MSR路由器与其它路由器不能进行IPSEC对接 兼容性太差,找不到原因,请求远程支持
2019-07-04提问
  • 1收藏,859浏览
华三MSR系列路由器无法对接(无公网IP)
华三ER系列路由器轻松对接(无公网IP)
对端是软路由,有动态公网IP,已做动态域名解析
以下是MSR 2600的日志
*Jul  4 07:40:48:715 2019 2600 IKE/7/DEBUG: send message:
*Jul  4 07:40:48:715 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x7de5d63d139887e5
*Jul  4 07:40:48:715 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:40:48:716 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:40:48:716 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:40:48:716 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:40:48:716 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:40:48:717 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:40:48:717 2019 2600 IKE/7/DEBUG:   LENGTH: 367
*Jul  4 07:41:00:625 2019 2600 IKE/7/DEBUG: exchange release: freeing exchange 9d4bd40
*Jul  4 07:41:05:777 2019 2600 IKE/7/DEBUG: IKE receive acquire SA request, IKE peer name:vpn-test.
*Jul  4 07:41:05:777 2019 2600 IKE/7/DEBUG: Connection name is 182.148.30.44,182.148.142.9,500,,0,2,1
*Jul  4 07:41:05:777 2019 2600 IKE/7/DEBUG: Check connection: SA for 182.148.30.44,182.148.142.9,500,,0,2,1 missing
*Jul  4 07:41:05:778 2019 2600 IKE/7/DEBUG: exchange lookup :name = 182.148.30.44,182.148.142.9,500,,0,2,1 phase = 2
*Jul  4 07:41:05:778 2019 2600 IKE/7/DEBUG: exchange lookup :name = 182.148.30.44,182.148.142.9,500,,0,0,0 phase = 1
*Jul  4 07:41:05:778 2019 2600 IKE/7/DEBUG: exchange setup(I): 9cf64f0
*Jul  4 07:41:05:778 2019 2600 IKE/7/DEBUG: create udp resource:name = 182.148.30.44,182.148.142.9,500,,0,0,0.
*Jul  4 07:41:05:778 2019 2600 IKE/7/DEBUG: add payload to message: SA
*Jul  4 07:41:05:779 2019 2600 IKE/7/DEBUG:   DOI: 1
*Jul  4 07:41:05:779 2019 2600 IKE/7/DEBUG: add payload to message: PROPOSAL
*Jul  4 07:41:05:779 2019 2600 IKE/7/DEBUG:   NO: 1
*Jul  4 07:41:05:779 2019 2600 IKE/7/DEBUG:   PROTO: ISAKMP
*Jul  4 07:41:05:779 2019 2600 IKE/7/DEBUG:   SPI_SZ: 0
*Jul  4 07:41:05:780 2019 2600 IKE/7/DEBUG:   NTRANSFORMS: 1
*Jul  4 07:41:05:780 2019 2600 IKE/7/DEBUG: add payload to message: TRANSFORM
*Jul  4 07:41:05:780 2019 2600 IKE/7/DEBUG:   NO: 0
*Jul  4 07:41:05:780 2019 2600 IKE/7/DEBUG:   ID: 1
*Jul  4 07:41:05:780 2019 2600 IKE/7/DEBUG:   Transform 0's attributes
*Jul  4 07:41:05:780 2019 2600 IKE/7/DEBUG:   Attribute ENCRYPTION_ALGORITHM : DES_CBC
*Jul  4 07:41:05:780 2019 2600 IKE/7/DEBUG:   Attribute HASH_ALGORITHM : MD5
*Jul  4 07:41:05:780 2019 2600 IKE/7/DEBUG:   Attribute AUTHENTICATION_METHOD : PRE_SHARED
*Jul  4 07:41:05:780 2019 2600 IKE/7/DEBUG:   Attribute GROUP_DESCRIPTION : MODP_1024
*Jul  4 07:41:05:780 2019 2600 IKE/7/DEBUG:   Attribute LIFE_TYPE : SECONDS
*Jul  4 07:41:05:781 2019 2600 IKE/7/DEBUG:   Attribute LIFE_DURATION : 7200
*Jul  4 07:41:05:781 2019 2600 IKE/7/DEBUG: P1 initiator send SA message.
*Jul  4 07:41:05:781 2019 2600 IKE/7/DEBUG: add payload to message: KEY_EXCH
*Jul  4 07:41:05:781 2019 2600 IKE/7/DEBUG:   Group ID: 2
*Jul  4 07:41:05:781 2019 2600 IKE/7/DEBUG: add payload to message: NONCE
*Jul  4 07:41:05:781 2019 2600 IKE/7/DEBUG: add payload to message: VENDOR
IKE_DPD: send VID : afcad713 68a1f1c9 6b8696fc 77570100 (DPD)
*Jul  4 07:41:05:781 2019 2600 IKE/7/DEBUG: add payload to message: ID
*Jul  4 07:41:05:781 2019 2600 IKE/7/DEBUG:   TYPE: 2
*Jul  4 07:41:05:782 2019 2600 IKE/7/DEBUG:   DOI_DATA: 0x000000
*Jul  4 07:41:05:782 2019 2600 IKE/7/DEBUG: add payload to message: VENDOR
*Jul  4 07:41:05:782 2019 2600 IKE/7/DEBUG:   send rfc3947 VID
*Jul  4 07:41:05:782 2019 2600 IKE/7/DEBUG:   send draft-ietf-ipsec-nat-t-ike-06 VID
*Jul  4 07:41:05:782 2019 2600 IKE/7/DEBUG:   send draft-ietf-ipsec-nat-t-ike-03 VID
*Jul  4 07:41:05:782 2019 2600 IKE/7/DEBUG:   send draft-ietf-ipsec-nat-t-ike-02 VID
*Jul  4 07:41:05:783 2019 2600 IKE/7/DEBUG:   send draft-ietf-ipsec-nat-t-ike-01 VID
*Jul  4 07:41:05:783 2019 2600 IKE/7/DEBUG: exchange check: checking for required SA
*Jul  4 07:41:05:783 2019 2600 IKE/7/DEBUG: exchange check: checking for required KEY_EXCH
*Jul  4 07:41:05:783 2019 2600 IKE/7/DEBUG: exchange check: checking for required NONCE
*Jul  4 07:41:05:783 2019 2600 IKE/7/DEBUG: exchange check: checking for required ID
*Jul  4 07:41:05:783 2019 2600 IKE/7/DEBUG: send message:
*Jul  4 07:41:05:783 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0xe094f9652f67d3d5
*Jul  4 07:41:05:783 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:41:05:783 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:41:05:783 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:41:05:784 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:41:05:784 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:41:05:784 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:41:05:784 2019 2600 IKE/7/DEBUG:   LENGTH: 367
*Jul  4 07:41:05:784 2019 2600 IKE/7/DEBUG: exchange state machine(I): finished step 0, advancing...
