H3C WX3010E 4个AP都搜不到了。
2017-12-18提问
  • 1收藏,7688浏览
以前接4个AP都能上网,现在突然所有的AP都搜不到了是怎么回事 Pow灯隔3秒绿一下正常么?
以下是配置信息:
[H3C]dis curr # version 5.20, Release 3507P22 # sysname H3C # clock timezone Beijing add 08:00:00 # domain default enable system # telnet server enable # port-security enable # oap management-ip 192.168.0.101 slot 0 # password-recovery enable # vlan 1 # domain system access-limit disable state active idle-cut disable self-service-url disable # user-group system group-attribute allow-guest # local-user admin password cipher $c$3$uqeGf8Ruskb6hpaOvLg1T1128K6jkuIh authorization-attribute level 3 service-type telnet service-type web # wlan rrm dot11a mandatory-rate 6 12 24 dot11a supported-rate 9 18 36 48 54 dot11b mandatory-rate 1 2 dot11b supported-rate 5.5 11 dot11g mandatory-rate 1 2 5.5 11 dot11g supported-rate 6 9 12 18 24 36 48 54 scan type active load-balance session 30 # wlan service-template 1 crypto ssid TXXJYJ bind WLAN-ESS 0 cipher-suite tkip security-ie rsn client forwarding-mode local vlan 1 service-template enable # wlan service-template 2 crypto ssid LQ bind WLAN-ESS 1 cipher-suite tkip security-ie rsn security-ie wpa # wlan ap-group default_group ap txxjyj ap txjyj-1 ap txjyj-2 # interface Bridge-Aggregation1 arp detection trust # interface NULL0 # interface Vlan-interface1 ip address 192.168.0.253 255.255.255.0 # interface GigabitEthernet1/0/1 port link-aggregation group 1 arp detection trust # interface GigabitEthernet1/0/2 port link-aggregation group 1 arp detection trust # interface WLAN-ESS0 port link-type hybrid port hybrid vlan 1 untagged port-security port-mode psk port-security tx-key-type 11key port-security preshared-key pass-phrase cipher $c$3$NPeN676aZxvZgdvbdMsK5wzkLts PiGciPhNJQA== # interface WLAN-ESS1 port link-type hybrid port hybrid vlan 1 untagged port-security port-mode psk port-security tx-key-type 11key port-security preshared-key pass-phrase cipher $c$3$nfcXEagOW/u+PI+55C8Vbye2ixp 5VorVxO0ynQ== # interface WLAN-ESS2 port link-type hybrid port hybrid vlan 1 untagged # wlan ap txjyj-1 model WA2610E-GNE id 2 serial-id 219801A0MM9155Q00219 radio 1 channel 6 service-template 1 service-template 2 power lock radio enable # wlan ap txjyj-2 model WA2610E-GNE id 3 serial-id 219801A0MM9154Q00492 radio 1 service-template 1 channel lock power lock radio enable # wlan ap txxjyj model WA2610E-GNE id 1 serial-id 219801A0MM9155Q00384 radio 1 channel 6 service-template 1 service-template 2 power lock radio enable # wlan ips malformed-detect-policy default signature deauth_flood signature-id 1 signature broadcast_deauth_flood signature-id 2 signature disassoc_flood signature-id 3 signature broadcast_disassoc_flood signature-id 4 signature eapol_logoff_flood signature-id 5 signature eap_success_flood signature-id 6 signature eap_failure_flood signature-id 7 signature pspoll_flood signature-id 8 signature cts_flood signature-id 9 signature rts_flood signature-id 10 signature addba_req_flood signature-id 11 signature-policy default countermeasure-policy default attack-detect-policy default virtual-security-domain default attack-detect-policy default malformed-detect-policy default signature-policy default countermeasure-policy default # ip route-static 0.0.0.0 0.0.0.0 Vlan-interface1 192.168.0.1 # snmp-agent snmp-agent local-engineid 800063A2033891D53B79E6 snmp-agent sys-info version v3 # wlan ap-authentication method serial-id # user-interface con 0 user-interface vty 0 4 authentication-mode scheme user privilege level 3 # return
粉丝:28人 关注:15人
掉线了吧
谢谢!
nxycliuzj 发表时间:2017-12-18
