ap
2019-06-18提问
  • 1收藏,1011浏览
AP型号是:WA2620i—gn 4个,WA2620i-AGN 1个,先是一直闪绿灯,大概是29下,然后就快速闪红灯,这样反复,也搜索不到ssid
AC型号是:WX3010E
我在AC上配DHCP服务,AP灯已经正常了,但是用户不是获取了路由的IP,而是获取AC上DHCP服务分的IP,路由已开启DHCP服务,请问一下这问题应该怎么处理
以下是配置:
<wuxiankongzhiqi>dis cu
 version 5.20, Release 3308P18
 sysname wuxiankongzhiqi
 domain default enable system
 telnet server enable
 port-security enable
 oap management-ip 192.168.0.101 slot 0
 wlan auto-ap enable
 password-recovery enable
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
dhcp server ip-pool wu
 network 192.168.0.0 mask 255.255.255.0
 gateway-list 192.168.0.1
 dns-list 222.246.129.80
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$YRGaWn4xWuvnW0HJ0qk7UfVAc3Yus6DPgdz8
 authorization-attribute level 3
 service-type lan-access
 service-type telnet
 service-type ftp
 service-type ppp
 service-type portal
 service-type web
wlan rrm
 dot11a mandatory-rate 6 12 24
 dot11a supported-rate 9 18 36 48 54
 dot11b mandatory-rate 1 2
 dot11b supported-rate 5.5 11
 dot11g mandatory-rate 1 2 5.5 11
 dot11g supported-rate 6 9 12 18 24 36 48 54
wlan service-template 11 crypto
 ssid cfst-wifi
 bind WLAN-ESS 1
 authentication-method shared-key
 cipher-suite wep40
 wep default-key 1 wep40 pass-phrase cipher $c$3$UoAfqHHOkHyHJ4OkB2HcgGGYAp63i/3S
 service-template enable
interface Bridge-Aggregation1
interface NULL0
interface Vlan-interface1
 ip address 192.168.0.100 255.255.255.0
 port link-aggregation group 1
interface WLAN-ESS1
interface WLAN-ESS11
wlan ap autoap_0009 model WA2610i-GN id 3
 serial-id 219801A0CLC13A000289
 radio 1
  channel 6
  service-template 11
  radio enable
wlan ap autoap_0010 model WA2610i-GN id 4
 serial-id 219801A0CLC13A000296
 radio 1
  channel 1
  service-template 11
  radio enable
wlan ap autoap_0011 model WA2610i-GN id 5
 serial-id 219801A0CLC13A000305
 radio 1
  channel 11
  service-template 11
  radio enable
wlan ap autoap_0012 model WA2610i-GN id 6
 serial-id 219801A0CLC13A000306
 radio 1
  channel 1
  service-template 11
  radio enable
wlan ap aytoap_0015 model WA2620i-AGN id 7
 serial-id 219801A0CNC138018605
 radio 1
  service-template 11
  radio enable
 radio 2
  service-template 11
  radio enable
 undo info-center enable
 dhcp server forbidden-ip 192.168.0.1
 dhcp server forbidden-ip 192.168.0.100
 dhcp server forbidden-ip 192.168.0.101
 dhcp server forbidden-ip 192.168.0.254
 dhcp enable
 load xml-configuration
user-interface con 0
user-interface vty 0 4
 authentication-mode scheme
 user privilege level 3
return
<wuxiankongzhiqi>
以下是AP在线状态:
<wuxiankongzhiqi> dis wlan ap all
 Total Number of APs configured           : 5
 Total Number of configured APs connected : 5
 Total Number of auto APs connected       : 0
                                  AP Profiles
 State : I = Idle,   J = Join, JA = JoinAck,   IL = ImageLoad
         C = Config, R = Run,  KU = KeyUpdate, KC = KeyCfm
 AP Name                          State Model              Serial-ID
 autoap_0009                      R/M   WA2610i-GN         219801A0CLC13A000289
 autoap_0010                      R/M   WA2610i-GN         219801A0CLC13A000296
 autoap_0011                      R/M   WA2610i-GN         219801A0CLC13A000305
 autoap_0012                      R/M   WA2610i-GN         219801A0CLC13A000306
 aytoap_0015                      R/M   WA2620i-AGN        219801A0CNC138018605
<wuxiankongzhiqi>
把ac当旁挂接入,ap的地址由路由下发,然后ac的dhcp关了,将ac的管理地址改的跟路由下发的地址同网段就ok了。
