MSG360配置微信连WIFI成功后,手机端搜不到SSID
2019-03-15提问
  • 1收藏,1506浏览
Reeady 零段
# version 7.1.064, Release 5221
# sysname H3C
 # clock timezone Beijing add 08:00:00 clock protocol ntp
# telnet server enable
# port-security enable
# dialer-group 1 rule ip permit
# ip redirects enable ip unreachables enable ip ttl-expires enable
# dhcp enable
# dns proxy enable
 dns server 222.88.88.88
 dns server 202.102.224.68
 dns server 114.114.114.114
 ip host H3C 10.2.23.254
 ip host lvzhoudev.h3c.com 139.217.22.254
 ip host oasis.h3c.com 139.217.27.153
 ip host oasisauth.h3c.com 139.217.11.74
 ip host oasisdev.h3c.com 139.217.27.118
 ip host oauthindev.h3c.com 192.168.0.100
ip host www.spiritapp-wlan-ac.h3c.com 192.168.0.100
# maintain enable
# module-proxy sample-description {"mode":"5","startTime":"10T00","endTime":"14T00","adjustTime":"2T00"}
# password-recovery enable
# vlan 1
 # vlan 100
# vlan 1000
# dhcp server ip-pool 100 gateway-list 172.16.100.1 network 172.16.100.0 mask 255.255.252.0 dns-list 172.16.100.1
# dhcp server ip-pool 1000 gateway-list 10.2.24.1 network 10.2.24.0 mask 255.255.252.0 dns-list 114.114.114.114 222.88.88.88
# nqa entry xiaobei test type http frequency 5000 history-record enable history-record number 1 probe timeout 500 url http://www.baidu.com
# nqa schedule xiaobei test start-time now lifetime forever
# wlan service-template st_8465558069165888 description 1 ssid qianlongcheng user-isolation enable akm mode psk preshared-key pass-phrase cipher $c$3$8GTe8g94IwjHQtVlM5evZsZVH8Xy1M+ctM3qhnaC cipher-suite ccmp cipher-suite tkip security-ie rsn security-ie wpa service-template enable
wechat description Free-WiFi
 ssid Qlc-WIFI vlan 1000 portal enable method direct portal domain cloud portal apply web-server wechat portal temp-pass period 20 enable service-template enable
# controller Cellular1/0/6
# interface Dialer1 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate nat outbound
# interface Dialer2 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate nat outbound
# interface Dialer3 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate nat outbound
# interface Dialer4 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate nat outbound
# interface Dialer5 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate nat outbound
# interface NULL0
 # interface Vlan-interface1 ip address 10.2.23.254 255.255.254.0 nat outbound
# interface Vlan-interface100 ip address 172.16.100.1 255.255.252.0
# interface Vlan-interface1000 ip address 10.2.24.1 255.255.252.0
 # interface GigabitEthernet1/0/1 port link-mode bridge
# interface GigabitEthernet1/0/2 port link-mode bridge
# interface GigabitEthernet1/0/3 port link-mode bridge
# interface GigabitEthernet1/0/4 port link-mode bridge port link-type trunk port trunk permit vlan all
# interface GigabitEthernet1/0/5 port link-mode bridge
# scheduler logfile size 16
# scheduler job Job_adjust command 1 wlan calibrate-channel pronto ap all
# scheduler schedule Schedule_adjust user-role network-admin job Job_adjust
# line class console user-role network-admin
 # line class vty user-role network-operator
# line con 0 authentication-mode scheme user-role network-admin
# line vty 0 31 authentication-mode scheme user-role network-operator
# ip route-static 0.0.0.0 0 Vlan-interface1 10.2.23.1
 # undo info-center logfile enable
# ssh server enable sftp server enable scp server enable
# nqa server enable
 # ntp-service enable ntp-service unicast-server ***.*** ntp-service unicast-server ***.***
# domain cloud authorization-attribute idle-cut 30 10240 authorization-attribute session-timeout 360 authentication portal none authorization portal none accounting portal none
# domain extend-auth authentication portal none authorization portal none accounting portal none
# domain system
# domain default enable system
# role name level-0 description Predefined level-0 role
# role name level-1 description Predefined level-1 role
# role name level-2 description Predefined level-2 role
# role name level-3 description Predefined level-3 role
# role name level-4 description Predefined level-4 role
# role name level-5 description Predefined level-5 role
# role name level-6 description Predefined level-6 role
 # role name level-7 description Predefined level-7 role
# role name