdown了吗 所以状态为down 26口up 也正常
网络迷途中de小糊涂 发表时间:2019-01-22
