H3C S5024PV3-EI
2019-07-10提问
  • 1收藏,987浏览
H3C S5024PV3-EI 三台和核心交换机相连,没有其它配置只配置了端口,可只有一台可以通,请大神指导!
version 7.1.070, Release 6126P13
sysname H3C
telnet server enable
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
irf member 1 priority 1
password-recovery enable
vlan 1
vlan 3
interface NULL0
interface Vlan-interface1 ip address 192.168.0.235 255.255.255.0
# interface GigabitEthernet1/0/1 port access vlan 3 # interface GigabitEthernet1/0/2 port access vlan 3 # interface GigabitEthernet1/0/3 port access vlan 3 # interface GigabitEthernet1/0/4 port access vlan 3 # interface GigabitEthernet1/0/5 port access vlan 3 # interface GigabitEthernet1/0/6 port access vlan 3 # interface GigabitEthernet1/0/7 port access vlan 3 # interface GigabitEthernet1/0/8 port access vlan 3 # interface GigabitEthernet1/0/9 port access vlan 3 # interface GigabitEthernet1/0/10 port access vlan 3 # interface GigabitEthernet1/0/11 port access vlan 3 # interface GigabitEthernet1/0/12 port access vlan 3 # interface GigabitEthernet1/0/13 port access vlan 3 # interface GigabitEthernet1/0/14 port access vlan 3 # interface GigabitEthernet1/0/15 port access vlan 3 # interface GigabitEthernet1/0/16 port access vlan 3 # interface GigabitEthernet1/0/17 port access vlan 3 # interface GigabitEthernet1/0/18 port access vlan 3 # interface GigabitEthernet1/0/19 port access vlan 3 # interface GigabitEthernet1/0/20 port access vlan 3 # interface GigabitEthernet1/0/21 port access vlan 3 # interface GigabitEthernet1/0/22 port access vlan 3 # interface GigabitEthernet1/0/23 port access vlan 3 # interface GigabitEthernet1/0/24 port access vlan 3 # interface GigabitEthernet1/0/25 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/26 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/27 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/28 port link-type trunk port trunk permit vlan all
scheduler logfile size 16 # line class aux authentication-mode scheme user-role network-admin # line class vty authentication-mode scheme user-role network-operator # line aux 0 user-role network-admin # line vty 0 63 user-role network-operator # snmp-agent snmp-agent local-engineid 800063A28090E710A9B40B00000001 snmp-agent community write private snmp-agent community read public snmp-agent sys-info version all # domain system # domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # local-user admin class manage password hash $h$6$vnD/l/x+HUaz4bas$Lw2Yln/T1UF55L3zVEDk+L/ijpxxGD3szOdx4+hfX2jJW2x48aiIImQ8J7GqZok+6d0xXqI/+zYDtrJwlcEK4w== service-type telnet http https terminal authorization-attribute user-role network-admin authorization-attribute user-role network-operator # ip http enable ip https enable
# return
粉丝:10人 关注:1人
你这个配置没啥问题,是不是互连接口没有放通相应vlan,trunk vlan all看一下,然后看下两边是否有ARP表项
走走看看 知了小白
换了光模块和跳线就好了,不知原因
QWE123 三段
粉丝:1人 关注:3人
1、检查VLAN配置
2、检查一下端口配置
3、检查是不是成环路了
