H3C MSR 20-12 双路由可以配置主备吗?
  • 1收藏,1091浏览
我们公司通过数字专线用双路由;使用配置了双路由后,部分文档图片无法发送,单独使用一条线路都能正常发送。请大神帮看一下什么原因,感谢!
一台配置如下:
 version 5.20, Release 2511P02
 sysname SN-JSHA-700V-WAN-ARU-YD
 undo password-control aging enable
 firewall enable # domain default enable system
 router id 172.17.112.14 # telnet server enable
 dar p2p signature-file flash:/p2p_default.mtd
 port-security enable
 password-recovery enable
acl number 3000
 rule 0 permit ip destination 192.168.100.0 0.0.0.255
 rule 5 permit ip destination 192.168.118.0 0.0.0.255
 rule 10 permit ip destination 192.168.122.0 0.0.0.255
 rule 15 deny ip rule 25 permit ip acl number 3001
 rule 0 deny ip destination 192.168.100.0 0.0.0.255
 rule 5 deny ip destination 192.168.118.0 0.0.0.255
 rule 10 deny ip destination 192.168.122.0 0.0.0.255
 rule 25 permit ip acl number 3002
rule 10 deny tcp destination-port eq 445
rule 20 deny udp destination-port eq 445
 rule 25 permit ip
vlan 1
 domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
 traffic classifier B operator and
 if-match acl 3001
traffic classifier P operator and
 if-match acl 3000
 traffic behavior B
 queue af bandwidth 7168
 traffic behavior P
 queue af bandwidth 3072
qos policy POS&BG
 classifier P behavior P
 classifier B behavior B
qos policy PolicyLimit
user-group system
 group-attribute allow-guest
 local-user JSHA-XYSHGC-DX
 local-user admin
 password cipher $c$3$==
 authorization-attribute level 3
 service-type ssh telnet
 service-type web password-control length 4
 password-control composition type-number 1
 cwmp
 undo cwmp enable
controller E1 0/0
 interface Aux0
 async mode flow
 link-protocol ppp
 interface Cellular0/0
 async mode protocol
 link-protocol ppp
 firewall packet-filter 4999 outbound
 interface Ethernet0/0
 port link-mode route
 ip address 172.17.12.252 255.255.255.0
 ip address 172.17.12.252 255.255.255.0 sub
 ospf network-type broadcast
 vrrp vrid 1 virtual-ip 172.17.12.254
 vrrp vrid 2 virtual-ip 172.17.12.254
 vrrp vrid 3 virtual-ip 172.17.12.254
interface Ethernet0/1
 qos max-bandwidth 4000
 ip address 172.17.112.14 255.255.255.252
 ospf cost 1000
 qos reserved-bandwidth pct 100
 qos lr outbound cir 4000 cbs 125000 ebs 0
 qos flow-interval 1
 qos gts acl 3020 cir 300 cbs 18750 ebs 0 queue-length 50
undo ip fast-forwarding
 interface NULL0
 interface Vlan-interface1
 interface Ethernet0/2
 port link-mode bridge
interface Ethernet0/3
 interface Ethernet0/4
ospf 100
 peer 172.17.112.13
 area 0.0.2.5
 network 172.17.112.12 0.0.0.3
 network 172.17.12.0 0.0.0.255
 nssa
voice-setup
 sip
 sip-server
 call-rule-set
 call-route
 dial-program
 aaa-client
 gk-client
 snmp-agent
 snmp-agent local-engineid 800063A20370F96D1A8940
 snmp-agent community read suning1
 snmp-agent sys-info version v2c v3
 undo snmp-agent trap enable voice dial
 ssh server enable
 ssh server authentication-timeout 30
 ssh user admin service-type stelnet authentication-type password
 load xml-configuration
 load tr069-configuration
 user-interface tty 12
 user-interface aux 0
 authentication-mode password
set authentication password cipher $c$3$wg= =
user-interface vty 0 4
 authentication-mode scheme
 user privilege level 3
 set authentication password cipher $c$3$nQ= = idle-timeout 100 0
 return
另外一台配置为:
 sysname SN-JSHA-700V-WAN-ARU-DX
acl number 3000
 rule 25 permit ip
vlan 1
 domain system
 state active
 idle-cut disable
 if-match acl 3001
 if-match acl 3000
 traffic behavior B
 traffic behavior P
qos policy POS&BG
user-group system
 local-user admin
 cwmp
 undo cwmp enable
controller E1 0/0
 interface Aux0
 async mode flow
 link-protocol ppp
 async mode protocol
 link-protocol ppp
 ip address 172.17.12.253 255.255.255.0
 ip address 172.17.12.253 255.255.255.0 sub
 ospf cost 1000
 qos flow-interval 1
 interface NULL0
ospf 100
 peer 172.17.112.13
 area 0.0.2.5
 nssa
voice-setup
 sip
 sip-server
 call-rule-set
 call-route
 dial-program
 aaa-client
 gk-client
 snmp-agent
 ssh server enable
 return
Cookie 七段
粉丝:6人 关注:3人
检查一下路由表,是不是存在来回路径不一致的情况