*Jul  4 07:41:13:783 2019 2600 IKE/7/DEBUG: send message:
*Jul  4 07:41:13:783 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0xe094f9652f67d3d5
*Jul  4 07:41:13:784 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:41:13:784 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:41:13:784 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:41:13:784 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:41:13:785 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:41:13:785 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:41:13:785 2019 2600 IKE/7/DEBUG:   LENGTH: 367
*Jul  4 07:41:15:184 2019 2600 IKE/7/DEBUG: exchange release: freeing exchange 9dcd980
*Jul  4 07:41:24:792 2019 2600 IKE/7/DEBUG: send message:
*Jul  4 07:41:24:792 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0xe094f9652f67d3d5
*Jul  4 07:41:24:793 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:41:24:793 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:41:24:793 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:41:24:793 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:41:24:793 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:41:24:794 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:41:24:794 2019 2600 IKE/7/DEBUG:   LENGTH: 367
*Jul  4 07:41:30:777 2019 2600 IKE/7/DEBUG: received message:
*Jul  4 07:41:30:778 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x84c8d13bbc753c59
*Jul  4 07:41:30:778 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:41:30:778 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:41:30:778 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:41:30:779 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:41:30:779 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:41:30:779 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:41:30:779 2019 2600 IKE/7/DEBUG:   LENGTH: 376
*Jul  4 07:41:30:779 2019 2600 IKE/7/DEBUG: exchange lookup all list from COOKIE: iCOOKIE 84c8d13bbc753c59
*Jul  4 07:41:30:780 2019 2600 IKE/7/DEBUG: parse payloads: payload SA
*Jul  4 07:41:30:780 2019 2600 IKE/7/DEBUG: parse payloads: payload KEY_EXCH
*Jul  4 07:41:30:780 2019 2600 IKE/7/DEBUG: parse payloads: payload NONCE
*Jul  4 07:41:30:780 2019 2600 IKE/7/DEBUG: parse payloads: payload ID
*Jul  4 07:41:30:781 2019 2600 IKE/7/DEBUG: parse payloads: payload VENDOR
*Jul  4 07:41:30:781 2019 2600 IKE/7/DEBUG: validate payload SA
*Jul  4 07:41:30:781 2019 2600 IKE/7/DEBUG:   DOI: 1
*Jul  4 07:41:30:781 2019 2600 IKE/7/DEBUG:   unsupported Vendor ID(HEX):
*Jul  4 07:41:30:781 2019 2600 IKE/7/DEBUG: 09002689 dfd6b712 0d000014 afcad713
*Jul  4 07:41:30:781 2019 2600 IKE/7/DEBUG:   receive DPD Protocol Vendor ID
*Jul  4 07:41:30:781 2019 2600 IKE/7/DEBUG:   receive rfc3947 Protocol Vendor ID
*Jul  4 07:41:30:782 2019 2600 IKE/7/DEBUG:   receive draft-ietf-ipsec-nat-t-ike-02 Protocol Vendor ID
*Jul  4 07:41:30:782 2019 2600 IKE/7/DEBUG: P1 responder exchange setup: Connection name is 182.148.30.44,110.191.248.38,500,,0,0,0
*Jul  4 07:41:30:782 2019 2600 IKE/7/DEBUG: exchange setup(R): 9cf5c70
*Jul  4 07:41:30:782 2019 2600 IKE/7/DEBUG: parse payloads: payload PROPOSAL
*Jul  4 07:41:30:782 2019 2600 IKE/7/DEBUG: parse payloads: payload TRANSFORM
*Jul  4 07:41:30:782 2019 2600 IKE/7/DEBUG: validate payload PROPOSAL
*Jul  4 07:41:30:782 2019 2600 IKE/7/DEBUG:   NO: 0
*Jul  4 07:41:30:782 2019 2600 IKE/7/DEBUG:   PROTO: ISAKMP
*Jul  4 07:41:30:783 2019 2600 IKE/7/DEBUG:   SPI_SZ: 0
*Jul  4 07:41:30:783 2019 2600 IKE/7/DEBUG:   NTRANSFORMS: 2
*Jul  4 07:41:30:783 2019 2600 IKE/7/DEBUG: validate payload TRANSFORM
*Jul  4 07:41:30:783 2019 2600 IKE/7/DEBUG:   NO: 1
*Jul  4 07:41:30:783 2019 2600 IKE/7/DEBUG:   ID: 1
*Jul  4 07:41:30:783 2019 2600 IKE/7/DEBUG:   Transform 1's attributes
*Jul  4 07:41:30:783 2019 2600 IKE/7/DEBUG:   Attribute ENCRYPTION_ALGORITHM : 3DES_CBC
*Jul  4 07:41:30:783 2019 2600 IKE/7/DEBUG:   Attribute HASH_ALGORITHM : MD5
*Jul  4 07:41:30:783 2019 2600 IKE/7/DEBUG:   Attribute GROUP_DESCRIPTION : MODP_1024
*Jul  4 07:41:30:783 2019 2600 IKE/7/DEBUG:   Attribute AUTHENTICATION_METHOD : PRE_SHARED
*Jul  4 07:41:30:784 2019 2600 IKE/7/DEBUG:   Attribute LIFE_TYPE : SECONDS
*Jul  4 07:41:30:784 2019 2600 IKE/7/DEBUG:   Attribute LIFE_DURATION : 86400
*Jul  4 07:41:30:784 2019 2600 IKE/7/DEBUG: validate payload TRANSFORM
*Jul  4 07:41:30:784 2019 2600 IKE/7/DEBUG:   NO: 2
*Jul  4 07:41:30:784 2019 2600 IKE/7/DEBUG:   ID: 1
*Jul  4 07:41:30:784 2019 2600 IKE/7/DEBUG:   Transform 2's attributes
*Jul  4 07:41:30:784 2019 2600 IKE/7/DEBUG:   Attribute ENCRYPTION_ALGORITHM : AES_CBC
*Jul  4 07:41:30:784 2019 2600 IKE/7/DEBUG:   Attribute KEY_LENGTH : AES_CBC_128
*Jul  4 07:41:30:784 2019 2600 IKE/7/DEBUG:   Attribute HASH_ALGORITHM : SHA
*Jul  4 07:41:30:784 2019 2600 IKE/7/DEBUG:   Attribute GROUP_DESCRIPTION : MODP_2048
*Jul  4 07:41:30:785 2019 2600 IKE/7/DEBUG:   Attribute AUTHENTICATION_METHOD : PRE_SHARED
*Jul  4 07:41:30:785 2019 2600 IKE/7/DEBUG:   Attribute LIFE_TYPE : SECONDS
*Jul  4 07:41:30:785 2019 2600 IKE/7/DEBUG:   Attribute LIFE_DURATION : 86400
*Jul  4 07:41:30:785 2019 2600 IKE/7/DEBUG: validate payload KEY_EXCH
*Jul  4 07:41:30:785 2019 2600 IKE/7/DEBUG: validate payload ID
*Jul  4 07:41:30:785 2019 2600 IKE/7/DEBUG:   TYPE: 1
*Jul  4 07:41:30:785 2019 2600 IKE/7/DEBUG:   DOI_DATA: 0x000000
*Jul  4 07:41:30:785 2019 2600 IKE/7/DEBUG:   id information: type 1 proto 0 port 0
*Jul  4 07:41:30:785 2019 2600 IKE/7/DEBUG:   id information: IPv4 address 192.168.180.102
*Jul  4 07:41:30:786 2019 2600 IKE/7/DEBUG: validate payload NONCE
*Jul  4 07:41:30:786 2019 2600 IKE/7/DEBUG: validate payload VENDOR
*Jul  4 07:41:30:786 2019 2600 IKE/7/DEBUG:   vendor ID seen
*Jul  4 07:41:30:786 2019 2600 IKE/7/DEBUG: exchange check: checking for required SA
*Jul  4 07:41:30:787 2019 2600 IKE/7/DEBUG: exchange check: checking for required KEY_EXCH
*Jul  4 07:41:30:787 2019 2600 IKE/7/DEBUG: exchange check: checking for required NONCE
*Jul  4 07:41:30:787 2019 2600 IKE/7/DEBUG: exchange check: checking for required ID
*Jul  4 07:41:30:787 2019 2600 IKE/7/DEBUG: negotiate sa: transform 1 proto 1 proposal 0 compatible
*Jul  4 07:41:30:787 2019 2600 IKE/7/DEBUG: negotiate sa: proposal 0 succeeded
*Jul  4 07:41:30:787 2019 2600 IKE/7/DEBUG: Find IKE peer by address.
  IfIndex:0x000b0001.
  local addr:182.148.30.44, remote addr:192.168.180.102.
*Jul  4 07:41:30:787 2019 2600 IKE/7/DEBUG: P1 handle ID: Failed to find ike peer by address.
*Jul  4 07:41:30:787 2019 2600 IKE/7/DEBUG: exchange state machine: Failed to receive message.
*Jul  4 07:41:34:778 2019 2600 IKE/7/DEBUG: received message:
*Jul  4 07:41:34:778 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x84c8d13bbc753c59
*Jul  4 07:41:34:778 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:41:34:778 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:41:34:779 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:41:34:779 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:41:34:779 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:41:34:779 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:41:34:779 2019 2600 IKE/7/DEBUG:   LENGTH: 376
*Jul  4 07:41:34:780 2019 2600 IKE/7/DEBUG: exchange lookup all list from COOKIE: iCOOKIE 84c8d13bbc753c59
*Jul  4 07:41:34:780 2019 2600 IKE/7/DEBUG:   found p1 active exchange ...
*Jul  4 07:41:34:780 2019 2600 IKE/7/DEBUG: received message: dropping setup for existing SA
*Jul  4 07:41:38:781 2019 2600 IKE/7/DEBUG: send message:
*Jul  4 07:41:38:781 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0xe094f9652f67d3d5
*Jul  4 07:41:38:781 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:41:38:782 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:41:38:782 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:41:38:782 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:41:38:782 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:41:38:783 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:41:38:783 2019 2600 IKE/7/DEBUG:   LENGTH: 367
*Jul  4 07:41:41:975 2019 2600 IKE/7/DEBUG: received message:
*Jul  4 07:41:41:975 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x84c8d13bbc753c59
*Jul  4 07:41:41:975 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:41:41:975 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:41:41:976 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:41:41:976 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:41:41:976 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:41:41:976 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:41:41:977 2019 2600 IKE/7/DEBUG:   LENGTH: 376
*Jul  4 07:41:41:977 2019 2600 IKE/7/DEBUG: exchange lookup all list from COOKIE: iCOOKIE 84c8d13bbc753c59
*Jul  4 07:41:41:977 2019 2600 IKE/7/DEBUG:   found p1 active exchange ...
*Jul  4 07:41:41:977 2019 2600 IKE/7/DEBUG: received message: dropping setup for existing SA
*Jul  4 07:41:54:938 2019 2600 IKE/7/DEBUG: received message:
*Jul  4 07:41:54:938 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x84c8d13bbc753c59
*Jul  4 07:41:54:939 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:41:54:939 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:41:54:939 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:41:54:939 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:41:54:940 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:41:54:940 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:41:54:940 2019 2600 IKE/7/DEBUG:   LENGTH: 376
*Jul  4 07:41:54:940 2019 2600 IKE/7/DEBUG: exchange lookup all list from COOKIE: iCOOKIE 84c8d13bbc753c59
*Jul  4 07:41:54:941 2019 2600 IKE/7/DEBUG:   found p1 active exchange ...
