两条SMTP数字专线使用双路由作主备机时,部分文件发送上传异常.
2019-05-15提问
  • 1收藏,1889浏览
我们公司通过SMTP数字专线使用双路由备份使用的;两条路由关了一条线路都能正常发送文件,使用配置了双路由后,内部通讯软件和OA系统上传功能中,部分word文档的(.doc和.xls)无法发送上传,压缩包等能正常发送。请大神帮看一下什么原因,感谢!
两台路由配置如下:
 undo password-control aging enable
 firewall enable
 domain default enable system
 router id 172.17.112.54
 telnet server enable
 dar p2p signature-file flash:/p2p_default.mtd
 port-security enable
acl number 3002
 rule 10 deny tcp destination-port eq 445
 rule 20 deny udp destination-port eq 445
 rule 25 permit ip
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
qos policy PolicyLimit
user-group system
 group-attribute allow-guest
local-user JSHA-XYSHGC-DX
local-user admin
 password cipher $c$3$4HsEjmLj1MnXNg3DGKkCrz+1urGu2DrXes7niQ==
 authorization-attribute level 3
 service-type ssh telnet
 service-type web
 password-control length 4
 password-control composition type-number 1
cwmp
 undo cwmp enable
controller E1 0/0
interface Aux0
 async mode flow
 link-protocol ppp
interface Cellular0/0
 async mode protocol
 link-protocol ppp
 firewall packet-filter 4999 outbound
interface Ethernet0/0
 port link-mode route
 ip address 172.17.123.253 255.255.255.0
 ip address 172.17.124.253 255.255.255.0 sub
 ospf network-type broadcast
 vrrp vrid 1 virtual-ip 172.17.123.254
 vrrp vrid 1 priority 120
 vrrp vrid 1 preempt-mode timer delay 4
 vrrp vrid 1 track interface Ethernet0/1 reduced 50
 vrrp vrid 2 virtual-ip 172.17.124.254
 vrrp vrid 2 priority 120
 vrrp vrid 2 preempt-mode timer delay 4
 vrrp vrid 2 track interface Ethernet0/1 reduced 50
 ip flow-ordering internal
 firewall packet-filter 3002 inbound
 firewall packet-filter 3002 outbound
 ip address 172.17.112.54 255.255.255.252
 ospf cost 1000
 ip netstream inbound
 ip netstream outbound
interface NULL0
interface Vlan-interface1
interface Ethernet0/2
 port link-mode bridge
interface Ethernet0/3
interface Ethernet0/4
ospf 100
 peer 172.17.112.53
 area 0.0.2.5
  network 172.17.112.52 0.0.0.3
  network 172.17.123.0 0.0.0.255
  network 172.17.124.0 0.0.0.255
  nssa
 snmp-agent
 snmp-agent local-engineid 800063A20370F96D1A8D7E
 snmp-agent community read suning1
 snmp-agent sys-info version v2c
 ssh server enable
 ssh server authentication-timeout 30
 ssh user admin service-type stelnet authentication-type password
 load xml-configuration
 load tr069-configuration
user-interface tty 12
user-interface aux 0
 authentication-mode password
user-interface vty 0 4
 authentication-mode scheme
 user privilege level 3
 idle-timeout 100 0
return
第二台配置
 firewall enable
 router id 172.17.112.14
 password-recovery enable
acl number 3002
 rule 25 permit ip
vlan 1
domain system
 state active
 idle-cut disable
user-group system
local-user admin
 service-type web
cwmp
 undo cwmp enable
controller E1 0/0
interface Aux0
 async mode flow
 link-protocol ppp
 async mode protocol
 link-protocol ppp
 ip address 172.17.123.252 255.255.255.0
 ip address 172.17.124.252 255.255.255.0 sub
 vrrp vrid 1 priority 110
 vrrp vrid 2 priority 110
 description TO HUAIAN-YD-10M
 ip address 172.17.112.14 255.255.255.252
 ospf cost 1000
interface NULL0
ospf 100
 peer 172.17.112.13
 area 0.0.2.5
  network 172.17.112.12 0.0.0.3
  nssa
 snmp-agent
 snmp-agent local-engineid 800063A20370F96D1A8940
 snmp-agent sys-info version v2c v3
 undo snmp-agent trap enable voice dial
 ssh server enable
 set authentication password cipher $c$3$hNlkAom0+Ek9MXMkLzy25wYBEe7H2XUGkTKMwg=
 set authentication password cipher $c$3$iXVXQzBmAnUv8edq+DJmW5OtLetnW+jXKR2hnQ=
 idle-timeout 100 0
return
粉丝:17人 关注:4人
从配置看是vrrp+ospf的结合使用,主要看下路由表是否正常。从压缩包正常传输看,链路通信应该是正常的.这种情况建议在Pc和服务器抓包看看失败时,报文交互情况的.具体问题分析,推荐向H3C售后咨询
