H3C wa4320i-X 改FAT成功,但配置后手机不能连接。
2019-03-07提问
  • 1收藏,1336浏览
如题,手上的WA4320i-X 已改成FAT模式。配置后出现以下问题。
1、电脑可以连接,但连接后要等5分钟以上才可正常上网。
2、手机端不能连接,出现“连接超时”的提示。不能获取IP地址。
以下是设备连接图
wa4320i-X 的配置
[BEGIN] 2019/3/7 16:16:13
<WA4320i-X>dis cur
 version 5.20, Release 1509P03
 sysname WA4320i-X
 domain default enable system
 telnet server enable
 port-security enable
 password-recovery enable
 undo attack-defense tcp fragment enable
 vlan 1
radius scheme system
 primary authentication 127.0.0.1
 primary accounting 127.0.0.1
 key authentication cipher $c$3$ury4fg2znABvvtqOT0azA/Y/n40vjg==
 key accounting cipher $c$3$kDeYeEw3APOrfQF4U9MIRW++6vm0qw==
 accounting-on enable
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$OUhZ9Ml3zQvjU6uJIRKaccUWzaT1Gq3JIGOl0PI=
 authorization-attribute level 3
 service-type telnet
 service-type web
wlan rrm
 dot11a mandatory-rate 6 12 24
 dot11a supported-rate 9 18 36 48 54
 dot11b mandatory-rate 1 2
 dot11b supported-rate 5.5 11
 dot11g mandatory-rate 1 2 5.5 11
 dot11g supported-rate 6 9 12 18 24 36 48 54
wlan service-template 1 crypto
 ssid KT-H3C
 cipher-suite ccmp
 security-ie rsn
 service-template enable
cwmp
 undo cwmp enable
interface NULL0
nterface Vlan-interface1
 ip address 192.168.0.50 255.255.255.0
interface WLAN-BSS2
 port-security port-mode psk
 port-security tx-key-type 11key
 port-security preshared-key pass-phrase cipher $c$3$XKxBcji5GEAoyzqAS/WrRFu7a5pt2pHd2QsMIg==
interface WLAN-BSS32
 port-security preshared-key pass-phrase cipher $c$3$LurmFolY5jb8IzqtLRiiUhq36hPAPeHQougPpw==
interface WLAN-BSS33
 port link-type hybrid
 port hybrid vlan 1 untagged
interface WLAN-Radio1/0/1
interface WLAN-Radio1/0/2
 service-template 1 interface wlan-bss 2
 ip route-static 0.0.0.0 0.0.0.0 192.168.1.1
 arp-snooping enable
 load xml-configuration
 load tr069-configuration
 user-interface con 0
user-interface vty 0 4
 authentication-mode scheme
return
 [END] 2019/3/7 16:16:21
粉丝:2人 关注:0人
检查一下终端信号强度是否达标,接入后ping网关是否可通,如果可通的话和无线关系不大
