F1060配置拨号上网后,网速变的越来越慢
2017-12-08提问
  • 1收藏,1793浏览
防火墙接了三根外线,一根是无线两根是拨号,单独一根无线上网没有任何问题,但是单独任意一根拨号上网,网速开始时正常,后来渐渐的变的越来越慢,是配置拨号时要注意什么吗?
policy-based-route dianxinbohao108-111 permit node 10
 if-match acl 3000
 apply output-interface Dialer1
policy-based-route dianxinbohao108-111 permit node 20
 if-match acl 3001
 apply output-interface GigabitEthernet1/0/2
 apply output-interface Dialer2
policy-based-route dianxinbohao108-111 permit node 30
 if-match acl 3003
 apply output-interface GigabitEthernet1/0/3
interface Dialer1
 ppp chap password cipher $c$3$C+QDS/Fwb4fme0JuDik+ZiRFTVgr85bRIvDF
 ppp chap user 123456
 ppp pap local-user ad79626374 password cipher $c$3$v9sqG459FhB4juZHVoHah9Y6A9TKbh8wfcOC
 dialer bundle enable
 dialer-group 1
 dialer timer idle 0
 ip address ppp-negotiate
 nat outbound 2000
interface Dialer2
 ppp chap password cipher $c$3$ktB/vjGPNEH9o16ZETT8NZ69GB8dq1trWTV6
 ppp chap user 654321
 ppp pap local-user ad79626774 password cipher $c$3$zIACxmvAQJGawbHKFWWpr2v/CtHCqWSPqCM=
 dialer-group 2
 dialer timer idle 0
 nat outbound 2000
 port link-mode route
 pppoe-client dial-bundle-number 1
 pppoe-client dial-bundle-number 2
 ip address 222.72.41.106 255.255.255.252
 nat outbound 2000
interface GigabitEthernet1/0/15
 ip address 10.0.0.65 255.255.255.248
 ip policy-based-route dianxinbohao108-111
object-policy ip Any-Any
 rule 0 pass
object-policy ip Untrust-Local
 rule 0 pass
object-policy ip av
 rule 0 inspect av
object-policy ip ips
 rule 0 inspect ips
security-zone name Local
security-zone name Trust
 import interface GigabitEthernet1/0/14
 import interface GigabitEthernet1/0/15
security-zone name DMZ
security-zone name Untrust
 import interface Dialer1
 import interface GigabitEthernet1/0/2
 import interface GigabitEthernet1/0/3
 import interface GigabitEthernet1/0/4
 import interface GigabitEthernet1/0/5
security-zone name Management
 import interface GigabitEthernet1/0/0
zone-pair security source Any destination Any
 object-policy apply ip Any-Any
zone-pair security source Untrust destination Local
 object-policy apply ip Untrust-Local
 scheduler logfile size 16
line class aux
 user-role network-operator
line class console
 authentication-mode scheme
 user-role network-admin
line class vty
line aux 0
line con 0
line vty 0 63
 ip route-static 0.0.0.0 0 Dialer1
 ip route-static 0.0.0.0 0 Dialer2
 ip route-static 0.0.0.0 0 222.72.41.105
 ip route-static 10.0.1.0 24 10.0.0.66
 ip route-static 10.0.2.0 24 10.0.0.66
 ip route-static 10.0.3.0 24 10.0.0.66
 ip route-static 10.0.4.0 24 10.0.0.66
 ip route-static 10.0.5.0 24 10.0.0.66
 ip route-static 10.0.6.0 24 10.0.0.66
 ip route-static 10.0.7.0 24 10.0.0.66
 ip route-static 10.0.8.0 24 10.0.0.66
 ip route-static 10.0.9.0 24 10.0.0.66
 ip route-static 10.0.10.0 24 10.0.0.66
 ip route-static 10.0.11.0 24 10.0.0.66
 ip route-static 10.0.12.0 24 10.0.0.66
 ip route-static 10.0.13.0 24 10.0.0.66
 ip route-static 10.0.14.0 24 10.0.0.66
 ip route-static 10.0.15.0 24 10.0.0.66
 ip route-static 10.0.16.0 24 10.0.0.66
 ip route-static 10.0.20.0 23 10.0.0.66
 ip route-static 10.0.32.0 22 10.0.0.66
 ssh server enable
acl basic 2000
 rule 0 permit
acl advanced 3000
 rule 0 permit ip source 10.0.8.0 0.0.0.255
 rule 5 permit ip source 10.0.9.0 0.0.0.255
 rule 10 permit ip source 10.0.10.0 0.0.0.255
 rule 15 permit ip source 10.0.11.0 0.0.0.255
acl advanced 3001
 rule 0 permit ip source 10.0.12.0 0.0.0.255
 rule 5 permit ip source 10.0.14.0 0.0.0.255
 rule 15 permit ip source 10.0.13.0 0.0.0.255
acl advanced 3002
 rule 0 permit ip source 10.0.1.0 0.0.0.255
 rule 5 permit ip source 10.0.2.0 0.0.0.255
 rule 10 permit ip source 10.0.3.0 0.0.0.255
 rule 15 permit ip source 10.0.4.0 0.0.0.255
 rule 20 permit ip source 10.0.5.0 0.0.0.255
 rule 25 permit ip source 10.0.6.0 0.0.0.255
 rule 30 permit ip source 10.0.7.0 0.0.0.255
 rule 35 permit ip source 10.0.8.0 0.0.0.255
寂东 九段
粉丝:225人 关注:3人
dialer口下,做如下配置试试,我也遇到过类似的问题,就是这样解决的,或者咨询下当地运营商,那两个参数当地的线路设置成多少合适
interface Dialer1
mtu 1492
tcp mss 1200
粉丝:15人 关注:4人
dialer的tcp mss调整一下看看
Dialer2没加到安全域里吧?
