我公司有一台S6506R的交换机,都不知道密码,我想恢复出厂设置,初始化掉,官方对这个设备没有保了。 哪位大哥能帮帮我,应该怎么弄?
2019-03-28提问
  • 1收藏,1213浏览
粉丝:4人 关注:0人
在65设备上有两种方式, 1.在BOOTROM菜单下,ctrl+p,删除启动文件中用户的console密码(同时会删除别的密码,具体请看下面步骤)     BOOT  MENU 1. Download application file  2. Select application file to boot 3. Display all files in flash 4. Delete file from flash 5 Modify bootrom password 0. Reboot Enter your choice(0-5):  Are you sure you want to delete the privileged level password? Yes or No (Y/N)y Flash:/ File Number      File Size(bytes)     File Name       ======================================================== 1.                       151            private-data.txt 2.                       978            vrpcfg.cfg 3.                       716            hostkey 4.                       572            serverkey 5(*).               11439439            s7500-cmw310-r3135p18.app 6.                  12549008            s6500-vrp310-f3045l01.app 7.                         4            snmpboots 8.                     12560            test.cfg 9.                      9373            cad.cfg 10.                   464225            diaginfo.txt 11.                  462749            n.txt Flash Free Space : 7662592 bytes The current application file is:    flash:/s7500-cmw310-r3135p18.app The backup boot file has not been selected. Please input the configuration file number :2 The file you selected is flash:/vrpcfg.cfg, Yes or No(Y/N)y The file flash:/vrpcfg.cfg is an sysname mode file. Deleting super password  Deleting aux0 password  Deleting the privileged level password ... The privileged level password has been deleted successfully!    2.在BOOTROM菜单下,ctrl+y,导出用户的配置之后删除启动文件重新启动,此方法需要tftp服务器     BOOT  MENU 1. Download application file  2. Select application file to boot 3. Display all files in flash 4. Delete file from flash  //导出文件之后删除启动文件 5. Modify bootrom password 0. Reboot Enter your choice(0-5):  Please set application file upload protocol parameter:  1. Set TFTP protocol parameter: 0. Return to boot menu Enter your choice(0-1): 1 Load File name           :S7500-CMW310-R3135P18.app   Switch IP address        :200.1.1.1   Server IP address        :200.1.1.2
