请问 MSR830-5BEI这个路由器
2019-03-08提问
  • 1收藏,968浏览
请问 MSR830-5BEI这个路由器之前客户帮忙做了双网静太路由,一条线是外网, 一条是党政外网,合并到一起的,党政网密码了10和59段跳转但是,现在有一个网站IP是59.44.104.90。这个IP本来就是在外网打开的,所以现在这个地址打不开,请大神帮帮忙,有需要可以补发路由配置文件,谢谢
CR98K 四段
两条外网合并到一起是什么意思呢,以及党政网密码了10和59段跳转但是,能否再详细描述一下问题,多谢
# version 7.1.064, Release 0605P13 # sysname ANKIT_ANUBHAV:0052 # clock timezone Lisbon add 00:00:00 clock protocol none # telnet server enable # ip pool aaa 100.19.0.2 100.19.0.20 ip pool aaa gateway 100.19.0.1 # ip load-sharing mode per-flow src-ip global # dhcp enable dhcp server always-broadcast # dns proxy enable # password-recovery enable # vlan 1 # dhcp server ip-pool lan1 gateway-list 133.133.133.1 network 133.133.133.0 mask 255.255.255.0 address range 133.133.133.2 133.133.133.254 dns-list 10.0.0.10 61.139.2.69 # policy-based-route test permit node 5 if-match acl 3010 apply next-hop 10.108.210.1 # controller Cellular0/0 # interface Aux0 # interface Dialer0 # interface Dialer1 # interface Dialer2 # interface Dialer3 # interface Dialer4 # interface Dialer5 # interface Dialer6 # interface Dialer7 # interface Dialer8 # interface Dialer1023 # interface Virtual-Template0 # interface Virtual-Template1 ppp authentication-mode chap domain system remote address pool aaa # interface NULL0 # interface Vlan-interface1 ip address 133.133.133.1 255.255.255.0 tcp mss 1280 ip policy-based-route test # interface GigabitEthernet0/0 port link-mode route description Double_Line1 bandwidth 50000 ip address 10.108.210.2 255.255.255.240 dns server 10.0.0.10 nat outbound # interface GigabitEthernet0/1 port link-mode route description Double_Line2 bandwidth 100000 ip address 220.166.78.227 255.255.255.128 dns server 61.139.2.69 nat outbound # interface GigabitEthernet0/2 port link-mode bridge # interface GigabitEthernet0/3 port link-mode bridge # interface GigabitEthernet0/4 port link-mode bridge # security-zone name Local # security-zone name Trust # security-zone name DMZ # security-zone name Untrust # security-zone name Management # scheduler logfile size 16 # line class aux user-role network-operator # line class console user-role network-admin # line class tty user-role network-operator # line class usb user-role network-operator # line class vty user-role network-operator # line aux 0 authentication-mode none user-role network-admin # line con 0 user-role network-admin # line vty 0 63 authentication-mode scheme user-role network-operator # ip route-static 0.0.0.0 0 GigabitEthernet0/0 10.108.210.1 preference 70 ip route-static 0.0.0.0 0 GigabitEthernet0/1 220.166.78.129 # acl advanced 3010 rule 160 permit ip destination 59.0.0.0 0.255.255.255 rule 165 permit ip destination 10.0.0.0 0.255.255.255 # domain system authentication ppp local # domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # local-user admin class manage password hash $h$6$VGjoy58cw8/0Xyoc$g52cvz33AocZ2nhoP8bfeZx3nYKbMLqAuJE8d6rV+4Ck8PVZwZjWVYfgo9plSwLYrgGuoBwGYscDYCiEzGe8pA== service-type telnet http authorization-attribute user-role network-admin # local-user system class network password cipher $c$3$ycEdHLaUA9v4ZYob/cabMhMRQaY3TFdM+A== service-type ppp authorization-attribute user-role network-operator # l2tp-group 1 mode lns allow l2tp virtual-template 1 undo tunnel authentication tunnel name LNS # l2tp enable # ip http enable # wlan global-configuration control-address disable # wlan ap-group default-group # cloud-management server domain oasis.h3c.com # return
zhiliao_45VUB 发表时间:2019-03-08
原来H3C的技术帮我设置的,
zhiliao_45VUB 知了小白
不是两条普通外网是一条外网一条党政外网,党政外网是静态路由跳转的10和59开始的段,但是现在发现在普通外网下面有一个59.44.104.90,这个IP是普通外网的,因为是59开始的,所以路由器自动就跳转到党政外网的线路去了,所以这个地址打不开,我就想把这个IP设置成例外的,不让它跳到党政外网去,在普通外网就能打开这个IP。知道我的意思了吗?
