AP型号是:WA2620i—gn 4个,WA2620i-AGN 1个,先是一直闪绿灯,大概是29下,然后就快速闪红灯,这样反复,也搜索不到said号请问下这是什么问题,AC型号是:WX3010E
我问题问了一天都没有得到解决,高手们帮帮忙咯
以下是AC配置:
[wuxiankongzhiqi]dis cu
version 5.20, Release 3308P18
sysname wuxiankongzhiqi
domain default enable system
telnet server enable
port-security enable
oap management-ip 192.168.0.101 slot 0
wlan auto-ap enable
password-recovery enable
vlan 1
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
user-group system
group-attribute allow-guest
local-user admin
password cipher $c$3$nmBMe/uKDpkC4Xtv6LT2J3/1dyLYc5D+
authorization-attribute level 3
service-type telnet
local-user admin123
password cipher $c$3$5MkQPApb8aiEWkYdIh0nhEkxYtctq8k5Y7Cc
service-type telnet
wlan rrm
dot11a mandatory-rate 6 12 24
dot11a supported-rate 9 18 36 48 54
dot11b mandatory-rate 1 2
dot11b supported-rate 5.5 11
dot11g mandatory-rate 1 2 5.5 11
dot11g supported-rate 6 9 12 18 24 36 48 54
wlan service-template 11 crypto
ssid cfst-wifi
bind WLAN-ESS 1
authentication-method shared-key
cipher-suite wep40
wep default-key 1 wep40 pass-phrase cipher $c$3$UoAfqHHOkHyHJ4OkB2HcgGGYAp63i/3S
service-template enable
interface Bridge-Aggregation1
interface NULL0
interface Vlan-interface1
ip address 192.168.0.100 255.255.255.0
port link-aggregation group 1
interface WLAN-ESS1
interface WLAN-ESS11
wlan ap autoap_0009 model WA2610i-GN id 3
serial-id 219801A0CLC13A000289
radio 1
channel 6
service-template 11
radio enable
wlan ap autoap_0010 model WA2610i-GN id 4
serial-id 219801A0CLC13A000296
radio 1
channel 1
service-template 11
radio enable
wlan ap autoap_0011 model WA2610i-GN id 5
serial-id 219801A0CLC13A000305
radio 1
channel 11
service-template 11
radio enable
wlan ap autoap_0012 model WA2610i-GN id 6
serial-id 219801A0CLC13A000306
radio 1
channel 1
service-template 11
radio enable
wlan ap aytoap_0015 model WA2620i-AGN id 7
serial-id 219801A0CNC138018605
radio 1
service-template 11
radio enable
radio 2
service-template 11
radio enable
dhcp server forbidden-ip 192.168.0.1
dhcp server forbidden-ip 192.168.0.100
dhcp server forbidden-ip 192.168.0.101
dhcp server forbidden-ip 192.168.0.254
load xml-configuration
user-interface con 0
user-interface vty 0 4
authentication-mode scheme
user privilege level 3
return
[wuxiankongzhiqi]
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
<wuxiankongzhiqi>dis wlan ap all Total Number of APs configured : 5 Total Number of configured APs connected : 5 Total Number of auto APs connected : 0 AP Profiles State : I = Idle, J = Join, JA = JoinAck, IL = ImageLoad C = Config, R = Run, KU = KeyUpdate, KC = KeyCfm -------------------------------------------------------------------------------- AP Name State Model Serial-ID -------------------------------------------------------------------------------- autoap_0009 R/M WA2610i-GN 219801A0CLC13A000289 autoap_0010 R/M WA2610i-GN 219801A0CLC13A000296 autoap_0011 R/M WA2610i-GN 219801A0CLC13A000305 autoap_0012 R/M WA2610i-GN 219801A0CLC13A000306 aytoap_0015 R/M WA2620i-AGN 219801A0CNC138018605
这是在线壮态,
我在AC上配DHCP服务,已经正常了,但是用户不是获取了路由的IP,是AC上DHCP服务分的IP,请回复
