SECPATH F100-C-G2 ipsec vpn连接建立了,但是无法通讯什么问题?
2019-01-30提问
  • 1收藏,1038浏览
<H3C>dis ike sa
    Connection-ID   Remote                Flag         DOI
    8095            140.206.97.82         RD           IPsec
Flags:
RD--READY RL--REPLACED FD-FADING RK-REKEY
<H3C>dis ipsec sa
  IPsec policy: GE1/0/1
  Sequence number: 1
  Mode: ISAKMP
    Tunnel id: 0
    Encapsulation mode: tunnel
    Perfect Forward Secrecy: dh-group2
    Inside VPN:
    Extended Sequence Numbers enable: N
    Traffic Flow Confidentiality enable: N
    Path MTU: 1444
    Tunnel:
        local  address: 180.165.126.126
        remote address: 140.206.97.82
    Flow:
        sour addr: 172.16.1.0/255.255.255.0  port: 0  protocol: ip
        dest addr: 172.16.45.0/255.255.255.0  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 3175925396 (0xbd4cc694)
      Connection ID: 21474836480
      Transform set: ESP-ENCRYPT-3DES-CBC ESP-AUTH-SHA1
      SA duration (kilobytes/sec): 1843200/28800
      SA remaining duration (kilobytes/sec): 1843200/28392
      Max received sequence-number: 0
      Anti-replay check enable: Y
      Anti-replay window size: 64
      UDP encapsulation used for NAT traversal: N
      Status: Active
    [Outbound ESP SAs]
      SPI: 3920204953 (0xe9a99499)
      Connection ID: 4294967297
      Max sent sequence-number: 0
      Status: Active
<H3C>dis ipsec statistics
  IPsec packet statistics:
    Received/sent packets: 0/0
    Received/sent bytes: 0/0
    Dropped packets (received/sent): 30/8
    Dropped packets statistics
      No available SA: 38
      Wrong SA: 0
      Invalid length: 0
      Authentication failure: 0
      Encapsulation failure: 0
      Decapsulation failure: 0
      Replayed packets: 0
      ACL check failure: 0
      MTU check failure: 0
      Loopback limit exceeded: 0
      Crypto speed limit exceeded: 0
<H3C>
<H3C>dis ipsec sa brief
Interface/Global          Dst Address       SPI         Protocol    Status
GE1/0/1                   140.206.97.82     3920204953  ESP         Active
GE1/0/1                   180.165.126.12    3175925396  ESP         Active
                          6
<H3C>
粉丝:12人 关注:0人
看着两个阶段都起来了,可以ping一下,然后在设备上看下会话,看收发包统计。
都是drop的包。这是为什么?对端的acl问题么? Dropped packets (received/sent): 30/8
zhiliao_uCOt0 发表时间:2019-01-30
粉丝:15人 关注:0人
看下地址是不是16.1和16.45段互访?
粉丝:8人 关注:0人
多半是感兴趣流的问题,看看这条流是否做了NAT,如果有需要先deny掉,
