原有一台F5000,正常使用,现在加入一台F5020,因为网络环境的原因,坐冷备。测试时发现在F5020上并未学到ospf邻居,觉得是域间策略的问题。大神们帮忙看看域间策略哪里出了问题,指点指点。
(0)
接口加入安全域,并放通域间策略,具体的需要看配置
(0)
我有将相应的配置发出来的
这是5000上的vpn,ospf,以及相应的域间策略 # ip vpn-instance yibao description ***Ò½±£*** route-distinguisher 1000:1 vpn-target 1000:1 export-extcommunity vpn-target 1000:1 import-extcommunity # ip vpn-instance guahao description ***µçÐÅÔ¤Ô¼¹ÒºÅ*** route-distinguisher 2000:2 vpn-target 2000:2 export-extcommunity vpn-target 2000:2 import-extcommunity # ip vpn-instance weishengju description ***ÎÀÉú¾Ö*** route-distinguisher 3000:3 vpn-target 3000:3 export-extcommunity vpn-target 3000:3 import-extcommunity # ip vpn-instance nonghang description ***Å©ÒµÒøÐÐ*** route-distinguisher 4000:4 vpn-target 4000:4 export-extcommunity vpn-target 4000:4 import-extcommunity # ip vpn-instance internal description ***ÄÚÍø*** route-distinguisher 10000:1 vpn-target 10000:1 export-extcommunity vpn-target 10000:1 import-extcommunity # ip vpn-instance caizheng description "caizheng" route-distinguisher 5000:5 vpn-target 5000:5 export-extcommunity vpn-target 5000:5 import-extcommunity # ospf 1 router-id 192.160.3.238 vpn-instance yibao area 0.0.0.0 network 192.160.3.224 0.0.0.15 network 192.159.13.0 0.0.0.255 network 192.69.2.0 0.0.0.255 # ospf 2 router-id 172.16.50.2 vpn-instance nonghang vpn-instance-capability simple area 0.0.0.0 network 172.16.50.0 0.0.0.3 network 192.168.20.0 0.0.0.3 # ospf 3 router-id 172.16.8.2 vpn-instance internal area 0.0.0.0 network 192.168.99.0 0.0.0.255 network 172.16.8.0 0.0.0.3 # vd Root id 1 vd yibao id 2 allocate interface Vlan-interface250 allocate interface Vlan-interface251 allocate interface Vlan-interface252 allocate vlan 250 to 252 vd guahao id 3 allocate interface Vlan-interface253 allocate interface Vlan-interface255 allocate vlan 253 255 vd weishengju id 4 allocate interface Vlan-interface256 allocate interface Vlan-interface629 allocate vlan 256 629 vd nonghang id 5 allocate interface Vlan-interface150 allocate interface Vlan-interface257 allocate vlan 150 257 vd internal id 6 allocate interface Vlan-interface11 allocate interface Virtual-Template0 allocate interface Virtual-Template1 allocate vlan 11 vd caizheng id 7 allocate interface Vlan-interface258 allocate interface Vlan-interface259 allocate vlan 258 to 259 # zone name Management id 0 priority 100 import interface GigabitEthernet0/0 zone name Local id 1 priority 100 zone name Trust id 2 priority 85 import interface GigabitEthernet0/4 vlan 1 to 10 13 to 149 151 to 187 189 to 249 254 260 to 628 630 to 4094 import interface Vlan-interface10 import interface Vlan-interface100 zone name DMZ id 3 priority 50 zone name Untrust id 4 priority 5 import interface GigabitEthernet0/1 import interface GigabitEthernet0/3 import interface Vlan-interface9 import interface Vlan-interface188 import interface Vlan-interface189 import interface Vlan-interface261 switchto vd yibao zone name yibaotrust id 1 priority 85 import interface Vlan-interface250 zone name yibaountrust id 2 priority 5 import interface Vlan-interface251 import interface Vlan-interface252 switchto vd guahao zone name guahaotrust id 1 priority 85 import interface Vlan-interface255 zone name guahaountrust id 2 priority 5 import interface Vlan-interface253 switchto vd weishengju zone name weishengjutrust id 1 priority 85 import interface Vlan-interface256 zone name weishengjuuntrust id 2 priority 5 import interface Vlan-interface629 switchto vd nonghang zone name nonghangtrust id 1 priority 85 import interface Vlan-interface150 zone name nonghanguntrust id 2 priority 5 import interface GigabitEthernet0/10 vlan 150 257 import interface Vlan-interface257 switchto vd internal zone name internaltrust id 1 priority 85 import interface Vlan-interface11 import interface Virtual-Template0 zone name internaluntrust id 2 priority 5 switchto vd caizheng zone name trust id 1 priority 85 import interface Vlan-interface259 zone name untrust id 2 priority 5 import interface Vlan-interface258 switchto vd Root object network subnet 122.244.55.154/0.0.0.7 subnet 122.244.55.154 0.0.0.7 object network subnet 172.17.70.2/0.0.0.0 subnet 172.17.70.2 0.0.0.0 object network subnet 192.168.0.0/0.0.0.255 subnet 192.168.0.0 0.0.0.255 object network subnet 192.168.1.222/0.0.0.0 subnet 192.168.1.222 0.0.0.0 object network subnet 192.168.2.9/0.0.0.0 subnet 192.168.2.9 0.0.0.0 zone name Management id 0 ip virtual-reassembly zone name Local id 1 ip virtual-reassembly zone name Trust id 2 ip virtual-reassembly zone name DMZ id 3 ip virtual-reassembly zone name Untrust id 4 ip virtual-reassembly interzone source Trust destination Untrust session log enable acl 3001 interzone source Untrust destination Trust rule 0 permit source-ip any_address destination-ip any_address service any_service rule enable switchto vd yibao zone name yibaotrust id 1 ip virtual-reassembly zone name yibaountrust id 2 ip virtual-reassembly switchto vd guahao zone name guahaotrust id 1 ip virtual-reassembly zone name guahaountrust id 2 ip virtual-reassembly switchto vd weishengju zone name weishengjutrust id 1 ip virtual-reassembly zone name weishengjuuntrust id 2 ip virtual-reassembly switchto vd nonghang zone name nonghangtrust id 1 ip virtual-reassembly zone name nonghanguntrust id 2 ip virtual-reassembly interzone source nonghanguntrust destination nonghangtrust switchto vd internal zone name internaltrust id 1 ip virtual-reassembly zone name internaluntrust id 2 ip virtual-reassembly switchto vd caizheng zone name trust id 1 ip virtual-reassembly zone name untrust id 2 ip virtual-reassembly #
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
