S5500配置问题
2019-04-16提问
  • 1收藏,948浏览
公司原有一台交换机供内部使用,新接一条专线,运营商提供172.106.4.2/30 给本地使用,因要访问其它IP,172.106.4.10-14,在本地交换机上做了一些配置之后,只可以在交换机里面PING通172.106.4.10,在台式机上无法访问。
interface NULL0
interface Vlan-interface100
 ip address 10.23.121.2 255.255.255.252
interface Vlan-interface101
 ip address 10.23.121.129 255.255.255.248
interface Vlan-interface102
 ip address 10.23.121.145 255.255.255.240
interface Vlan-interface103
 ip address 10.23.121.161 255.255.255.224
interface Vlan-interface104
 ip address 10.23.121.225 255.255.255.240
interface Vlan-interface105
 ip address 10.23.121.201 255.255.255.248
interface Vlan-interface106
 ip address 10.23.121.209 255.255.255.248
interface Vlan-interface107
 ip address 10.23.121.217 255.255.255.248
interface Vlan-interface108
 ip address 172.106.4.2 255.255.255.252
 port link-mode bridge
 port access vlan 100
 port access vlan 101
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
 port access vlan 102
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
 port access vlan 103
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
 port access vlan 104
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
 port access vlan 105
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
 port access vlan 106
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
 port access vlan 107
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
 port access vlan 108
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
 shutdown
interface GigabitEthernet1/0/50
 shutdown
interface GigabitEthernet1/0/51
 shutdown
interface GigabitEthernet1/0/52
 shutdown
 ip route-static 0.0.0.0 0.0.0.0 10.23.121.1
 ip route-static 172.106.4.0 255.255.255.0 172.106.4.1 preference 59
 load xml-configuration
-6219 七段
粉丝:2人 关注:0人
台式机的网关是在SW2上吗?172.106.4.0网段的网关在SW1上是吗?
检查一下SW1上有没有到10网段的路由,下一跳指向SW2
另外:  ip route-static 0.0.0.0 0.0.0.0 10.23.121.1,这条默认路由指向下联PC的意义是什么?
zhiliao_nCf3q 知了小白
台式机网关是在SW2上面,172.106.4.0的网段网关是SW1上面,那个0.0.0.0这条路由其实指向的是一层交换机,画错了。SW1上面没做10.23.121.0/24 这条路由。不知道下一跳应该怎么写,
ip route-static 10.23.121.0 24 172.106.4.2 这样写就可以了~可以评论我的回答哈~不然我不点到这个问题,就看不到你的评论啦~
-6219 发表时间:2019-04-16
