S5120 Series 如何重置
2019-03-20提问
  • 1收藏,975浏览
S5120 Series  如何重置成出厂设置?
无羡 四段
<H3C>reset saved-configuration
The saved configuration file will be erased. Are you sure? [Y/N]:Y  //确定删除保存的配置文件
<H3C>reboot
 Start to check configuration with next startup configuration file, please wait.........DONE!
 This command will reboot the device. Current configuration will be lost, save current configuration? [Y/N]:N  //不保存配置
This command will reboot the device. Continue? [Y/N]:Y   //继续重启
bootrom下删除配置文件也是可以的