*Jul  4 07:41:54:941 2019 2600 IKE/7/DEBUG: received message: dropping setup for existing SA
*Jul  4 07:41:59:742 2019 2600 IKE/7/DEBUG: send message:
*Jul  4 07:41:59:743 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0xe094f9652f67d3d5
*Jul  4 07:41:59:743 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:41:59:743 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:41:59:743 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:41:59:744 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:41:59:744 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:41:59:744 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:41:59:744 2019 2600 IKE/7/DEBUG:   LENGTH: 367
*Jul  4 07:42:00:665 2019 2600 IKE/7/DEBUG: received message:
*Jul  4 07:42:00:665 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x95209ae0cf420e78
*Jul  4 07:42:00:665 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:42:00:666 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:42:00:666 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:42:00:666 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:42:00:666 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:42:00:667 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:42:00:667 2019 2600 IKE/7/DEBUG:   LENGTH: 376
*Jul  4 07:42:00:667 2019 2600 IKE/7/DEBUG: exchange lookup all list from COOKIE: iCOOKIE 95209ae0cf420e78
*Jul  4 07:42:00:667 2019 2600 IKE/7/DEBUG: parse payloads: payload SA
*Jul  4 07:42:00:667 2019 2600 IKE/7/DEBUG: parse payloads: payload KEY_EXCH
*Jul  4 07:42:00:668 2019 2600 IKE/7/DEBUG: parse payloads: payload NONCE
*Jul  4 07:42:00:668 2019 2600 IKE/7/DEBUG: parse payloads: payload ID
*Jul  4 07:42:00:668 2019 2600 IKE/7/DEBUG: parse payloads: payload VENDOR
*Jul  4 07:42:00:669 2019 2600 IKE/7/DEBUG: parse payloads: payload VENDOR
*Jul  4 07:42:00:669 2019 2600 IKE/7/DEBUG: validate payload SA
*Jul  4 07:42:00:669 2019 2600 IKE/7/DEBUG:   DOI: 1
*Jul  4 07:42:00:670 2019 2600 IKE/7/DEBUG:   unsupported Vendor ID(HEX):
*Jul  4 07:42:00:670 2019 2600 IKE/7/DEBUG: 09002689 dfd6b712 0d000014 afcad713
*Jul  4 07:42:00:670 2019 2600 IKE/7/DEBUG:   receive DPD Protocol Vendor ID
*Jul  4 07:42:00:670 2019 2600 IKE/7/DEBUG:   receive rfc3947 Protocol Vendor ID
*Jul  4 07:42:00:670 2019 2600 IKE/7/DEBUG:   receive draft-ietf-ipsec-nat-t-ike-02 Protocol Vendor ID
*Jul  4 07:42:00:671 2019 2600 IKE/7/DEBUG: P1 responder exchange setup: Connection name is 182.148.30.44,110.191.248.38,500,,0,0,0
*Jul  4 07:42:00:671 2019 2600 IKE/7/DEBUG: P1 exists the same exchange.
*Jul  4 07:42:00:671 2019 2600 IKE/7/DEBUG: exchange chooses role: Local is initiator
*Jul  4 07:42:00:671 2019 2600 IKE/7/DEBUG: P1: local is initiator.
*Jul  4 07:42:04:666 2019 2600 IKE/7/DEBUG: received message:
*Jul  4 07:42:04:666 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x95209ae0cf420e78
*Jul  4 07:42:04:666 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:42:04:667 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:42:04:667 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:42:04:667 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:42:04:667 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:42:04:668 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:42:04:668 2019 2600 IKE/7/DEBUG:   LENGTH: 376
*Jul  4 07:42:04:668 2019 2600 IKE/7/DEBUG: exchange lookup all list from COOKIE: iCOOKIE 95209ae0cf420e78
*Jul  4 07:42:04:668 2019 2600 IKE/7/DEBUG: parse payloads: payload SA
*Jul  4 07:42:04:669 2019 2600 IKE/7/DEBUG: parse payloads: payload KEY_EXCH
*Jul  4 07:42:04:669 2019 2600 IKE/7/DEBUG: parse payloads: payload NONCE
*Jul  4 07:42:04:669 2019 2600 IKE/7/DEBUG: parse payloads: payload ID
*Jul  4 07:42:04:669 2019 2600 IKE/7/DEBUG: parse payloads: payload VENDOR
*Jul  4 07:42:04:670 2019 2600 IKE/7/DEBUG: validate payload SA
*Jul  4 07:42:04:670 2019 2600 IKE/7/DEBUG:   DOI: 1
*Jul  4 07:42:04:670 2019 2600 IKE/7/DEBUG:   unsupported Vendor ID(HEX):
*Jul  4 07:42:04:670 2019 2600 IKE/7/DEBUG: 09002689 dfd6b712 0d000014 afcad713
*Jul  4 07:42:04:670 2019 2600 IKE/7/DEBUG:   receive DPD Protocol Vendor ID
*Jul  4 07:42:04:670 2019 2600 IKE/7/DEBUG:   receive rfc3947 Protocol Vendor ID
*Jul  4 07:42:04:670 2019 2600 IKE/7/DEBUG:   receive draft-ietf-ipsec-nat-t-ike-02 Protocol Vendor ID
*Jul  4 07:42:04:670 2019 2600 IKE/7/DEBUG: P1 responder exchange setup: Connection name is 182.148.30.44,110.191.248.38,500,,0,0,0
*Jul  4 07:42:04:670 2019 2600 IKE/7/DEBUG: P1 exists the same exchange.
*Jul  4 07:42:04:671 2019 2600 IKE/7/DEBUG: exchange chooses role: Local is initiator
*Jul  4 07:42:04:671 2019 2600 IKE/7/DEBUG: P1: local is initiator.
*Jul  4 07:42:05:767 2019 2600 IKE/7/DEBUG: exchange release: freeing exchange 9cf64f0
*Jul  4 07:42:10:820 2019 2600 IKE/7/DEBUG: IKE receive acquire SA request, IKE peer name:vpn-test.
*Jul  4 07:42:10:820 2019 2600 IKE/7/DEBUG: Connection name is 182.148.30.44,182.148.142.9,500,,0,2,1
*Jul  4 07:42:10:821 2019 2600 IKE/7/DEBUG: Check connection: SA for 182.148.30.44,182.148.142.9,500,,0,2,1 missing
*Jul  4 07:42:10:821 2019 2600 IKE/7/DEBUG: exchange lookup :name = 182.148.30.44,182.148.142.9,500,,0,2,1 phase = 2
*Jul  4 07:42:10:821 2019 2600 IKE/7/DEBUG: exchange lookup :name = 182.148.30.44,182.148.142.9,500,,0,0,0 phase = 1
*Jul  4 07:42:10:821 2019 2600 IKE/7/DEBUG: exchange setup(I): 9cf4d90
*Jul  4 07:42:10:822 2019 2600 IKE/7/DEBUG: create udp resource:name = 182.148.30.44,182.148.142.9,500,,0,0,0.
*Jul  4 07:42:10:822 2019 2600 IKE/7/DEBUG: add payload to message: SA
*Jul  4 07:42:10:822 2019 2600 IKE/7/DEBUG:   DOI: 1
*Jul  4 07:42:10:822 2019 2600 IKE/7/DEBUG: add payload to message: PROPOSAL
*Jul  4 07:42:10:823 2019 2600 IKE/7/DEBUG:   NO: 1
*Jul  4 07:42:10:823 2019 2600 IKE/7/DEBUG:   PROTO: ISAKMP
*Jul  4 07:42:10:823 2019 2600 IKE/7/DEBUG:   SPI_SZ: 0
*Jul  4 07:42:10:823 2019 2600 IKE/7/DEBUG:   NTRANSFORMS: 1
*Jul  4 07:42:10:823 2019 2600 IKE/7/DEBUG: add payload to message: TRANSFORM
*Jul  4 07:42:10:823 2019 2600 IKE/7/DEBUG:   NO: 0
*Jul  4 07:42:10:823 2019 2600 IKE/7/DEBUG:   ID: 1
*Jul  4 07:42:10:823 2019 2600 IKE/7/DEBUG:   Transform 0's attributes
*Jul  4 07:42:10:823 2019 2600 IKE/7/DEBUG:   Attribute ENCRYPTION_ALGORITHM : DES_CBC
*Jul  4 07:42:10:824 2019 2600 IKE/7/DEBUG:   Attribute HASH_ALGORITHM : MD5
*Jul  4 07:42:10:824 2019 2600 IKE/7/DEBUG:   Attribute AUTHENTICATION_METHOD : PRE_SHARED
*Jul  4 07:42:10:824 2019 2600 IKE/7/DEBUG:   Attribute GROUP_DESCRIPTION : MODP_1024
*Jul  4 07:42:10:824 2019 2600 IKE/7/DEBUG:   Attribute LIFE_TYPE : SECONDS
*Jul  4 07:42:10:824 2019 2600 IKE/7/DEBUG:   Attribute LIFE_DURATION : 7200
*Jul  4 07:42:10:824 2019 2600 IKE/7/DEBUG: P1 initiator send SA message.
