MSR3610-X1 和 F100-M-SI的比较
  • 1收藏,1404浏览
1.以下是网络配置,这两个各设备哪个更好
2.求网络配置文档
display current-configuration
 version 5.20, Release 3733
 sysname JSLH-F1000
 l2tp enable
 l2tpmoreexam enable
 undo voice vlan mac-address 00e0-bb00-0000
 interzone policy default by-priority
 nat address-group 1
 domain default enable system
 telnet server enable
 qos carl 1 source-ip-address range
 qos carl 2 destination-ip-address range
 qos carl 3 source-ip-address range                           per-address
 qos carl 4 destination-ip-address range                   per-address
 qos carl 5 source-ip-address range                 per-address
 qos carl 6 destination-ip-address range                           per-address
 qos carl 7 source-ip-address range xx
 qos carl 8 destination-ip-address range xx
 ip http port 81
 undo alg dns
 undo alg rtsp
 undo alg h323
 undo alg sip
 undo alg sqlnet
 undo alg pptp
 undo alg ils
 undo alg nbt
 undo alg msn
 undo alg qq
 undo alg tftp
 undo alg sccp
 undo alg gtp
session synchronization enable
 password-recovery enable
acl number 3000
 rule 1 deny ip sourcexxxxxxdestination xxxxxxx
acl number 3100
 rule 5 permit ip sourcexxxxdestination xxxxxxxx
vlan 1
vlan 100
domain sxjr
 authentication ppp local
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
 ip pool 1 xxxxxxx
domain system
 state active
 idle-cut disable
 ip pool 1 xxxxxxxx
pki domain default
  crl check disable
ike peer peer
 pre-shared-key cipher $c$3$v7AqYdm2h+fjCSJgSqVE8V6u7avrg3F9EUI=
 remote-address xxxxx
ipsec transform-set 1
 encapsulation-mode tunnel
 transform esp
 esp authentication-algorithm sha1
 esp encryption-algorithm des
ipsec policy 1 10 isakmp
 security acl 3100
 ike-peer peer
 transform-set 1
 sa duration traffic-based 1843200
 sa duration time-based 3600
traffic classifier suidao operator and
 if-match acl 3100
traffic behavior suidao
 remark ip-precedence 7
 filter permit
qos policy suidao
 classifier suidao behavior suidao
user-group system
 group-attribute allow-guest
local-user JSLH08
 password cipher $c$3$glgq+XspbZFN/Y329PClU6rZ8idnAEvyqWkWYA==
 service-type ppp
local-user JSLH09
 password cipher $c$3$7jKGhMfteeUH3osXNVfUscHkmgD0ULhMx+Rr/Q==
 service-type ppp
local-user JSLH10
 password cipher $c$3$vcoxyGRHUU8XUkTO/jO+aoA/x2XO9pm3QpJGgg==
 service-type ppp
local-user admin
 password cipher $c$3$kLm3gLYIU4QcIkPLZR2k9Vm3bmrVR9w6ce6fuFI=
 authorization-attribute level 3
 service-type telnet
 service-type web
local-user dtjslh
 password cipher $c$3$JBCOgWEdBIGzYDYiAYieEPD15pqp6SEDYg==
 service-type ppp
l2tp-group 1
 allow l2tp virtual-template 1
 tunnel name LNS
l2tp-group 2
 allow l2tp virtual-template 2 remote TP-LINK_Router_TL-WVR300 domain sxjr
interface Virtual-Template1
 ppp authentication-mode chap domain system
 remote address pool 1
 ip address 192.168.10.1 255.255.255.0
interface Virtual-Template2
 ppp authentication-mode chap domain sxjr
 ip address 192.168.20.1 255.255.255.0
interface NULL0
interface GigabitEthernet0/0
 port link-mode route
 ip address 192.168.0.1 255.255.255.0
 qos car inbound carl 7 cir 4000 cbs 250000 ebs 0 green pass red discard
 qos car inbound carl 5 cir 2000 cbs 125000 ebs 0 green pass red discard
 qos car outbound carl 8 cir 4000 cbs 250000 ebs 0 green pass red discard
 qos car outbound carl 6 cir 2000 cbs 125000 ebs 0 green pass red discard
interface GigabitEthernet0/1
 description TO-hexin5700
 nat outbound 3000 address-group 1
 nat server protocol tcp global xxxxxxx
 ip address xxxxxxxxxxxx
 ip address xxxxxxxxxxxxxxxxxxxsub
 ip address xxxxxxxxxxxxxsub
 ip address xxxxxxxxxxxxxxxxxsub
 qos apply policy suidao inbound
 ipsec policy 1
interface GigabitEthernet0/11
interface GigabitEthernet0/2
 port link-mode bridge
 port access vlan 100
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
vd Root id 1
zone name Management id 0
 priority 100
 import interface GigabitEthernet0/0
zone name Local id 1
 priority 100
zone name Trust id 2
 priority 85
 import interface GigabitEthernet0/1
 import interface GigabitEthernet0/2 vlan 100
 import interface GigabitEthernet0/3 vlan 100
 import interface GigabitEthernet0/4 vlan 100
 import interface GigabitEthernet0/5 vlan 100
zone name DMZ id 3
 priority 50
zone name Untrust id 4
 priority 5
 import interface GigabitEthernet0/10
 import interface GigabitEthernet0/11
 import interface Virtual-Template1
 import interface Virtual-Template2
switchto vd Root
 ip virtual-reassembly
 zone name DMZ id 3
 interzone source Trust destination Untrust
  rule 0 permit
   source-ip any_address
   destination-ip any_address
   service any_service
   rule enable
 interzone source Untrust destination Trust
  rule 0 permit
   service any_service
   rule enable
 ip route-static 0.0.0.0 0.0.0.0 121.30.233.105
粉丝:36人 关注:1人
MSR3610-X1 路由器
F100-M-SI 防火墙
功能特性不一样,没有太大可比性,不过MSR3610的性能应该更强一些。
