请教一下,防火墙做透明部署。在命令行界面配置域间策略,在安全策略上启用安全策略。配置后网络正常,但是安全策略那边无命中数。这个是什么问题导致的,配置在附件中。
(0)
[FW]dis cu # version 7.1.064, Release 9333P17 # sysname FW # context Admin id 1 # irf mac-address persistent timer irf auto-update enable undo irf link-delay irf member 2 priority 1 # security-policy disable # password-recovery enable # vlan 1 # vlan 10 # object-group service 445??? 0 service tcp destination eq 445 # interface NULL0 # interface GigabitEthernet2/0/0 port link-mode route ip address 192.168.20.243 255.255.255.0 # interface GigabitEthernet2/0/3 port link-mode route # interface GigabitEthernet2/0/4 port link-mode route # interface GigabitEthernet2/0/5 port link-mode route # interface GigabitEthernet2/0/6 port link-mode route # interface GigabitEthernet2/0/7 port link-mode route # interface GigabitEthernet2/0/8 port link-mode route # interface GigabitEthernet2/0/9 port link-mode route # interface GigabitEthernet2/0/10 port link-mode route # interface GigabitEthernet2/0/11 port link-mode route # interface GigabitEthernet2/0/12 port link-mode route # interface GigabitEthernet2/0/13 port link-mode route # interface GigabitEthernet2/0/14 port link-mode route # interface GigabitEthernet2/0/15 port link-mode route # interface GigabitEthernet2/0/16 port link-mode route # interface GigabitEthernet2/0/17 port link-mode route # interface GigabitEthernet2/0/18 port link-mode route # interface GigabitEthernet2/0/19 port link-mode route # interface GigabitEthernet2/0/20 port link-mode route # interface GigabitEthernet2/0/21 port link-mode route # interface GigabitEthernet2/0/22 port link-mode route # interface GigabitEthernet2/0/23 port link-mode route # interface GigabitEthernet2/0/1 port link-mode bridge port access vlan 10 # interface GigabitEthernet2/0/2 port link-mode bridge port access vlan 10 # object-policy ip Local-Trust rule 0 pass # object-policy ip Local-Untrust rule 0 pass # object-policy ip Trust-Local rule 0 pass # object-policy ip Trust-Trust rule 0 pass # object-policy ip Trust-Untrust rule 0 pass # object-policy ip Untrust-Local rule 0 pass # object-policy ip Untrust-Trust rule 0 pass # security-zone name Local # security-zone name Trust import interface GigabitEthernet2/0/0 import interface GigabitEthernet2/0/2 vlan 10 # security-zone name DMZ # security-zone name Untrust import interface GigabitEthernet2/0/1 vlan 10 # security-zone name Management # zone-pair security source Local destination Trust object-policy apply ip Local-Trust # zone-pair security source Local destination Untrust object-policy apply ip Local-Untrust # zone-pair security source Trust destination Local object-policy apply ip Trust-Local # zone-pair security source Trust destination Untrust object-policy apply ip Trust-Untrust # zone-pair security source Untrust destination Local object-policy apply ip Untrust-Local # zone-pair security source Untrust destination Trust object-policy apply ip Untrust-Trust # scheduler logfile size 16 # line class aux user-role network-operator # line class console authentication-mode scheme user-role network-admin # line class usb user-role network-operator # line class vty user-role network-operator # line aux 1 user-role network-operator # line con 1 user-role network-admin # line vty 0 63 authentication-mode scheme user-role network-admin # ssh server enable # domain system # domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # local-user admin class manage password hash $h$6$UbIhNnPevyKUwfpm$LqR3+yg1IjNct39MkOR0H0iQXLkYB3jMqM4vbAeoXOhbabIIFnjJPEGR00YiYA1Sz4LiY3FmEdru2fOLMb1shQ== service-type ssh terminal https authorization-attribute user-role level-3 authorization-attribute user-role network-admin authorization-attribute user-role network-operator # session statistics enable # ipsec logging negotiation enable # ike logging negotiation enable # ip https enable webui log enable # inspect logging parameter-profile av_logging_default_parameter # inspect logging parameter-profile ips_logging_default_parameter # security-policy ip rule 1 name deny logging enable counting enable source-zone Trust destination-zone Untrust service 445??? rule 2 name "trust to untrust" action pass logging enable counting enable source-zone Trust destination-zone Untrust rule 3 name "untrust to trust" action pass logging enable counting enable source-zone Untrust destination-zone Trust rule 4 name "trust to local" action pass logging enable counting enable source-zone Trust destination-zone Local rule 5 name "local to trust" action pass logging enable counting enable source-zone Local destination-zone Trust # ips logging parameter-profile ips_logging_default_parameter # anti-virus logging parameter-profile av_logging_default_parameter # return
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
在命令行建立的域间策略不会在安全策略上显示。我是要在web界面的安全策略上看我建的安全策略是否生效
security-policy disable你关了安全策略,web上配置的是安全策略,security-policy ip,不是对象策略。所以你web看不到
为什么会有security-policy disable?我配置安全策略的时候都是有启用策略的
那你估计是老版本升级上来,为了兼容老版本的对象策略。你去web上把安全策略配好,然后去命令行把disable那个命令undo掉,设备就走安全策略了
OK,明白了
