H3C WX3024E+WA4320i-ACN能配套使用吗
2019-02-21提问
  • 1收藏,1092浏览
*************************************************************************** * * * H3C WA2620i-AGN BootWare, Version 2.07 * * * *************
如果能用 ap报错见下文最后一句
*************************************************************** Copyright (c) 2004-2013 Hangzhou H3C Technologies Co., Ltd. Compiled Date : May 14 2013 CPU Type : AR9350 CPU L1 Cache : 32KB CPU Clock Speed : 560MHz Memory Type : SDRAM Memory Size : 128MB BootWare Size : 512KB Flash Size : 32MB CPLD Version : 004 PCB Version : Ver.E BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa2600a_fit.bin! The main application file does not exist--flash:/wa2600a_fit.bin! Starting to get the backup application file--flash:/wa2600a_fat.bin! The backup application file does not exist--flash:/wa2600a_fat.bin! Starting to get the secure application file--flash:/wa2600a_fit.bin! The secure application file does not exist--flash:/wa2600a_fit.bin! Booting App fails! Trying to get the IP address from the DHCP server...... DHCP server's IP address is 192.168.3.252 Client's assigned address is 192.168.3.130 DNS domain name got from DHCP server is ×××.cn DNS server's IP address is 192.168.2.172 Default Gateway's IP address is 192.168.3.252 This client's subnet mask is 255.255.255.0 The length of option 43 is: 0 Change State : Idle to Broadcast Discovery Change State : Broadcast Discovery to Join get ac [H3C.×××××.cn]'s ip... Getting AC's IP Address 192.168.3.220 Change State : Unicast Discovery to Join Change State : Unicast discovery to Sulking Change State : Idle to Broadcast Discovery Change State : Broadcast Discovery to Join Change State : Unicast discovery to Sulking Can't download the image from network, please check the network settings The system will reboot
粉丝:40人 关注:3人
官网的版本说明书里有配套的FIT AP说明
官网的版本说明书 一搜一堆都不知道哪个是 能帮忙给个链接吗
zhiliao_TV0um 发表时间:2019-02-21
找你对应的AC,并且是对应的版本
Johnny囧尼 发表时间:2019-02-21
