无线ap
2019-06-15提问
  • 1收藏,1104浏览
我按照思路配置了设备  为什么信号是正常的但是dhcp拿不到地址  是为什么
配置如下
<WA2620-AGN>DIS current-configuration
 # version 5.20, 0000 # sysname WA2620-AGN
 # domain default enable system
# telnet server enable # port-security enable
# password-recovery enable
# vlan 1
# vlan 2
# domain system access-limit disable state active idle-cut disable self-service-url disable
# dhcp server ip-pool 1
network 192.168.100.0 mask 255.255.255.0
 gateway-list 192.168.100.254
 dns-list 114.114.114.114
# user-group system group-attribute allow-guest
# local-user admin password cipher $c$3$6tSpAMAe2g2eYEx7+4oOmeYQlR2bO6u1cJH9qY0=
 authorization-attribute level 3
 service-type telnet
# wlan rrm dot11a mandatory-rate 6 12 24 dot11a supported-rate 9 18 36 48 54 dot11b mandatory-rate 1 2 dot11b supported-rate 5.5 11 dot11g mandatory-rate 1 2 5.5 11 dot11g supported-rate 6 9 12 18 24 36 48 54
 # wlan service-template 1 clear
 ssid H3C service-template enable
# wlan service-template 2 clear
 ssid h3c-1 service-template enable
# cwmp undo cwmp enable
 # interface NULL0
# interface Vlan-interface1
 ip address 192.168.0.50 255.255.255.0
 # interface Vlan-interface2
 ip address 192.168.100.254 255.255.255.0
 # interface GigabitEthernet1/0/1
 port link-type trunk
 port trunk permit vlan all
 # interface WLAN-BSS2
 port access vlan 2
# interface WLAN-BSS32
 port link-type hybrid
 port hybrid vlan 1 untagged
# interface WLAN-BSS33
# interface WLAN-Radio1/0/1
 radio-type dot11a
 service-template 2
interface wlan-bss 2
interface WLAN-Radio1/0/2
 service-template 1 interface wlan-bss 33
# dhcp enable
# arp-snooping enable #
 load xml-configuration #
 load tr069-configuration #
 user-interface con 0
user-interface vty 0 4
 authentication-mode scheme
 # return
现状态无法获取地址 配置静态也不通 但是vlan2时up的 官方给的配置稳定很短 有没有大神来帮帮我 私聊 489341332 qq 发红包
() 一段
你的ap是fatap 还是fitap   获取
fat
梦里花落 发表时间:2019-06-15
小Z 四段
找不到请求的界面
看你这个链接 怎么看怎么像交换的东西 我问的是无线啊
你给我的是dhcp这玩意有啥难的 你给我干嘛
