F100-C80-WINET+有一台服务器做了映射不能访问
2019-06-17提问
  • 1收藏,845浏览
服务器上8812,1433,8080,要求内网外网都通过外网地址能访问服务器,现映射后外网不能访问服务器。在内网测试127.0.0.1已经能用。
配置如下:
<FUPINBAN-firewall>dis cur
 version 7.1.064, Ess 9508
 sysname FUPINBAN-firewall
context Admin id 1
ip vpn-instance management
 route-distinguisher 1000000000:1
 vpn-target 1000000000:1 import-extcommunity
 vpn-target 1000000000:1 export-extcommunity
 telnet server enable
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 1
 dhcp enable
 password-recovery enable
vlan 1
vlan 100
 description neiwang
object-group ip address fuwuqi
 0 network host address 192.168.100.100
object-group ip address neiwang
 0 network subnet 192.168.100.0 255.255.255.0
object-group service 1433
 0 service tcp destination eq 1433
object-group service 3389
 0 service tcp destination eq 3389
object-group service 8080
 0 service tcp destination eq 8080
object-group service 8812
 0 service tcp destination eq 8812
dhcp server ip-pool vlan100
 gateway-list 192.168.100.1
 network 192.168.100.0 mask 255.255.255.0
 address range 192.168.100.105 192.168.100.250
 dns-list 202.99.192.68 202.99.192.66
interface NULL0
interface Vlan-interface100
 ip address 192.168.100.1 255.255.255.0
 nat server protocol tcp global 60.220.217.254 1433 inside 192.168.100.100 1433
 nat server protocol tcp global 60.220.217.254 8080 inside 192.168.100.100 8080
 nat server protocol tcp global 60.220.217.254 8812 inside 192.168.100.100 8812
interface GigabitEthernet1/0/0
 port link-mode route
 ip binding vpn-instance management
 ip address 192.168.0.1 255.255.255.0
 description waiwang
 ip address 60.220.217.254 255.255.255.252
 nat outbound 2000
 nat server protocol tcp global current-interface 1433 inside 192.168.100.100 1433
 nat server protocol tcp global current-interface 3389 inside 192.168.100.100 3389
 nat server protocol tcp global current-interface 8080 inside 192.168.100.100 8080
 nat server protocol tcp global current-interface 8812 inside 192.168.100.100 8812
interface GigabitEthernet1/0/4
 port link-mode bridge
 port access vlan 100
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
object-policy ip Local-Trust
 rule 0 pass
object-policy ip Trust-Local
 rule 0 pass
object-policy ip Trust-Untrust
 rule 0 pass source-ip neiwang
object-policy ip Untrust-Trust
 rule 1 pass destination-ip fuwuqi service 1433
 rule 2 pass destination-ip fuwuqi service 3389
 rule 3 pass destination-ip fuwuqi service 8080
 rule 4 pass destination-ip fuwuqi service 8812
security-zone name Local
security-zone name Trust
 import interface Vlan-interface100
 import interface GigabitEthernet1/0/4 vlan 100
 import interface GigabitEthernet1/0/5 vlan 100
 import interface GigabitEthernet1/0/6 vlan 100
 import interface GigabitEthernet1/0/7 vlan 100
 import interface GigabitEthernet1/0/8 vlan 100
 import interface GigabitEthernet1/0/9 vlan 100
security-zone name DMZ
security-zone name Untrust
 import interface GigabitEthernet1/0/3
security-zone name Management
 import interface GigabitEthernet1/0/0
 import interface GigabitEthernet1/0/2
zone-pair security source Local destination Trust
 object-policy apply ip Local-Trust
zone-pair security source Trust destination Local
 object-policy apply ip Trust-Local
zone-pair security source Trust destination Untrust
 object-policy apply ip Trust-Untrust
zone-pair security source Untrust destination Trust
 object-policy apply ip Untrust-Trust
 scheduler logfile size 16
line class aux
 user-role network-operator
line class console
 user-role network-admin
line class vty
line aux 0
line con 0
 authentication-mode scheme
line vty 0 63
 ip route-static 0.0.0.0 0 60.220.217.253
 ssh server enable
acl basic 2000
 rule 0 permit
domain system
 aaa session-limit ftp 16
 aaa session-limit telnet 16
 aaa session-limit ssh 16
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 password hash $h$6$Izx21IFGtiVId+JR$U3unMF50bDlNwEC5kzR8DJ8kpLsV5Ld730EZl5Fur/vkeAk2eGl9lMvv+yJ8nhRp0BDTsGDNDHPCnN1tpNmVVA==
 service-type ssh telnet terminal http https
 authorization-attribute user-role level-3
 authorization-attribute user-role level-15
 ip https enable
return
<FUPINBAN-firewall> dis dev man
 Slot 1 CPU 0:
 DEVICE_NAME          : F100-C80-WiNet
 DEVICE_SERIAL_NUMBER : 219801A15M916CQ00234
 MAC_ADDRESS          : D461-FECF-1C94
 MANUFACTURING_DATE   : 2016-12-14
 VENDOR_NAME          : H3C
Power 0:
The operation is not supported on the specified power.
外网接防火墙3口,4至9口接内网
寂东 九段
粉丝:225人 关注:3人
1,zone-pair security source Untrust destination local 这个方向的域间策略加上看看外部能不能访问了
2,interface GigabitEthernet1/0/2  接口下,开启 nat hairpin enable
粉丝:24人 关注:0人
session statistics enable开这个命令后
访问一下端口
敲一下下面的会话发回来看看
 display session table ipv4 destination-ip 60.220.217.254 destination-port 8080 verbose
而且我看你没放通trust到trust的策略,你内网是怎么可以用公网地址互访的?