*Jul  4 07:42:10:824 2019 2600 IKE/7/DEBUG: add payload to message: KEY_EXCH
*Jul  4 07:42:10:824 2019 2600 IKE/7/DEBUG:   Group ID: 2
*Jul  4 07:42:10:824 2019 2600 IKE/7/DEBUG: add payload to message: NONCE
*Jul  4 07:42:10:825 2019 2600 IKE/7/DEBUG: add payload to message: VENDOR
*Jul  4 07:42:10:825 2019 2600 IKE/7/DEBUG: add payload to message: ID
*Jul  4 07:42:10:825 2019 2600 IKE/7/DEBUG:   TYPE: 2
*Jul  4 07:42:10:825 2019 2600 IKE/7/DEBUG:   DOI_DATA: 0x000000
*Jul  4 07:42:10:825 2019 2600 IKE/7/DEBUG:   send rfc3947 VID
*Jul  4 07:42:10:825 2019 2600 IKE/7/DEBUG:   send draft-ietf-ipsec-nat-t-ike-06 VID
*Jul  4 07:42:10:826 2019 2600 IKE/7/DEBUG:   send draft-ietf-ipsec-nat-t-ike-03 VID
*Jul  4 07:42:10:826 2019 2600 IKE/7/DEBUG: add payload to message: VENDOR
*Jul  4 07:42:10:826 2019 2600 IKE/7/DEBUG:   send draft-ietf-ipsec-nat-t-ike-02 VID
*Jul  4 07:42:10:826 2019 2600 IKE/7/DEBUG:   send draft-ietf-ipsec-nat-t-ike-01 VID
*Jul  4 07:42:10:826 2019 2600 IKE/7/DEBUG: exchange check: checking for required SA
*Jul  4 07:42:10:826 2019 2600 IKE/7/DEBUG: exchange check: checking for required KEY_EXCH
*Jul  4 07:42:10:826 2019 2600 IKE/7/DEBUG: exchange check: checking for required NONCE
*Jul  4 07:42:10:826 2019 2600 IKE/7/DEBUG: exchange check: checking for required ID
*Jul  4 07:42:10:826 2019 2600 IKE/7/DEBUG: send message:
*Jul  4 07:42:10:827 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x6aaf0fe1d2eb11e0
*Jul  4 07:42:10:827 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:42:10:827 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:42:10:827 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:42:10:827 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:42:10:827 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:42:10:827 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:42:10:827 2019 2600 IKE/7/DEBUG:   LENGTH: 367
*Jul  4 07:42:10:827 2019 2600 IKE/7/DEBUG: exchange state machine(I): finished step 0, advancing...
*Jul  4 07:42:11:870 2019 2600 IKE/7/DEBUG: received message:
*Jul  4 07:42:11:870 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x95209ae0cf420e78
*Jul  4 07:42:11:870 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:42:11:870 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:42:11:871 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:42:11:871 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:42:11:871 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:42:11:871 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:42:11:872 2019 2600 IKE/7/DEBUG:   LENGTH: 376
*Jul  4 07:42:11:872 2019 2600 IKE/7/DEBUG: exchange lookup all list from COOKIE: iCOOKIE 95209ae0cf420e78
*Jul  4 07:42:11:872 2019 2600 IKE/7/DEBUG: parse payloads: payload SA
*Jul  4 07:42:11:872 2019 2600 IKE/7/DEBUG: parse payloads: payload KEY_EXCH
*Jul  4 07:42:11:872 2019 2600 IKE/7/DEBUG: parse payloads: payload NONCE
*Jul  4 07:42:11:873 2019 2600 IKE/7/DEBUG: parse payloads: payload ID
*Jul  4 07:42:11:873 2019 2600 IKE/7/DEBUG: parse payloads: payload VENDOR
*Jul  4 07:42:11:874 2019 2600 IKE/7/DEBUG: parse payloads: payload VENDOR
*Jul  4 07:42:11:874 2019 2600 IKE/7/DEBUG: validate payload SA
*Jul  4 07:42:11:874 2019 2600 IKE/7/DEBUG:   DOI: 1
*Jul  4 07:42:11:874 2019 2600 IKE/7/DEBUG:   unsupported Vendor ID(HEX):
*Jul  4 07:42:11:875 2019 2600 IKE/7/DEBUG: 09002689 dfd6b712 0d000014 afcad713
*Jul  4 07:42:11:875 2019 2600 IKE/7/DEBUG:   receive DPD Protocol Vendor ID
*Jul  4 07:42:11:875 2019 2600 IKE/7/DEBUG:   receive rfc3947 Protocol Vendor ID
*Jul  4 07:42:11:875 2019 2600 IKE/7/DEBUG:   receive draft-ietf-ipsec-nat-t-ike-02 Protocol Vendor ID
*Jul  4 07:42:11:875 2019 2600 IKE/7/DEBUG: P1 responder exchange setup: Connection name is 182.148.30.44,110.191.248.38,500,,0,0,0
*Jul  4 07:42:11:876 2019 2600 IKE/7/DEBUG: P1 exists the same exchange.
*Jul  4 07:42:11:876 2019 2600 IKE/7/DEBUG: exchange chooses role: Local is initiator
*Jul  4 07:42:11:876 2019 2600 IKE/7/DEBUG: P1: local is initiator.
*Jul  4 07:42:24:832 2019 2600 IKE/7/DEBUG: received message:
*Jul  4 07:42:24:833 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x95209ae0cf420e78
*Jul  4 07:42:24:833 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:42:24:833 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:42:24:833 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:42:24:834 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:42:24:834 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:42:24:834 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:42:24:834 2019 2600 IKE/7/DEBUG:   LENGTH: 376
*Jul  4 07:42:24:835 2019 2600 IKE/7/DEBUG: exchange lookup all list from COOKIE: iCOOKIE 95209ae0cf420e78
*Jul  4 07:42:24:835 2019 2600 IKE/7/DEBUG: parse payloads: payload SA
*Jul  4 07:42:24:835 2019 2600 IKE/7/DEBUG: parse payloads: payload KEY_EXCH
*Jul  4 07:42:24:835 2019 2600 IKE/7/DEBUG: parse payloads: payload NONCE
*Jul  4 07:42:24:835 2019 2600 IKE/7/DEBUG: parse payloads: payload ID
*Jul  4 07:42:24:836 2019 2600 IKE/7/DEBUG: parse payloads: payload VENDOR
*Jul  4 07:42:24:836 2019 2600 IKE/7/DEBUG: validate payload SA
*Jul  4 07:42:24:836 2019 2600 IKE/7/DEBUG:   DOI: 1
*Jul  4 07:42:24:836 2019 2600 IKE/7/DEBUG:   unsupported Vendor ID(HEX):
*Jul  4 07:42:24:836 2019 2600 IKE/7/DEBUG: 09002689 dfd6b712 0d000014 afcad713
*Jul  4 07:42:24:836 2019 2600 IKE/7/DEBUG:   receive DPD Protocol Vendor ID
*Jul  4 07:42:24:837 2019 2600 IKE/7/DEBUG:   receive rfc3947 Protocol Vendor ID
*Jul  4 07:42:24:837 2019 2600 IKE/7/DEBUG:   receive draft-ietf-ipsec-nat-t-ike-02 Protocol Vendor ID
*Jul  4 07:42:24:837 2019 2600 IKE/7/DEBUG: P1 responder exchange setup: Connection name is 182.148.30.44,110.191.248.38,500,,0,0,0
*Jul  4 07:42:24:837 2019 2600 IKE/7/DEBUG: P1 exists the same exchange.
*Jul  4 07:42:24:837 2019 2600 IKE/7/DEBUG: exchange chooses role: Local is initiator
*Jul  4 07:42:24:837 2019 2600 IKE/7/DEBUG: P1: local is initiator.
