SECPATH F100-C-G2 ipsec VPN的配置问题
2019-01-29提问
  • 1收藏,1211浏览
与fortigate 100d 组IPsec VPN 报错信息如下,应该怎么配置?
不明白dst的是什么地址,根本没配置过这地址。
Process SA payload.
*Jan 29 21:59:19:954 2019 H3C IKE/7/PACKET: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500
Check ISAKMP transform 1.
  Lifetime type is 1.
  Life duration is 28800.
  Encryption algorithm is 3DES-CBC.
  Authentication method is Pre-shared key.
  HASH algorithm is HMAC-SHA1.
  DH group is 2.
*Jan 29 21:59:19:954 2019 H3C IKE/7/EVENT: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500
Pre-shared key matching address 101.95.170.98 not found.
*Jan 29 21:59:19:954 2019 H3C IKE/7/ERROR: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500
No acceptable transform.
Failed to parse the IKE SA payload.
Construct notification packet: NO_PROPOSAL_CHOSEN.
Sending packet to 101.95.170.98 remote port 500, local port 500.
  I-COOKIE: 6f2c8c487cb284b4
  R-COOKIE: 0000000000000000
  next payload: NOTIFY
  version: ISAKMP Version 1.0
  exchange mode: Info
  flags:
  message ID: 0
  length: 56
Sending an IPv4 packet.
*Jan 29 21:59:19:955 2019 H3C IKE/7/EVENT: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500
Sent data to socket successfully.
*Jan 29 21:59:19:955 2019 H3C IKE/7/ERROR: vrf = 0, src = 180.155.122.133, dst = 101.95.170.98/500
Failed to negotiate IKE SA.
<H3C>dis current-configuration
 version 7.1.064, Release 9510P06
 sysname H3C
context Admin id 1
 telnet server enable
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 1
nat address-group 1 name ÉÏÍøIP
 dhcp enable
 dhcp server forbidden-ip 172.16.1.1
 dhcp server forbidden-ip 172.16.1.2
 dhcp server forbidden-ip 172.16.1.3
 dhcp server forbidden-ip 172.16.1.4
 dhcp server forbidden-ip 172.16.1.5
 dhcp server forbidden-ip 172.16.1.6
 dhcp server forbidden-ip 172.16.1.7
 dhcp server forbidden-ip 172.16.1.8
 dhcp server forbidden-ip 172.16.1.9
 dhcp server forbidden-ip 172.16.1.10
 dhcp server forbidden-ip 172.16.1.11
 dhcp server forbidden-ip 172.16.1.12
 dhcp server forbidden-ip 172.16.1.13
 dhcp server forbidden-ip 172.16.1.14
 dhcp server forbidden-ip 172.16.1.15
 dhcp server forbidden-ip 172.16.1.16
 dhcp server forbidden-ip 172.16.1.17
 dhcp server forbidden-ip 172.16.1.18
 dhcp server forbidden-ip 172.16.1.20
 dhcp server forbidden-ip 172.16.1.21
 dhcp server forbidden-ip 172.16.1.22
 dhcp server forbidden-ip 172.16.1.23
 dhcp server forbidden-ip 172.16.1.24
 dhcp server forbidden-ip 172.16.1.25
 dhcp server forbidden-ip 172.16.1.26
 dhcp server forbidden-ip 172.16.1.27
 dhcp server forbidden-ip 172.16.1.28
 dhcp server forbidden-ip 172.16.1.29
 dhcp server forbidden-ip 172.16.1.30
 dhcp server forbidden-ip 172.16.1.31
 dhcp server forbidden-ip 172.16.1.32
 dhcp server forbidden-ip 172.16.1.33
 dhcp server forbidden-ip 172.16.1.34
 dhcp server forbidden-ip 172.16.1.35
 dhcp server forbidden-ip 172.16.1.36
 dhcp server forbidden-ip 172.16.1.37
 dhcp server forbidden-ip 172.16.1.38
 dhcp server forbidden-ip 172.16.1.39
 dhcp server forbidden-ip 172.16.1.40
 dhcp server forbidden-ip 172.16.1.41
 dhcp server forbidden-ip 172.16.1.42
 dhcp server forbidden-ip 172.16.1.43
 dhcp server forbidden-ip 172.16.1.44
 dhcp server forbidden-ip 172.16.1.45
 dhcp server forbidden-ip 172.16.1.46
 dhcp server forbidden-ip 172.16.1.47
 dhcp server forbidden-ip 172.16.1.48
 dhcp server forbidden-ip 172.16.1.49
 dhcp server forbidden-ip 172.16.1.50
 dhcp server forbidden-ip 172.16.1.189
 password-recovery enable
vlan 1
object-group ip address 172.16.45.0
object-group ip address 172.17.1.0
dhcp server ip-pool Users