level-8 description Predefined level-8 role
# role name level-9 description Predefined level-9 role
# role name level-10 description Predefined level-10 role
# role name level-11 description Predefined level-11 role
# role name level-12 description Predefined level-12 role
# role name level-13 description Predefined level-13 role
# role name level-14 description Predefined level-14 role
# user-group system
# local-user admin class manage password hash $h$6$7QRBo4elvzMhVVCs$YvMjjj50ExDjGYxP5CKlUjnlaSD+7lpIIye/+8+NRgw/MOfgBoJ2QsmUeU6UslhOFs09sRL9PtVzI3Slieanhg== service-type ssh telnet terminal http https authorization-attribute user-role network-admin
# portal host-check enable portal user log enable portal free-rule 1 destination ip 114.114.114.114 255.255.255.255 portal free-rule 2 destination ip any udp 53 portal free-rule 3 destination ip any tcp 53 portal free-rule 4 destination short.weixin.qq.com portal free-rule 5 destination mp.weixin.qq.com portal free-rule 6 destination long.weixin.qq.com portal free-rule 8 destination minorshort.weixin.qq.com portal free-rule 9 destination extshort.weixin.qq.com portal free-rule 10 destination szshort.weixin.qq.com portal free-rule 11 destination szlong.weixin.qq.com portal free-rule 12 destination szextshort.weixin.qq.com portal free-rule 13 destination ***.*** portal free-rule 19 destination isdspeed.qq.com portal free-rule 21 destination wifi.weixin.qq.com portal free-rule 22 destination oasisauth.h3c.com portal free-rule 2346257224 destination open.weixin.qq.com portal free-rule 2346257225 destination ip any tcp 5223 portal free-rule 2346257233 destination dns.weixin.qq.com portal free-rule 2346257241 destination long.open.weixin.qq.com portal free-rule 2346257242 destination res.wx.qq.com portal safe-redirect enable portal safe-redirect method get post portal safe-redirect user-agent Android portal safe-redirect user-agent CaptiveNetworkSupport portal safe-redirect user-agent MicroMessenger portal safe-redirect user-agent Mozilla portal safe-redirect user-agent WeChat portal safe-redirect user-agent iPhone portal safe-redirect user-agent micromessenger
# portal web-server 1 url http://192.168.0.100
# portal web-server cloud url http://oasisauth.h3c.com/portal/protocol captive-bypass ios optimize enable server-type oauth if-match user-agent CaptiveNetworkSupport redirect-url http://oasisauth.h3c.com/generate_404 if-match user-agent Dalvik/2.1.0(Linux;U;Android7.0;HUAWEI redirect-url http://oasisauth.h3c.com/generate_404 if-match original-url http://10.168.168.168 temp-pass if-match original-url http://captive.apple.com/hotspot-detect.html user-agent Mozilla temp-pass redirect-url http://oasisauth.h3c.com/portal/protocol if-match original-url http://www.apple.com user-agent Mozilla temp-pass redirect-url http://oasisauth.h3c.com/portal/protocol
 # portal web-server local-server url https://192.168.0.100/portal
# portal web-server lvzhou-server url http://lvzhou.h3c.com/portal/protocol server-type oauth
# portal web-server wechat url http://oasisauth.h3c.com/portal/protocol server-type oauth if-match user-agent CaptiveNetworkSupport redirect-url http://oasisauth.h3c.com/generate_404 if-match user-agent Dalvik/2.1.0(Linux;U;Android7.0;HUAWEI redirect-url http://oasisauth.h3c.com/generate_404 if-match original-url http://10.168.168.168 temp-pass if-match original-url http://captive.apple.com user-agent Mozilla temp-pass redirect-url http://oasisauth.h3c.com/portal/protocol if-match original-url ***.***/wifi/echo temp-pass redirect-url http://oasisauth.h3c.com/generate_404 if-match original-url http://www.apple.com user-agent Mozilla temp-pass redirect-url http://oasisauth.h3c.com/portal/protocol
 # portal local-web-server http # portal local-web-server https # portal extend-auth-server qq # portal extend-auth-server mail mail-protocol pop3 imap # ip http enable ip https enable # portal mac-trigger-server cloud binding-retry 2 interval 3 cloud-binding enable # wlan rrm calibration-power interval 30
 # wlan auto-ap enable wlan auto-persistent enable
# wlan global-configuration nas-id cm-0-598999-219801A0WCCIRFIRF1507
 # wlan ap-group default-group band-navigation disable vlan 1 ap-model SPM-X1-10 gigabitethernet 1 gigabitethernet 2 gigabitethernet 3 