*Jul  4 07:42:24:837 2019 2600 IKE/7/DEBUG: send message:
*Jul  4 07:42:24:837 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x6aaf0fe1d2eb11e0
*Jul  4 07:42:24:837 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:42:24:837 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:42:24:838 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:42:24:838 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:42:24:838 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:42:24:838 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:42:24:838 2019 2600 IKE/7/DEBUG:   LENGTH: 367
*Jul  4 07:42:30:737 2019 2600 IKE/7/DEBUG: exchange release: freeing exchange 9cf5c70
*Jul  4 07:42:40:846 2019 2600 IKE/7/DEBUG: send message:
*Jul  4 07:42:40:846 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x6aaf0fe1d2eb11e0
*Jul  4 07:42:40:846 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:42:40:847 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:42:40:847 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:42:40:847 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:42:40:847 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:42:40:847 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:42:40:848 2019 2600 IKE/7/DEBUG:   LENGTH: 367
*Jul  4 07:42:48:161 2019 2600 IKE/7/DEBUG: received message:
*Jul  4 07:42:48:161 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x95209ae0cf420e78
*Jul  4 07:42:48:161 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:42:48:162 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:42:48:162 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:42:48:162 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:42:48:162 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:42:48:162 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:42:48:163 2019 2600 IKE/7/DEBUG:   LENGTH: 376
*Jul  4 07:42:48:163 2019 2600 IKE/7/DEBUG: exchange lookup all list from COOKIE: iCOOKIE 95209ae0cf420e78
*Jul  4 07:42:48:163 2019 2600 IKE/7/DEBUG: parse payloads: payload SA
*Jul  4 07:42:48:163 2019 2600 IKE/7/DEBUG: parse payloads: payload KEY_EXCH
*Jul  4 07:42:48:164 2019 2600 IKE/7/DEBUG: parse payloads: payload NONCE
*Jul  4 07:42:48:164 2019 2600 IKE/7/DEBUG: parse payloads: payload ID
*Jul  4 07:42:48:164 2019 2600 IKE/7/DEBUG: parse payloads: payload VENDOR
*Jul  4 07:42:48:164 2019 2600 IKE/7/DEBUG: validate payload SA
*Jul  4 07:42:48:165 2019 2600 IKE/7/DEBUG:   DOI: 1
*Jul  4 07:42:48:165 2019 2600 IKE/7/DEBUG:   unsupported Vendor ID(HEX):
*Jul  4 07:42:48:165 2019 2600 IKE/7/DEBUG: 09002689 dfd6b712 0d000014 afcad713
*Jul  4 07:42:48:165 2019 2600 IKE/7/DEBUG:   receive DPD Protocol Vendor ID
*Jul  4 07:42:48:165 2019 2600 IKE/7/DEBUG:   receive rfc3947 Protocol Vendor ID
*Jul  4 07:42:48:165 2019 2600 IKE/7/DEBUG:   receive draft-ietf-ipsec-nat-t-ike-02 Protocol Vendor ID
*Jul  4 07:42:48:165 2019 2600 IKE/7/DEBUG: P1 responder exchange setup: Connection name is 182.148.30.44,110.191.248.38,500,,0,0,0
*Jul  4 07:42:48:165 2019 2600 IKE/7/DEBUG: exchange setup(R): 9cf5a50
*Jul  4 07:42:48:165 2019 2600 IKE/7/DEBUG: parse payloads: payload PROPOSAL
*Jul  4 07:42:48:166 2019 2600 IKE/7/DEBUG: parse payloads: payload TRANSFORM
*Jul  4 07:42:48:166 2019 2600 IKE/7/DEBUG: validate payload PROPOSAL
*Jul  4 07:42:48:166 2019 2600 IKE/7/DEBUG:   NO: 0
*Jul  4 07:42:48:166 2019 2600 IKE/7/DEBUG:   PROTO: ISAKMP
*Jul  4 07:42:48:166 2019 2600 IKE/7/DEBUG:   SPI_SZ: 0
*Jul  4 07:42:48:166 2019 2600 IKE/7/DEBUG:   NTRANSFORMS: 2
*Jul  4 07:42:48:166 2019 2600 IKE/7/DEBUG: validate payload TRANSFORM
*Jul  4 07:42:48:166 2019 2600 IKE/7/DEBUG:   NO: 1
*Jul  4 07:42:48:166 2019 2600 IKE/7/DEBUG:   ID: 1
*Jul  4 07:42:48:167 2019 2600 IKE/7/DEBUG:   Transform 1's attributes
*Jul  4 07:42:48:167 2019 2600 IKE/7/DEBUG:   Attribute ENCRYPTION_ALGORITHM : 3DES_CBC
*Jul  4 07:42:48:167 2019 2600 IKE/7/DEBUG:   Attribute HASH_ALGORITHM : MD5
*Jul  4 07:42:48:167 2019 2600 IKE/7/DEBUG:   Attribute GROUP_DESCRIPTION : MODP_1024
*Jul  4 07:42:48:167 2019 2600 IKE/7/DEBUG:   Attribute AUTHENTICATION_METHOD : PRE_SHARED
*Jul  4 07:42:48:167 2019 2600 IKE/7/DEBUG:   Attribute LIFE_TYPE : SECONDS
*Jul  4 07:42:48:167 2019 2600 IKE/7/DEBUG:   Attribute LIFE_DURATION : 86400
*Jul  4 07:42:48:167 2019 2600 IKE/7/DEBUG: validate payload TRANSFORM
*Jul  4 07:42:48:167 2019 2600 IKE/7/DEBUG:   NO: 2
*Jul  4 07:42:48:167 2019 2600 IKE/7/DEBUG:   ID: 1
*Jul  4 07:42:48:168 2019 2600 IKE/7/DEBUG:   Transform 2's attributes
*Jul  4 07:42:48:168 2019 2600 IKE/7/DEBUG:   Attribute ENCRYPTION_ALGORITHM : AES_CBC
*Jul  4 07:42:48:168 2019 2600 IKE/7/DEBUG:   Attribute KEY_LENGTH : AES_CBC_128
*Jul  4 07:42:48:168 2019 2600 IKE/7/DEBUG:   Attribute HASH_ALGORITHM : SHA
*Jul  4 07:42:48:168 2019 2600 IKE/7/DEBUG:   Attribute GROUP_DESCRIPTION : MODP_2048
*Jul  4 07:42:48:168 2019 2600 IKE/7/DEBUG:   Attribute AUTHENTICATION_METHOD : PRE_SHARED
*Jul  4 07:42:48:168 2019 2600 IKE/7/DEBUG:   Attribute LIFE_TYPE : SECONDS
*Jul  4 07:42:48:168 2019 2600 IKE/7/DEBUG:   Attribute LIFE_DURATION : 86400
*Jul  4 07:42:48:168 2019 2600 IKE/7/DEBUG: validate payload KEY_EXCH
*Jul  4 07:42:48:168 2019 2600 IKE/7/DEBUG: validate payload ID
*Jul  4 07:42:48:169 2019 2600 IKE/7/DEBUG:   TYPE: 1
*Jul  4 07:42:48:169 2019 2600 IKE/7/DEBUG:   DOI_DATA: 0x000000
*Jul  4 07:42:48:169 2019 2600 IKE/7/DEBUG:   id information: type 1 proto 0 port 0
*Jul  4 07:42:48:169 2019 2600 IKE/7/DEBUG:   id information: IPv4 address 192.168.180.102
*Jul  4 07:42:48:169 2019 2600 IKE/7/DEBUG: validate payload NONCE
*Jul  4 07:42:48:169 2019 2600 IKE/7/DEBUG: validate payload VENDOR
*Jul  4 07:42:48:169 2019 2600 IKE/7/DEBUG:   vendor ID seen
*Jul  4 07:42:48:170 2019 2600 IKE/7/DEBUG: validate payload VENDOR
*Jul  4 07:42:48:170 2019 2600 IKE/7/DEBUG:   vendor ID seen
*Jul  4 07:42:48:170 2019 2600 IKE/7/DEBUG: exchange check: checking for required SA
*Jul  4 07:42:48:170 2019 2600 IKE/7/DEBUG: exchange check: checking for required KEY_EXCH
*Jul  4 07:42:48:170 2019 2600 IKE/7/DEBUG: exchange check: checking for required NONCE
*Jul  4 07:42:48:170 2019 2600 IKE/7/DEBUG: exchange check: checking for required ID
*Jul  4 07:42:48:170 2019 2600 IKE/7/DEBUG: negotiate sa: transform 1 proto 1 proposal 0 compatible
*Jul  4 07:42:48:170 2019 2600 IKE/7/DEBUG: negotiate sa: proposal 0 succeeded
*Jul  4 07:42:48:171 2019 2600 IKE/7/DEBUG: Find IKE peer by address.
  IfIndex:0x000b0001.
*Jul  4 07:42:48:171 2019 2600 IKE/7/DEBUG: P1 handle ID: Failed to find ike peer by address.
*Jul  4 07:42:48:171 2019 2600 IKE/7/DEBUG: exchange state machine: Failed to receive message.
*Jul  4 07:42:59:873 2019 2600 IKE/7/DEBUG: send message:
*Jul  4 07:42:59:873 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x6aaf0fe1d2eb11e0
*Jul  4 07:42:59:873 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:42:59:874 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:42:59:874 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:42:59:874 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:42:59:874 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:42:59:874 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:42:59:875 2019 2600 IKE/7/DEBUG:   LENGTH: 367
*Jul  4 07:43:10:781 2019 2600 IKE/7/DEBUG: exchange release: freeing exchange 9cf4d90
*Jul  4 07:43:15:359 2019 2600 IKE/7/DEBUG: IKE receive acquire SA request, IKE peer name:vpn-test.
