wap712c刷完胖ap文件后提示The image does not exist! Booting image fails! web无法访问 ping 192.168.0.50也拼不通
2019-03-24提问
  • 1收藏,2977浏览
问题现像同标题
粉丝:6人 关注:3人
先排除flash问题,内存自检正常。
再查看确认文件上传无误,大小也正确,但是无法设置文件属性,上传的文件也无法使用。这个时候排查一下BOOTWARE版本问题,发现之前AP的版本为V5的1507P06,现需要升级的版本为V5的1508P11,结果发现两个软件版本的BOOTWARE版本也不一样,需要先将BOOTWARE版本进行更换为和新版本一致后再升级软件版本。
具体操作步骤如下:
1.进入V5 AP的BOOTWARE,并用Ctrl+F格式化
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd.
Compiled Date       : Mar 27 2017
CPU Type            : ATHEROS AR9550
CPU L1 Cache        : 32KB
CPU Clock Speed     : 720MHz
Memory Type         : SDRAM
Memory Size         : 256MB
Memory Speed        : 560MHz
BootWare Size       : 512KB
Flash Size          : 32MB
CPLD Version        : 002
PCB Version         : Ver.C
=========================<EXTEND BOOTWAREMENU>========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+C: Display Copyright
Ctrl+Y: Change AP Mode
Ctrl+F: Format File System
Enter your choice(0-9):
Warning:All files on flash will be lost! Are you sure to format? [Y/N]Y.....
Format success.
2.进入APBOOTWARE下,通过网口传入apwtu430_v1.06.btw文件,提示
更新BOOTWARE版本的时候选择Y。
=========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash                                        |
|<1> Download Application Program To SDRAM And Run                         |
|<2> Update Main Application File                                          |
|<3> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
Enter your choice(0-3): 3
===================== ==<ETHERNET PARAMETERSET>========================
|Note:       '.' = Clear field.                                            |
|            '-' = Go to previous field.                                   |
|          Ctrl+D = Quit.                                                  |
Protocol (FTP or TFTP) :tftp tftp
Load File Name         :wa4300.ipe.ipe
                       : apwtu430_v1.06.btw
Target File Name       :wa4300.ipe.ipe
Server IP Address      :100.0.0.2 100.0.0.2
Local IP Address       :100.0.0.1 100.0.0.1
Gateway IP Address     :0.0.0.0
Enter your choice(0-3): 1
Loading.....................................................................
.......................Done!
16260096 bytes downloaded!
Extend BootWare Version is not equal,updating? [Y/N]
Updating Extend BootWare...........Done!
BootWare updated,System is rebooting now.
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing...................................
........Done!
3.进行软件版本的导入,方法同上,不再赘述。
==========================<Enter Ethernet SubMenu>==========================
|<1> Download Image Program To SDRAM And Run                               |
|<2> Update Main Image File                                                |
|<3> Update Backup Image File                                              |
|<4> Download Files(*.*)                                                   |
|<5> Modify Ethernet Parameter                                             |
Enter your choice(0-5): 2
不同的是升级软件版本文件这里的选项不一样。
4.重启,版本升级完成。