 gateway-list 172.16.1.1
 network 172.16.1.0 mask 255.255.255.0
 dns-list 202.96.209.5 202.96.209.133
interface NULL0
interface Vlan-interface1
 ip address dhcp-alloc
interface GigabitEthernet1/0/0
 port link-mode route
 combo enable copper
 ip address 192.168.0.1 255.255.255.0
 combo enable copper
 ip address 180.155.122.133 255.255.255.248
 nat inbound 2000 address-group 1 no-pat
 nat outbound 2000
 ipsec apply policy GE1/0/1
 ip address 172.16.1.1 255.255.255.0
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
object-policy ip Any-Any
 rule 0 pass
security-zone name Local
security-zone name Trust
 import interface GigabitEthernet1/0/3
security-zone name DMZ
security-zone name Untrust
 import interface GigabitEthernet1/0/1
security-zone name Management
 import interface GigabitEthernet1/0/0
 import interface GigabitEthernet1/0/2
zone-pair security source Any destination Any
 object-policy apply ip Any-Any
 scheduler logfile size 16
line class aux
 user-role network-operator
line class console
 user-role network-admin
line class vty
line aux 0
line con 0
 authentication-mode scheme
line vty 0 4
line vty 5 63
 ip route-static 0.0.0.0 0 GigabitEthernet1/0/1 222.72.38.89
 ip route-static 0.0.0.0 0 GigabitEthernet1/0/1 180.155.122.134
 ssh server enable
acl basic 2000
 rule 0 permit
acl advanced name IPsec_GE1/0/1_IPv4_1
 rule 1 permit ip source 172.16.1.0 0.0.0.255 destination 172.16.45.0 0.0.0.255
 rule 2 permit ip source 172.16.45.0 0.0.0.255 destination 172.16.1.0 0.0.0.255
domain system
 aaa session-limit ftp 16
 aaa session-limit telnet 16
 aaa session-limit ssh 16
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 password hash $h$6$qjPPN+fk9eRPEEzw$j33KT873YXSuFn31t7hXNaZGNQiC1NIk54X+Z8wXQLD3egouKAn3zZt0x8SAMILnJhMrpI7xgT+f9f3nsl8pCQ==
 service-type ssh telnet terminal https
 authorization-attribute user-role level-3
ipsec transform-set GE1/0/1_IPv4_1
 esp encryption-algorithm 3des-cbc
 esp authentication-algorithm sha1
 pfs dh-group2
ipsec policy GE1/0/1 1 isakmp
 security acl name IPsec_GE1/0/1_IPv4_1
 local-address 180.155.122.133
 remote-address 116.239.16.209
 ike-profile GE1/0/1_IPv4_1
 sa duration time-based 28800
ike profile GE1/0/1_IPv4_1
 keychain GE1/0/1_IPv4_1
 local-identity address 180.155.122.133
 match remote identity address 116.239.16.209 255.255.255.0
 match local address GigabitEthernet1/0/1
 proposal 65535
ike proposal 65535
 dh group2
 sa duration 28800
 description GE1/0/1_IPv4_1
ike keychain GE1/0/1_IPv4_1
 pre-shared-key address 116.239.16.209 255.255.255.0 key cipher $c$3$kQzwjR67VpWjQ9aI2HO0MUkJMy2LeCadHg==
 ip https enable
inspect block-source parameter-profile ips_block_default_parameter
inspect block-source parameter-profile url_block_default_parameter
inspect capture parameter-profile ips_capture_default_parameter
inspect redirect parameter-profile av_redirect_default_parameter
inspect redirect parameter-profile ips_redirect_default_parameter
inspect redirect parameter-profile url_redirect_default_parameter
ips block-source parameter-profile ips_block_default_parameter
return
粉丝:12人 关注:1人
把没用的路由删掉
undo  ip route-static 0.0.0.0 0 GigabitEthernet1/0/1 180.155.122.134
 ipsec数据不要做nat
acl advanced 3999
 rule  deny ip source 172.16.1.0 0.0.0.255 destination 172.16.45.0 0.0.0.255
 rule  deny ip source 172.16.45.0 0.0.0.255 destination 172.16.1.0 0.0.0.255
 rule permit ip
interface GigabitEthernet1/0/1  //此修改会导致内网中断,谨慎操作
undo  nat inbound 2000 address-group 1 no-pat
undo  nat outbound 2000
nat outbound 3999
zhiliao_uCOt0 知了小白
对端的IP也有问题,我配置也没配好。可以通讯了,谢谢。