gigabitethernet 4 gigabitethernet 5 gigabitethernet 6 gigabitethernet 7 gigabitethernet 8 gigabitethernet 9 gigabitethernet 10 gigabitethernet 11 gigabitethernet 12 ap-model SPM-X1-24 gigabitethernet 1 gigabitethernet 2 gigabitethernet 3 gigabitethernet 4 gigabitethernet 5 gigabitethernet 6 gigabitethernet 7 gigabitethernet 8 gigabitethernet 9 gigabitethernet 10 gigabitethernet 11 gigabitethernet 12 gigabitethernet 13 gigabitethernet 14 gigabitethernet 15 gigabitethernet 16 gigabitethernet 17 gigabitethernet 18 gigabitethernet 19 gigabitethernet 20 gigabitethernet 21 gigabitethernet 22 gigabitethernet 23 gigabitethernet 24 ap-model WAP711H radio 1 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 ap-model WAP712C radio 1 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 radio 2 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 ap-model WAP712H radio 1 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 radio 2 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 ap-model WAP722 radio 1 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 radio 2 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 gigabitethernet 1 gigabitethernet 2 ap-model WAP722E radio 1 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 radio 2 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 gigabitethernet 1 gigabitethernet 2 ap-model WAP722E-W2 radio 1 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 radio 2 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 gigabitethernet 1 gigabitethernet 2 ap-model WAP722H radio 1 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 radio 2 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 ap-model WAP722S radio 1 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 radio 2 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 ap-model WAP722S-W2 radio 1 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 radio 2 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 gigabitethernet 1 ap-model WAP722X-W2 radio 1 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 radio 2 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 gigabitethernet 1 gigabitethernet 2 ap-model WAP723-W2 radio 1 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 radio 2 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 radio 3 radio enable service-template st_8465558069165888 bandwidth-guarantee enable bandwidth-guarantee service-template st_8465558069165888 percent 80 module 1 gigabitethernet 1 gigabitethernet 2
# wlan ap 01 model WAP722 serial-id 219801A0Q09177G00057 vlan 1 radio 1 channel 64 max-power 15 channel band-width 20 option client reject enable radio 2 channel 6 max-power 15 rate mandatory 11 rate multicast auto rate supported 12 18 24 36 48 54 rate disabled 1 2 5.5 6 9 gigabitethernet 1 gigabitethernet 2
 # wlan ap 02 model WAP722 serial-id 219801A0Q09177G000G9 vlan 1 radio 1 channel 36 max-power 15 channel band-width 20 option client reject enable radio 2 max-power 15 rate mandatory 11 rate multicast auto rate supported 12 18 24 36 48 54 rate disabled 1 2 5.5 6 9 gigabitethernet 1 gigabitethernet 2
# wlan ap 03 model WAP722 serial-id 219801A0Q09177G000KC vlan 1 radio 1 max-power 15 channel band-width 20 option client reject enable radio 2 channel 11 max-power 15 rate mandatory 11 rate multicast auto rate supported 12 18 24 36 48 54 rate disabled 1 2 5.5 6 9 gigabitethernet 1 gigabitethernet 2
# wlan ap 04 model WAP722 serial-id 219801A0Q09171G00352 vlan 1 radio 1 channel 64 max-power 15 channel band-width 20 option client reject enable radio 2 max-power 15 rate mandatory 11 rate multicast auto rate supported 12 18 24 36 48 54 rate disabled 1 2 5.5 6 9 gigabitethernet 1 gigabitethernet 2
# wlan ap 05 model WAP722 serial-id 219801A0Q09171G00427 vlan 1 radio 1 channel 36 max-power 15 channel band-width 20 option client reject enable radio 2 max-power 15 rate mandatory 11 rate multicast auto rate supported 12 18 24 36 48 54 rate disabled 1 2 5.5 6 9 gigabitethernet 1 gigabitethernet 2
 # cloud-management server domain oasis.h3c.com
# return
麻烦给看下MSG360的配置,其中配置的微信连WiFi,ssid名为Qlc-WIFI的无线,手机端搜索不到,请大神看下是哪里的问题
粉丝:23人 关注:2人
微信连wifi成功后搜不到ssid,是指的之前可以搜到但是微信连wifi成功以后就搜不到了?wifi断开?
手机搜索不到Qlc-WIFI这个无线,无法连接
Reeady 发表时间:2019-03-15
粉丝:48人 关注:4人
建议你以附件形式放出配置,这么连在一起根本没法判断。
附件上传不上去