*Jul  4 07:43:15:359 2019 2600 IKE/7/DEBUG: Connection name is 182.148.30.44,182.148.142.9,500,,0,2,1
*Jul  4 07:43:15:359 2019 2600 IKE/7/DEBUG: Check connection: SA for 182.148.30.44,182.148.142.9,500,,0,2,1 missing
*Jul  4 07:43:15:359 2019 2600 IKE/7/DEBUG: exchange lookup :name = 182.148.30.44,182.148.142.9,500,,0,2,1 phase = 2
*Jul  4 07:43:15:360 2019 2600 IKE/7/DEBUG: exchange lookup :name = 182.148.30.44,182.148.142.9,500,,0,0,0 phase = 1
*Jul  4 07:43:15:360 2019 2600 IKE/7/DEBUG: exchange setup(I): 9d08f10
*Jul  4 07:43:15:360 2019 2600 IKE/7/DEBUG: create udp resource:name = 182.148.30.44,182.148.142.9,500,,0,0,0.
*Jul  4 07:43:15:360 2019 2600 IKE/7/DEBUG: add payload to message: SA
*Jul  4 07:43:15:360 2019 2600 IKE/7/DEBUG:   DOI: 1
*Jul  4 07:43:15:361 2019 2600 IKE/7/DEBUG: add payload to message: PROPOSAL
*Jul  4 07:43:15:361 2019 2600 IKE/7/DEBUG:   NO: 1
*Jul  4 07:43:15:361 2019 2600 IKE/7/DEBUG:   PROTO: ISAKMP
*Jul  4 07:43:15:361 2019 2600 IKE/7/DEBUG:   SPI_SZ: 0
*Jul  4 07:43:15:361 2019 2600 IKE/7/DEBUG:   NTRANSFORMS: 1
*Jul  4 07:43:15:361 2019 2600 IKE/7/DEBUG: add payload to message: TRANSFORM
*Jul  4 07:43:15:362 2019 2600 IKE/7/DEBUG:   NO: 0
*Jul  4 07:43:15:362 2019 2600 IKE/7/DEBUG:   ID: 1
*Jul  4 07:43:15:362 2019 2600 IKE/7/DEBUG:   Transform 0's attributes
*Jul  4 07:43:15:362 2019 2600 IKE/7/DEBUG:   Attribute ENCRYPTION_ALGORITHM : DES_CBC
*Jul  4 07:43:15:362 2019 2600 IKE/7/DEBUG:   Attribute HASH_ALGORITHM : MD5
*Jul  4 07:43:15:362 2019 2600 IKE/7/DEBUG:   Attribute AUTHENTICATION_METHOD : PRE_SHARED
*Jul  4 07:43:15:362 2019 2600 IKE/7/DEBUG:   Attribute GROUP_DESCRIPTION : MODP_1024
*Jul  4 07:43:15:362 2019 2600 IKE/7/DEBUG:   Attribute LIFE_TYPE : SECONDS
*Jul  4 07:43:15:362 2019 2600 IKE/7/DEBUG:   Attribute LIFE_DURATION : 7200
*Jul  4 07:43:15:363 2019 2600 IKE/7/DEBUG: P1 initiator send SA message.
*Jul  4 07:43:15:363 2019 2600 IKE/7/DEBUG: add payload to message: KEY_EXCH
*Jul  4 07:43:15:363 2019 2600 IKE/7/DEBUG:   Group ID: 2
*Jul  4 07:43:15:363 2019 2600 IKE/7/DEBUG: add payload to message: NONCE
*Jul  4 07:43:15:363 2019 2600 IKE/7/DEBUG: add payload to message: VENDOR
*Jul  4 07:43:15:363 2019 2600 IKE/7/DEBUG: add payload to message: ID
*Jul  4 07:43:15:363 2019 2600 IKE/7/DEBUG:   TYPE: 2
*Jul  4 07:43:15:363 2019 2600 IKE/7/DEBUG:   DOI_DATA: 0x000000
*Jul  4 07:43:15:364 2019 2600 IKE/7/DEBUG:   send rfc3947 VID
*Jul  4 07:43:15:364 2019 2600 IKE/7/DEBUG: add payload to message: VENDOR
*Jul  4 07:43:15:364 2019 2600 IKE/7/DEBUG:   send draft-ietf-ipsec-nat-t-ike-06 VID
*Jul  4 07:43:15:364 2019 2600 IKE/7/DEBUG:   send draft-ietf-ipsec-nat-t-ike-03 VID
*Jul  4 07:43:15:364 2019 2600 IKE/7/DEBUG:   send draft-ietf-ipsec-nat-t-ike-02 VID
*Jul  4 07:43:15:364 2019 2600 IKE/7/DEBUG:   send draft-ietf-ipsec-nat-t-ike-01 VID
*Jul  4 07:43:15:364 2019 2600 IKE/7/DEBUG: exchange check: checking for required SA
*Jul  4 07:43:15:365 2019 2600 IKE/7/DEBUG: exchange check: checking for required KEY_EXCH
*Jul  4 07:43:15:365 2019 2600 IKE/7/DEBUG: exchange check: checking for required NONCE
*Jul  4 07:43:15:365 2019 2600 IKE/7/DEBUG: exchange check: checking for required ID
*Jul  4 07:43:15:365 2019 2600 IKE/7/DEBUG: send message:
*Jul  4 07:43:15:365 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x403f11f0660118ad
*Jul  4 07:43:15:365 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:43:15:365 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:43:15:365 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:43:15:365 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:43:15:365 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:43:15:366 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:43:15:366 2019 2600 IKE/7/DEBUG:   LENGTH: 367
*Jul  4 07:43:15:366 2019 2600 IKE/7/DEBUG: exchange state machine(I): finished step 0, advancing...
*Jul  4 07:43:27:368 2019 2600 IKE/7/DEBUG: send message:
*Jul  4 07:43:27:368 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x403f11f0660118ad
*Jul  4 07:43:27:369 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:43:27:369 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:43:27:369 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:43:27:369 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:43:27:370 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:43:27:370 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:43:27:370 2019 2600 IKE/7/DEBUG:   LENGTH: 367
*Jul  4 07:43:30:152 2019 2600 IKE/7/DEBUG: received message:
*Jul  4 07:43:30:152 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x95209ae0cf420e78
*Jul  4 07:43:30:152 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:43:30:153 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:43:30:153 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:43:30:153 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:43:30:153 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:43:30:154 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:43:30:154 2019 2600 IKE/7/DEBUG:   LENGTH: 376
*Jul  4 07:43:30:154 2019 2600 IKE/7/DEBUG: exchange lookup all list from COOKIE: iCOOKIE 95209ae0cf420e78
*Jul  4 07:43:30:154 2019 2600 IKE/7/DEBUG:   found p1 active exchange ...
*Jul  4 07:43:30:154 2019 2600 IKE/7/DEBUG: received message: dropping setup for existing SA
*Jul  4 07:43:42:362 2019 2600 IKE/7/DEBUG: send message:
*Jul  4 07:43:42:362 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x403f11f0660118ad
*Jul  4 07:43:42:362 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:43:42:363 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:43:42:363 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:43:42:363 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:43:42:363 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:43:42:363 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:43:42:364 2019 2600 IKE/7/DEBUG:   LENGTH: 367
*Jul  4 07:43:48:166 2019 2600 IKE/7/DEBUG: exchange release: freeing exchange 9cf5a50
*Jul  4 07:44:02:378 2019 2600 IKE/7/DEBUG: send message:
*Jul  4 07:44:02:378 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x403f11f0660118ad
*Jul  4 07:44:02:378 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:44:02:378 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:44:02:378 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:44:02:379 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:44:02:379 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:44:02:379 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:44:02:379 2019 2600 IKE/7/DEBUG:   LENGTH: 367
*Jul  4 07:44:15:288 2019 2600 IKE/7/DEBUG: exchange release: freeing exchange 9d08f10
*Jul  4 07:44:20:407 2019 2600 IKE/7/DEBUG: IKE receive acquire SA request, IKE peer name:vpn-test.
*Jul  4 07:44:20:407 2019 2600 IKE/7/DEBUG: Connection name is 182.148.30.44,182.148.142.9,500,,0,2,1
*Jul  4 07:44:20:407 2019 2600 IKE/7/DEBUG: Check connection: SA for 182.148.30.44,182.148.142.9,500,,0,2,1 missing
*Jul  4 07:44:20:408 2019 2600 IKE/7/DEBUG: exchange lookup :name = 182.148.30.44,182.148.142.9,500,,0,2,1 phase = 2
*Jul  4 07:44:20:408 2019 2600 IKE/7/DEBUG: exchange lookup :name = 182.148.30.44,182.148.142.9,500,,0,0,0 phase = 1
*Jul  4 07:44:20:408 2019 2600 IKE/7/DEBUG: exchange setup(I): 9dbbc20
*Jul  4 07:44:20:408 2019 2600 IKE/7/DEBUG: create udp resource:name = 182.148.30.44,182.148.142.9,500,,0,0,0.
