S5120交换机无法自动分配地址
2019-04-28提问
  • 1收藏,1490浏览
Reeady 零段
交换机做网关,设置两个网段,10.2.23.0,10.2.22.0,其中23网段为手工配置静态地址,22网段为动态分配,目前故障为手工配置23网段可以上网,无法自动获取22网段地址 ,配置如下:
vlan 1#vlan 23#vlan 222#domain ****** access-limit disable state active idle-cut disable self-*******-url disable#dhcp ****** ip-pool 23 network 10.2.22.0 mask 255.255.254.0 gateway-list 10.2.23.1 dns-list 114.114.114.114 8.8.8.8#dhcp ****** ip-pool h3c network 10.2.23.0 mask 255.255.255.0 gateway-list 10.2.23.1#user-group ******#local-user ***** password cipher $c$3$GGi4KFbr0cTs1NcVzydb2UVLRgrKK9l/ authorization-attribute l***l 3 *******-type ssh telnet terminal *******-type web#inte***ce NULL0#inte***ce Vlan-inte***ce1#inte***ce Vlan-inte***ce23 ip address 10.2.23.1 255.255.254.0#inte***ce Vlan-inte***ce222 ip address 2.2.2.2 255.255.255.0#inte***ce GigabitEthernet1/0/1 port access vlan 23#inte***ce GigabitEthernet1/0/2 port access vlan 23#inte***ce GigabitEthernet1/0/3 port access vlan 23#inte***ce GigabitEthernet1/0/4 port access vlan 23#inte***ce GigabitEthernet1/0/5 port access vlan 23#inte***ce GigabitEthernet1/0/6 port access vlan 23#inte***ce GigabitEthernet1/0/7 port access vlan 23#inte***ce GigabitEthernet1/0/8 port access vlan 23#inte***ce GigabitEthernet1/0/9 port access vlan 23#inte***ce GigabitEthernet1/0/10 port access vlan 23#inte***ce GigabitEthernet1/0/11 port access vlan 23#inte***ce GigabitEthernet1/0/12 port access vlan 23#inte***ce GigabitEthernet1/0/13 port access vlan 23#inte***ce GigabitEthernet1/0/14 port access vlan 23#inte***ce GigabitEthernet1/0/15 port access vlan 23#inte***ce GigabitEthernet1/0/16 port access vlan 23#inte***ce GigabitEthernet1/0/17 port access vlan 23#inte***ce GigabitEthernet1/0/18 port access vlan 23#inte***ce GigabitEthernet1/0/19 port access vlan 23#inte***ce GigabitEthernet1/0/20 port access vlan 23#inte***ce GigabitEthernet1/0/21 port access vlan 23#inte***ce GigabitEthernet1/0/22#inte***ce GigabitEthernet1/0/23 port access vlan 23#inte***ce GigabitEthernet1/0/24 port access vlan 222#inte***ce GigabitEthernet1/0/25#inte***ce GigabitEthernet1/0/26#inte***ce GigabitEthernet1/0/27#inte***ce GigabitEthernet1/0/28# dhcp-snooping# ip route-static 0.0.0.0 0.0.0.0 2.2.2.1# dhcp ****** forbidden-ip 10.2.23.2 10.2.23.254# dhcp enable# load tr069-configuration#user-inte***ce aux 0 authentication-mode schemeuser-inte***ce vty 0 15 authentication-mode scheme user privilege l***l 3 set authentication password cipher $c$3$Lqi4zngoKWceKbfU4F1T2jKpXSGr5U9f protocol inbound telnet
V 八段
粉丝:9人 关注:0人
这个配置粘贴的有点乱....
而且我看vlan是vlan222,不是vlan22
1、看下是否配置dhcp enable
2、dhcp下面配置网段是否正确
3、网关地址有无up
4、建议电脑直连交换机测试
5、接电脑的接口关闭stp功能
VLAN222是与路由上VLAN做的trunk,交换机上只设了VLAN23,之前是工程师给这么配置的,可以实现22网段自动获取,23网段手工分配,现在不知道配置哪里出了问题,无法自动获取地址
Reeady 发表时间:2019-04-28
设备上没有配置vlan22的话,那哪个设备做dhcp server呢?
V 发表时间:2019-04-28
dhcp ****** ip-pool 23 network 10.2.22.0 mask 255.255.254.0 gateway-list 10.2.23.1 dns-list 114.114.114.114 8.8.8.8#dhcp ****** ip-pool h3c network 10.2.23.0 mask 255.255.255.0 gateway-list  核心交换上做的DHCP ******
# dhcp ****** ip-pool 23 network 10.2.22.0 mask 255.255.254.0 gateway-list 10.2.23.1 dns-list 114.114.114.114 8.8.8.8 # dhcp ****** ip-pool h3c network 10.2.23.0 mask 255.255.255.0 gateway-list 10.2.23.1 # user-group ****** # local-user ***** password cipher $c$3$GGi4KFbr0cTs1NcVzydb2UVLRgrKK9l/ authorization-attribute l***l 3 *******-type ssh telnet terminal *******-type web
那核心交换机和接入交换互连的接口有放通vlan吗?
V 发表时间:2019-04-28
464391869能否加一下我的qq远程协助下,特别着急
这个加不了哦~ 建议确认核心交换机和接入交换机互连接口需要放通vlan 22
V 发表时间:2019-04-28
1-21端口都为VLAN23的端口
具体怎么操作
不是vlan22要自动获取地址吗,那需要接入和核心互连接口放通vlan 22 ,终端接接入的接口也要划分vlan22才行
V 发表时间:2019-04-28
可是之前的工程师只给我们配了一个VLAN23,可以实现,怎么可以只配一个VLAN23就实现22网段自动分配,23网段手工静态呢
只配vlan23肯定不行,除非终端接在核心交换机上
V 发表时间:2019-04-28
怎么删除dhcp ****** ip-pool
前面加undo undo dhcp Server IP-pool 名字
V 发表时间:2019-04-28
删掉了原来的dhcp ****** IP-pool,重新配置之后恢复正常了
Reeady 发表时间:2019-04-29
Reeady 知了小白
