SECPATH F100-C-G2 ipsec VPN的配置步骤以及如何故障检测(web方式)?
2019-01-29提问
  • 1收藏,1014浏览
VPN ipsec 策略再web页面配置生成后,还需配置其他的么? acl自动生成了。
如果和对端不通,要如何测试问题原因?
对端cisco设备
粉丝:26人 关注:2人
display ike sa
display ipsec sa
看看这两个的状态是否正常,确认是协商到第一还是第二阶段没有起来;
可以看下案例分析http://kms2.h3c.com/Search.aspx?keyword=ipsec
Process SA payload. *Jan 29 21:59:19:954 2019 H3C IKE/7/PACKET: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500 Check ISAKMP transform 1. *Jan 29 21:59:19:954 2019 H3C IKE/7/PACKET: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500 Lifetime type is 1. *Jan 29 21:59:19:954 2019 H3C IKE/7/PACKET: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500 Life duration is 28800. *Jan 29 21:59:19:954 2019 H3C IKE/7/PACKET: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500 Encryption algorithm is 3DES-CBC. *Jan 29 21:59:19:954 2019 H3C IKE/7/PACKET: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500 Authentication method is Pre-shared key. *Jan 29 21:59:19:954 2019 H3C IKE/7/PACKET: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500 HASH algorithm is HMAC-SHA1. *Jan 29 21:59:19:954 2019 H3C IKE/7/PACKET: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500 DH group is 2. *Jan 29 21:59:19:954 2019 H3C IKE/7/EVENT: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500 Pre-shared key matching address 101.95.170.98 not found. *Jan 29 21:59:19:954 2019 H3C IKE/7/ERROR: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500 No acceptable transform. *Jan 29 21:59:19:954 2019 H3C IKE/7/ERROR: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500 Failed to parse the IKE SA payload. *Jan 29 21:59:19:954 2019 H3C IKE/7/PACKET: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500 Construct notification packet: NO_PROPOSAL_CHOSEN. *Jan 29 21:59:19:954 2019 H3C IKE/7/PACKET: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500 Sending packet to 101.95.170.98 remote port 500, local port 500. *Jan 29 21:59:19:954 2019 H3C IKE/7/PACKET: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500 I-COOKIE: 6f2c8c487cb284b4 R-COOKIE: 0000000000000000 next payload: NOTIFY version: ISAKMP Version 1.0 exchange mode: Info flags: message ID: 0 length: 56 *Jan 29 21:59:19:954 2019 H3C IKE/7/PACKET: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500 Sending an IPv4 packet. *Jan 29 21:59:19:955 2019 H3C IKE/7/EVENT: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500 Sent data to socket successfully. *Jan 29 21:59:19:955 2019 H3C IKE/7/ERROR: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500 Failed to negotiate IKE SA. 能看下这报错怎么回事么?
zhiliao_uCOt0 发表时间:2019-01-29
1. 首先检查两端设备是否可以相互ping通,保证两端设备通信正常。 2. 检查两端设备配置是否一致,主要从感兴趣流、预共享密钥确认一致、ike算法确认一致。 3. 确认下两端设备出接口上是否有NAT业务,如果有NAT业务的话,流量会先匹配NAT模块走掉而不匹配IPSec,所以需要在NAT的acl中先配置rule deny掉感兴趣流。对于V5平台的设备就方便得多,可以在外网口配置ipsec no-nat-process enable这个命令来实现。
你猜猜看 发表时间:2019-01-30
zhiliao_uCOt0 知了小白
在二个阶段还没有建立起来的情况下,还要用通过debugging命令才排除故障。
