我公司用2台路由器,想实现内网的电脑同时能上内外网...
  • 1收藏,3040浏览
我公司用2台H3C MSR20-12路由器。一台是公司内网使用(数据专线),一台外网使用(互联网专线),现在想要实现内网的电脑同时能上内外网。 两台路由配置如下,请大神帮忙给修改一下配置,谢谢!
内网是公司总部分配的IP地址段。
 version 5.20, Release 2511P02
 sysname JS-DX
 undo password-control aging enable
 firewall enable
 domain default enable system
 router id 10.17.112.86  上级公司专线分配地址
 telnet server enable
 dar p2p signature-file flash:/p2p_default.mtd
 port-security enable
 password-recovery enable
acl number 3000
 rule 0 permit ip destination 192.168.100.0 0.0.0.255
 rule 5 permit ip destination 192.168.118.0 0.0.0.255
 rule 10 permit ip destination 192.168.122.0 0.0.0.255
 rule 15 permit ip
acl number 3001
 rule 0 deny ip destination 192.168.100.0 0.0.0.255
 rule 5 deny ip destination 192.168.118.0 0.0.0.255
 rule 10 deny ip destination 192.168.122.0 0.0.0.255
 rule 15 permit ip
acl number 3602
 rule 0 permit ip source 10.104.249.65 0
 rule 5 permit ip source 10.104.254.101 0
 rule 10 permit ip source 10.104.249.143 0
 rule 15 permit ip destination 10.104.249.65 0
 rule 20 permit ip destination 10.104.254.101 0
 rule 25 permit ip destination 10.104.249.143 0
 rule 30 permit ip source 10.104.254.11 0
 rule 35 permit ip destination 10.104.254.11 0
acl number 3608
 rule 0 deny ip source 10.104.249.65 0
 rule 5 deny ip source 10.104.254.101 0
 rule 10 deny ip source 10.104.249.143 0
 rule 15 deny ip destination 10.104.249.65 0
 rule 20 deny ip destination 10.104.254.101 0
 rule 25 deny ip destination 10.104.249.143 0
 rule 30 deny ip source 10.104.254.11 0
 rule 35 deny ip destination 10.104.254.11 0
acl number 4999
 rule 1 permit
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
traffic classifier others operator and
 if-match acl 3001
traffic classifier pos&sap operator and
 if-match acl 3000
traffic classifier acl3980deny operator or
 if-match acl 3980
traffic behavior others
 queue af bandwidth 6000
traffic behavior pos&sap
 queue af bandwidth 4000
traffic behavior acldeny
 filter deny
qos policy pos&sap
 classifier pos&sap behavior pos&sap
 classifier others behavior others
qos policy PolicyLimit
user-group system
 group-attribute allow-guest
local-user JS-DX
local-user LYGXXB
 password cipher ************
 authorization-attribute level 3
 service-type ssh telnet
 service-type web
local-user admin
 password cipher ***************
 service-type web
 password-control length 4
 password-control composition type-number 1
local-user user
cwmp
 undo cwmp enable
controller E1 0/0
 using e1
interface Aux0
 async mode flow
 link-protocol ppp
interface Cellular0/0
 async mode protocol
 link-protocol ppp
 qos apply policy PolicyLimit outbound
 firewall packet-filter 4999 outbound
interface Ethernet0/0
 port link-mode route
 ip address 10.17.123.253 255.255.255.0
 ospf cost 1000
 vrrp vrid 1 virtual-ip 10.17.123.254
 vrrp vrid 1 priority 120
 vrrp vrid 1 preempt-mode timer delay 2
interface Ethernet0/1
 ip address 10.17.112.86 255.255.255.252    上级公司专线分配地址
 ospf network-type broadcast
 ip netstream inbound
 ip netstream outbound
 undo ip fast-forwarding
 ip flow-ordering internal
interface Ethernet0/2
 qos max-bandwidth 5120
 ospf network-type p2p
 qos flow-interval 1
interface Serial0/0:0
 link-protocol ppp
 qos flow-interval 1
interface NULL0
interface Vlan-interface1
interface Ethernet0/3
 port link-mode bridge
interface Ethernet0/4
ospf 100
 peer 10.17.112.85     上级公司专线分配地址
 area 0.0.2.5
  network 10.17.112.84 0.0.0.3
  network 10.17.123.0 0.0.0.255
  nssa
voice-setup
 sip
 sip-server
  call-rule-set
  call-route
 dial-program
 aaa-client
 gk-client
 snmp-agent
 snmp-agent local-engineid 800063A20370F96D1A8D7E
 snmp-agent community read yunshang1
 snmp-agent sys-info version v2c
 ip netstream export host 192.168.132.142 2055
 ip netstream export source interface Ethernet0/1
 ntp-service unicast-server 192.168.132.201
 ssh server enable
 ssh server authentication-timeout 30
 ssh user admin service-type stelnet authentication-type password
 load xml-configuration
 load tr069-configuration
user-interface tty 12
user-interface aux 0
 authentication-mode password
user-interface vty 0 4
 authentication-mode scheme
 user privilege level 3
 idle-timeout 100 0
return
外网路由配置信息如下:
 sysname H3C
 dns proxy enable
 bridge enable
acl number 3000
 rule 0 permit ip
vlan 1
domain system
 state active
 idle-cut disable
dhcp server ip-pool vlan1 extended
user-group system
local-user admin
 password cipher $c$3$MDxVKXl9Q2F9eQLHJWWtAuZrDugOuI3CErkebQ==
 service-type telnet
local-user xuyisuning
 password cipher $c$3$4GbNByYqHDH+y/2F+oyn8pGsOY2rXGtzNb8gEQ==
 service-type telnet
 service-type web
cwmp
 undo cwmp enable
attack-defense policy 1
 signature-detect action drop-packet
 signature-detect fraggle enable
 defense icmp-flood enable
  defense icmp-flood action drop-packet
controller E1 0/0
interface Aux0
 async mode flow
 link-protocol ppp
 async mode protocol
 link-protocol ppp
 nat outbound static
 nat outbound static
 nat outbound 3000
 ip address 108.1.27.4 255.255.255.0
 dns server 108.4.0.55
interface NULL0
 ip address 192.1.1.1 255.255.255.0
 undo dhcp select server global-pool
 dhcp server apply ip-pool vlan1
 attack-defense apply policy 1
 ip route-static 0.0.0.0 0.0.0.0 Ethernet0/0 108.1.27.1
 dhcp server forbidden-ip 192.1.1.10 192.1.1.254
 dhcp enable
 nms primary monitor-interface Ethernet0/0
return
呵呵 九段
粉丝:27人 关注:0人
使用PBR,如果访问的是内部地址,丢给内网那台MSR设备。
其他地址走公网那台MSR
使用PBR是在路由器上设置的吗?还是要在加一台三层交换机啊!
℡劉立軍 发表时间:2017-12-20
寂东 九段
粉丝:225人 关注:3人
外网加台三层交换机吧,用一台三层交换机,将两个网连起来,些一条去往10.17.112.86的明细路由,一条缺省路由指向互联网路由器的lan口,互联网路由器做好两个网段的nat转发,和回程路由
请问没有三层交换机怎么配置啊
℡劉立軍 发表时间:2017-12-23
回复℡劉立軍:
个人认为,不加三层交换机实现不了,没有三层交换,终端网关如何设定?
寂东 发表时间:2017-12-24
℡劉立軍 知了小白