*Jul  4 07:44:20:409 2019 2600 IKE/7/DEBUG: add payload to message: SA
*Jul  4 07:44:20:409 2019 2600 IKE/7/DEBUG:   DOI: 1
*Jul  4 07:44:20:409 2019 2600 IKE/7/DEBUG: add payload to message: PROPOSAL
*Jul  4 07:44:20:409 2019 2600 IKE/7/DEBUG:   NO: 1
*Jul  4 07:44:20:409 2019 2600 IKE/7/DEBUG:   PROTO: ISAKMP
*Jul  4 07:44:20:410 2019 2600 IKE/7/DEBUG:   SPI_SZ: 0
*Jul  4 07:44:20:410 2019 2600 IKE/7/DEBUG:   NTRANSFORMS: 1
*Jul  4 07:44:20:410 2019 2600 IKE/7/DEBUG: add payload to message: TRANSFORM
*Jul  4 07:44:20:410 2019 2600 IKE/7/DEBUG:   NO: 0
*Jul  4 07:44:20:410 2019 2600 IKE/7/DEBUG:   ID: 1
*Jul  4 07:44:20:410 2019 2600 IKE/7/DEBUG:   Transform 0's attributes
*Jul  4 07:44:20:410 2019 2600 IKE/7/DEBUG:   Attribute ENCRYPTION_ALGORITHM : DES_CBC
*Jul  4 07:44:20:410 2019 2600 IKE/7/DEBUG:   Attribute HASH_ALGORITHM : MD5
*Jul  4 07:44:20:410 2019 2600 IKE/7/DEBUG:   Attribute AUTHENTICATION_METHOD : PRE_SHARED
*Jul  4 07:44:20:410 2019 2600 IKE/7/DEBUG:   Attribute GROUP_DESCRIPTION : MODP_1024
*Jul  4 07:44:20:411 2019 2600 IKE/7/DEBUG:   Attribute LIFE_TYPE : SECONDS
*Jul  4 07:44:20:411 2019 2600 IKE/7/DEBUG:   Attribute LIFE_DURATION : 7200
*Jul  4 07:44:20:411 2019 2600 IKE/7/DEBUG: P1 initiator send SA message.
*Jul  4 07:44:20:411 2019 2600 IKE/7/DEBUG: add payload to message: KEY_EXCH
*Jul  4 07:44:20:411 2019 2600 IKE/7/DEBUG:   Group ID: 2
*Jul  4 07:44:20:411 2019 2600 IKE/7/DEBUG: add payload to message: NONCE
*Jul  4 07:44:20:411 2019 2600 IKE/7/DEBUG: add payload to message: VENDOR
*Jul  4 07:44:20:411 2019 2600 IKE/7/DEBUG: add payload to message: ID
*Jul  4 07:44:20:411 2019 2600 IKE/7/DEBUG:   TYPE: 2
*Jul  4 07:44:20:412 2019 2600 IKE/7/DEBUG:   DOI_DATA: 0x000000
*Jul  4 07:44:20:412 2019 2600 IKE/7/DEBUG: add payload to message: VENDOR
*Jul  4 07:44:20:412 2019 2600 IKE/7/DEBUG:   send rfc3947 VID
*Jul  4 07:44:20:412 2019 2600 IKE/7/DEBUG:   send draft-ietf-ipsec-nat-t-ike-06 VID
*Jul  4 07:44:20:412 2019 2600 IKE/7/DEBUG:   send draft-ietf-ipsec-nat-t-ike-03 VID
*Jul  4 07:44:20:412 2019 2600 IKE/7/DEBUG:   send draft-ietf-ipsec-nat-t-ike-02 VID
*Jul  4 07:44:20:413 2019 2600 IKE/7/DEBUG: add payload to message: VENDOR
*Jul  4 07:44:20:413 2019 2600 IKE/7/DEBUG:   send draft-ietf-ipsec-nat-t-ike-01 VID
*Jul  4 07:44:20:413 2019 2600 IKE/7/DEBUG: exchange check: checking for required SA
*Jul  4 07:44:20:413 2019 2600 IKE/7/DEBUG: exchange check: checking for required KEY_EXCH
*Jul  4 07:44:20:413 2019 2600 IKE/7/DEBUG: exchange check: checking for required NONCE
*Jul  4 07:44:20:413 2019 2600 IKE/7/DEBUG: exchange check: checking for required ID
*Jul  4 07:44:20:413 2019 2600 IKE/7/DEBUG: send message:
*Jul  4 07:44:20:413 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0xb420a01706cb5a5e
*Jul  4 07:44:20:413 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:44:20:413 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:44:20:414 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:44:20:414 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:44:20:414 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:44:20:414 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:44:20:414 2019 2600 IKE/7/DEBUG:   LENGTH: 367
*Jul  4 07:44:20:414 2019 2600 IKE/7/DEBUG: exchange state machine(I): finished step 0, advancing...
*Jul  4 07:44:36:420 2019 2600 IKE/7/DEBUG: send message:
*Jul  4 07:44:36:420 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0xb420a01706cb5a5e
*Jul  4 07:44:36:420 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:44:36:420 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:44:36:421 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:44:36:421 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:44:36:421 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:44:36:421 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:44:36:421 2019 2600 IKE/7/DEBUG:   LENGTH: 367
*Jul  4 07:44:45:738 2019 2600 IKE/7/DEBUG: received message:
*Jul  4 07:44:45:738 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x95209ae0cf420e78
*Jul  4 07:44:45:739 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:44:45:739 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:44:45:739 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:44:45:739 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:44:45:740 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:44:45:740 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:44:45:740 2019 2600 IKE/7/DEBUG:   LENGTH: 376
*Jul  4 07:44:45:740 2019 2600 IKE/7/DEBUG: exchange lookup all list from COOKIE: iCOOKIE 95209ae0cf420e78
*Jul  4 07:44:45:740 2019 2600 IKE/7/DEBUG: parse payloads: payload SA
*Jul  4 07:44:45:741 2019 2600 IKE/7/DEBUG: parse payloads: payload KEY_EXCH
*Jul  4 07:44:45:741 2019 2600 IKE/7/DEBUG: parse payloads: payload NONCE
*Jul  4 07:44:45:741 2019 2600 IKE/7/DEBUG: parse payloads: payload ID
*Jul  4 07:44:45:741 2019 2600 IKE/7/DEBUG: parse payloads: payload VENDOR
*Jul  4 07:44:45:742 2019 2600 IKE/7/DEBUG: parse payloads: payload VENDOR
*Jul  4 07:44:45:742 2019 2600 IKE/7/DEBUG: validate payload SA
*Jul  4 07:44:45:742 2019 2600 IKE/7/DEBUG:   DOI: 1
*Jul  4 07:44:45:743 2019 2600 IKE/7/DEBUG:   unsupported Vendor ID(HEX):
*Jul  4 07:44:45:743 2019 2600 IKE/7/DEBUG: 09002689 dfd6b712 0d000014 afcad713
*Jul  4 07:44:45:743 2019 2600 IKE/7/DEBUG:   receive DPD Protocol Vendor ID
*Jul  4 07:44:45:743 2019 2600 IKE/7/DEBUG:   receive rfc3947 Protocol Vendor ID
*Jul  4 07:44:45:744 2019 2600 IKE/7/DEBUG:   receive draft-ietf-ipsec-nat-t-ike-02 Protocol Vendor ID
*Jul  4 07:44:45:744 2019 2600 IKE/7/DEBUG: P1 responder exchange setup: Connection name is 182.148.30.44,110.191.248.38,500,,0,0,0
*Jul  4 07:44:45:744 2019 2600 IKE/7/DEBUG: exchange setup(R): 8973480
*Jul  4 07:44:45:744 2019 2600 IKE/7/DEBUG: parse payloads: payload PROPOSAL
*Jul  4 07:44:45:745 2019 2600 IKE/7/DEBUG: parse payloads: payload TRANSFORM
*Jul  4 07:44:45:745 2019 2600 IKE/7/DEBUG: validate payload PROPOSAL
*Jul  4 07:44:45:745 2019 2600 IKE/7/DEBUG:   NO: 0
*Jul  4 07:44:45:745 2019 2600 IKE/7/DEBUG:   PROTO: ISAKMP
*Jul  4 07:44:45:746 2019 2600 IKE/7/DEBUG:   SPI_SZ: 0
*Jul  4 07:44:45:746 2019 2600 IKE/7/DEBUG:   NTRANSFORMS: 2
*Jul  4 07:44:45:746 2019 2600 IKE/7/DEBUG: validate payload TRANSFORM
*Jul  4 07:44:45:746 2019 2600 IKE/7/DEBUG:   NO: 1
*Jul  4 07:44:45:747 2019 2600 IKE/7/DEBUG:   ID: 1
*Jul  4 07:44:45:747 2019 2600 IKE/7/DEBUG:   Transform 1's attributes
*Jul  4 07:44:45:747 2019 2600 IKE/7/DEBUG:   Attribute ENCRYPTION_ALGORITHM : 3DES_CBC
*Jul  4 07:44:45:747 2019 2600 IKE/7/DEBUG:   Attribute HASH_ALGORITHM : MD5
*Jul  4 07:44:45:747 2019 2600 IKE/7/DEBUG:   Attribute GROUP_DESCRIPTION : MODP_1024
*Jul  4 07:44:45:748 2019 2600 IKE/7/DEBUG:   Attribute AUTHENTICATION_METHOD : PRE_SHARED
*Jul  4 07:44:45:748 2019 2600 IKE/7/DEBUG:   Attribute LIFE_TYPE : SECONDS
*Jul  4 07:44:45:748 2019 2600 IKE/7/DEBUG:   Attribute LIFE_DURATION : 86400
*Jul  4 07:44:45:748 2019 2600 IKE/7/DEBUG: validate payload TRANSFORM
