华三交换机用什么命令清除所有配置
2019-05-09提问
  • 1收藏,17180浏览
华三交换机用什么命令清除所有配置
华三交换机用什么命令清除所有配置
大屿 八段
粉丝:25人 关注:3人
<sw>reset saved-configuration
The saved configuration file will be erased. Are you sure? [Y/N]:y
Configuration file in flash: is being cleared. Please wait ... MainBoard: Configuration file is cleared.
<sw>
<sw>reboot
Start to check configuration with next startup configuration file, please wait.........DONE! Current configuration may be lost after the reboot, save current configuration? [Y/N]:n
reboot第一次一定记着选择N,第二次再选择Y
请问第一次选n是什么意思?
zhiliao_sRnSdn 发表时间:2021-08-26
感謝學習了
