SECBLADE 防火墙板卡 端口映射问题?
2019-03-29提问
  • 1收藏,1210浏览
映射问题
映射后可以访问到内部的NVR 但是只能查看一半的摄像头信息,地址转换有无问题?
做了基于接口的和全局的两种 受不受影响?
两个地址转换
内部地址1:IP10.53.53.55 外部地址1:10.7.212.3
内部地址2:IP10.53.53.50 外部地址2:10.7.212.4
需求:外部用户通过访问外部地址达到访问内部NVR的需求。
防火墙配置
ip vpn-instance ZZBZX route-distinguisher 100:4000
 vpn-target 100:4000 export-extcommunity
 vpn-target 100:4000 import-extcommunity
acl number 3002
 rule 0 permit ip vpn-instance ZZBZX source 10.53.53.0 0.0.0.255
 rule 5 permit ip vpn-instance ZZBZX source 10.53.51.0 0.0.0.255
# interface Vlan-interface234
 nat outbound 3002
 nat server protocol tcp global 10.7.212.2 any vpn-instance ZZBZX inside 10.53.53.155 any vpn-instance ZZBZX
ip binding vpn-instance ZZBZX ip address 16.16.16.1 255.255.255.0
interface Vlan-interface235
 nat outbound static nat outbound 3002
nat server protocol tcp global 10.7.212.3 any vpn-instance ZZBZX inside 10.53.53.55 any vpn-instance ZZBZX
nat server protocol tcp global 10.7.212.4 any vpn-instance ZZBZX inside 10.53.51.50 any vpn-instance ZZBZX
 ip binding vpn-instance ZZBZX ip address 10.7.212.2 255.255.255.0
zone name zzbzx id 97 priority 1
 import interface Vlan-interface234
 import interface Vlan-interface235
 interzone source Any destination Any
 rule 0 permit
 source-ip any_address
 destination-ip any_address
 service any_service
 rule enable
 nat static 10.53.53.55 vpn-instance ZZBZX 10.7.212.3 vpn-instance ZZBZX
 nat static 10.53.51.50 vpn-instance ZZBZX 10.7.212.4 vpn-instance ZZBZX
需求是 外部用户通过访问外部地址达到访问内部NVR的话,用nat server 就好了
这个板卡具体型号是什么
vhuohuov 发表时间:2019-03-29
回复vhuohuov:
把全局的关掉吗?不关不是也不影响吗
zhiliao_zbrdc 发表时间:2019-03-29
