WX3010E 本地802.1X认证不了
  • 1收藏,1381浏览
搭建过基于公司AD域账号的802.1x认证可以正常使用,但是搭建在AC设备本地的802.1x认证不了
SSID配置
interface WLAN-ESS6 port link-type hybrid port hybrid vlan 1 241 untagged port hybrid pvid vlan 241 port-security port-mode userlogin-secure-ext port-security tx-key-type 11key port-security preshared-key pass-phrase cipher $c$3$g7IK64nCaqblhQ2KJfFddNJtLB2dPb4kGqf+vN7AmTo= undo dot1x handshake dot1x mandatory-domain cams undo dot1x multicast-trigger
用户配置
local-user H3C2 password cipher $c$3$bp8fc1BumcOQVEtZbXhUoZlBLZ7liefMlg== group it-test service-type lan-access
用户组配置
user-group it-test authorization-attribute vlan 241
AAA配置
domain cams authentication lan-access local authorization lan-access local accounting lan-access local access-limit disable state active idle-cut disable self-service-url disable
 port-security enable
 dot1x authentication-method eap
# port-security enable # dot1x authentication-method eap
粉丝:148人 关注:3人
SSID下面需要修改吗
zhiliao_OKMhD 发表时间:2019-07-23
修改了 还是不行