*Jul  4 07:44:45:749 2019 2600 IKE/7/DEBUG:   NO: 2
*Jul  4 07:44:45:749 2019 2600 IKE/7/DEBUG:   ID: 1
*Jul  4 07:44:45:749 2019 2600 IKE/7/DEBUG:   Transform 2's attributes
*Jul  4 07:44:45:749 2019 2600 IKE/7/DEBUG:   Attribute ENCRYPTION_ALGORITHM : AES_CBC
*Jul  4 07:44:45:749 2019 2600 IKE/7/DEBUG:   Attribute KEY_LENGTH : AES_CBC_128
*Jul  4 07:44:45:750 2019 2600 IKE/7/DEBUG:   Attribute HASH_ALGORITHM : SHA
*Jul  4 07:44:45:750 2019 2600 IKE/7/DEBUG:   Attribute GROUP_DESCRIPTION : MODP_2048
*Jul  4 07:44:45:750 2019 2600 IKE/7/DEBUG:   Attribute AUTHENTICATION_METHOD : PRE_SHARED
*Jul  4 07:44:45:750 2019 2600 IKE/7/DEBUG:   Attribute LIFE_TYPE : SECONDS
*Jul  4 07:44:45:751 2019 2600 IKE/7/DEBUG:   Attribute LIFE_DURATION : 86400
*Jul  4 07:44:45:751 2019 2600 IKE/7/DEBUG: validate payload KEY_EXCH
*Jul  4 07:44:45:751 2019 2600 IKE/7/DEBUG: validate payload ID
*Jul  4 07:44:45:751 2019 2600 IKE/7/DEBUG:   TYPE: 1
*Jul  4 07:44:45:752 2019 2600 IKE/7/DEBUG:   DOI_DATA: 0x000000
*Jul  4 07:44:45:752 2019 2600 IKE/7/DEBUG:   id information: type 1 proto 0 port 0
*Jul  4 07:44:45:752 2019 2600 IKE/7/DEBUG:   id information: IPv4 address 192.168.180.102
*Jul  4 07:44:45:752 2019 2600 IKE/7/DEBUG: validate payload NONCE
*Jul  4 07:44:45:752 2019 2600 IKE/7/DEBUG: validate payload VENDOR
*Jul  4 07:44:45:753 2019 2600 IKE/7/DEBUG:   vendor ID seen
*Jul  4 07:44:45:753 2019 2600 IKE/7/DEBUG: validate payload VENDOR
*Jul  4 07:44:45:754 2019 2600 IKE/7/DEBUG:   vendor ID seen
*Jul  4 07:44:45:754 2019 2600 IKE/7/DEBUG: validate payload VENDOR
*Jul  4 07:44:45:754 2019 2600 IKE/7/DEBUG: exchange check: checking for required SA
*Jul  4 07:44:45:754 2019 2600 IKE/7/DEBUG: exchange check: checking for required KEY_EXCH
*Jul  4 07:44:45:755 2019 2600 IKE/7/DEBUG: exchange check: checking for required NONCE
*Jul  4 07:44:45:755 2019 2600 IKE/7/DEBUG: exchange check: checking for required ID
*Jul  4 07:44:45:755 2019 2600 IKE/7/DEBUG: negotiate sa: transform 1 proto 1 proposal 0 compatible
*Jul  4 07:44:45:755 2019 2600 IKE/7/DEBUG: negotiate sa: proposal 0 succeeded
*Jul  4 07:44:45:756 2019 2600 IKE/7/DEBUG: Find IKE peer by address.
  IfIndex:0x000b0001.
*Jul  4 07:44:45:756 2019 2600 IKE/7/DEBUG: P1 handle ID: Failed to find ike peer by address.
*Jul  4 07:44:45:756 2019 2600 IKE/7/DEBUG: exchange state machine: Failed to receive message.
*Jul  4 07:44:47:439 2019 2600 IKE/7/DEBUG: send message:
*Jul  4 07:44:47:439 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0xb420a01706cb5a5e
*Jul  4 07:44:47:440 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:44:47:440 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:44:47:440 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:44:47:440 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:44:47:441 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:44:47:441 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:44:47:441 2019 2600 IKE/7/DEBUG:   LENGTH: 367
*Jul  4 07:44:49:736 2019 2600 IKE/7/DEBUG: received message:
*Jul  4 07:44:49:736 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x95209ae0cf420e78
*Jul  4 07:44:49:737 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:44:49:737 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:44:49:737 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:44:49:737 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:44:49:737 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:44:49:738 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:44:49:738 2019 2600 IKE/7/DEBUG:   LENGTH: 376
*Jul  4 07:44:49:738 2019 2600 IKE/7/DEBUG: exchange lookup all list from COOKIE: iCOOKIE 95209ae0cf420e78
*Jul  4 07:44:49:738 2019 2600 IKE/7/DEBUG:   found p1 active exchange ...
*Jul  4 07:44:49:739 2019 2600 IKE/7/DEBUG: received message: dropping setup for existing SA
*Jul  4 07:44:56:938 2019 2600 IKE/7/DEBUG: received message:
*Jul  4 07:44:56:939 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x95209ae0cf420e78
*Jul  4 07:44:56:939 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:44:56:939 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:44:56:939 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:44:56:940 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:44:56:940 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:44:56:940 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:44:56:940 2019 2600 IKE/7/DEBUG:   LENGTH: 376
*Jul  4 07:44:56:941 2019 2600 IKE/7/DEBUG: exchange lookup all list from COOKIE: iCOOKIE 95209ae0cf420e78
*Jul  4 07:44:56:941 2019 2600 IKE/7/DEBUG:   found p1 active exchange ...
*Jul  4 07:44:56:941 2019 2600 IKE/7/DEBUG: received message: dropping setup for existing SA
*Jul  4 07:44:59:441 2019 2600 IKE/7/DEBUG: send message:
*Jul  4 07:44:59:441 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0xb420a01706cb5a5e
*Jul  4 07:44:59:441 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:44:59:441 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:44:59:442 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:44:59:442 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:44:59:442 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:44:59:442 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:44:59:443 2019 2600 IKE/7/DEBUG:   LENGTH: 367
*Jul  4 07:45:09:900 2019 2600 IKE/7/DEBUG: received message:
*Jul  4 07:45:09:900 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0x95209ae0cf420e78
*Jul  4 07:45:09:900 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:45:09:900 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:45:09:901 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:45:09:901 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:45:09:901 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:45:09:901 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:45:09:902 2019 2600 IKE/7/DEBUG:   LENGTH: 376
*Jul  4 07:45:09:902 2019 2600 IKE/7/DEBUG: exchange lookup all list from COOKIE: iCOOKIE 95209ae0cf420e78
*Jul  4 07:45:09:902 2019 2600 IKE/7/DEBUG:   found p1 active exchange ...
*Jul  4 07:45:09:902 2019 2600 IKE/7/DEBUG: received message: dropping setup for existing SA
*Jul  4 07:45:14:403 2019 2600 IKE/7/DEBUG: send message:
*Jul  4 07:45:14:404 2019 2600 IKE/7/DEBUG:   ICOOKIE: 0xb420a01706cb5a5e
*Jul  4 07:45:14:404 2019 2600 IKE/7/DEBUG:   RCOOKIE: 0x0000000000000000
*Jul  4 07:45:14:404 2019 2600 IKE/7/DEBUG:   NEXT_PAYLOAD: SA
*Jul  4 07:45:14:404 2019 2600 IKE/7/DEBUG:   VERSION: 16
*Jul  4 07:45:14:405 2019 2600 IKE/7/DEBUG:   EXCH_TYPE: AGGRESSIVE
*Jul  4 07:45:14:405 2019 2600 IKE/7/DEBUG:   FLAGS: [ ]
*Jul  4 07:45:14:405 2019 2600 IKE/7/DEBUG:   MESSAGE_ID: 0x00000000
*Jul  4 07:45:14:405 2019 2600 IKE/7/DEBUG:   LENGTH: 367
目前有很多个ER系列和MSR系列的路由器要与中心站点对过IPSEC进行对接
从这个信息来看,第一阶段的ike都没建立,可能是本端发包了,对端没回包。最好用wireshark抓包看看
我在网上随便下了个wireshark安装好了,接下来要怎么做,我不是专业的。求指导~谢谢MSR下面接的是三层交换机,要不要把电脑直接接到路由器上面去?
zhiliao_40741 发表时间:2019-07-04
要的,电脑要接到路由器上,但这样可能还要做镜像抓包。可以搜一下教程
zhiliao_35742 发表时间:2019-07-04
