华三HCL模拟器MPLS L3 VPN的时候OSPF和BGP双向重分布的问题
2019-07-24提问
  • 1收藏,1550浏览
用hcl模拟器做MPLS VPN,bgp邻居和mpls ldp邻居建立正常,但是vpn实例的ospf和bgp双向引入的时候无法引入路由,很奇怪,不知道哪里配置错了,请大佬解答一下,同配置下ensp正常。
P路由
[P_R1]dis cu
 version 7.1.075, Alpha 7571
 sysname P_R1
 router id 1.1.1.1
ospf 1
 area 0.0.0.0
 network 1.1.1.1 0.0.0.0
 network 12.12.12.0 0.0.0.3
 network 13.13.13.0 0.0.0.3
 mpls lsr-id 1.1.1.1
mpls ldp
interface LoopBack0
 ip address 1.1.1.1 255.255.255.255
interface GigabitEthernet0/0
 port link-mode route
 combo enable copper
 ip address 12.12.12.1 255.255.255.252
 ospf network-type p2p
 mpls enable
 mpls ldp enable
interface GigabitEthernet0/1
 combo enable copper
 ip address 13.13.13.1 255.255.255.252
 mpls enable
 mpls ldp enable
# return
PE-1路由
[PE_R1]dis cu
 sysname PE_R1
ip vpn-instance 1t2
 route-distinguisher 100:200
 vpn-target 100:200 200:100 import-extcommunity
 vpn-target 200:100 100:200 export-extcommunity
 router id 2.2.2.2
ospf 1
 area 0.0.0.0
 network 2.2.2.2 0.0.0.0
ospf 2
 vpn-instance 1t2
 import-route bgp 333
 vpn-instance-capability simple
 area 0.0.0.0 network 24.24.24.0 0.0.0.3
mpls lsr-id 2.2.2.2
vlan 1
mpls ldp
interface LoopBack0
 ip address 2.2.2.2 255.255.255.255
 combo enable copper
 ip address 12.12.12.2 255.255.255.252
 mpls enable
 mpls ldp enable
 combo enable copper
 interface GigabitEthernet0/1.2
 ip binding vpn-instance 1t2
 ip address 24.24.24.1 255.255.255.252
 vlan-type dot1q vid 2
bgp 333
 peer 3.3.3.3 as-number 333
 peer 3.3.3.3 connect-interface LoopBack0
address-family vpnv4 peer 3.3.3.3 enable
 ip vpn-instance 1t2
 address-family ipv4 unicast
 import-route ospf 2
return
PE-2路由
[PE_R2]dis cu
 sysname PE_R2
ip vpn-instance 2t1
 vpn-target 200:100 100:200 import-extcommunity
 vpn-target 100:200 200:100 export-extcommunity
 router id 3.3.3.3
 # ospf 1
 area 0.0.0.0
 network 3.3.3.3 0.0.0.0
ospf 2 vpn-instance 2t1
 area 0.0.0.0
 network 35.35.35.0 0.0.0.3
 mpls lsr-id 3.3.3.3
vlan 1
mpls ldp
interface LoopBack0
 ip address 3.3.3.3 255.255.255.255
 combo enable copper
 ip address 13.13.13.2 255.255.255.252
 mpls enable
 mpls ldp enable
 combo enable copper
# interface GigabitEthernet0/1.2
 ip binding vpn-instance 2t1
 ip address 35.35.35.1 255.255.255.252
bgp 333
 peer 2.2.2.2 as-number 333
 peer 2.2.2.2 connect-interface LoopBack0
 peer 2.2.2.2 enable
 ip vpn-instance 2t1
 import-route ospf 2
return
CE-1交换
[CE_S1]dis cu
 sysname CE_S1
ip vpn-instance 1t2
 router id 4.4.4.4
ospf 2 vpn-instance 1t2
 network 192.168.1.0 0.0.0.255
vlan 1
vlan 2 to 3
 stp global enable
interface NULL0
interface LoopBack0
 ip address 4.4.4.4 255.255.255.255
interface Vlan-interface2
 ip address 24.24.24.2 255.255.255.252
interface Vlan-interface3
 port link-mode bridge
 port link-type trunk
 port trunk permit vlan all
 combo enable fiber
 port link-mode bridge port
 access vlan 3
 combo enable fiber
return
CE-2交换
 [CE_S2]dis cu
 sysname CE_S2
ip vpn-instance 2t1
 router id 5.5.5.5
 area 0.0.0.0
 network 192.168.2.0 0.0.0.255
 mpls lsr-id 5.5.5.5
 lldp global enable
vlan 1
vlan 2 to 3
 stp global enable
mpls ldp
 interface NULL0
 ip address 35.35.35.2 255.255.255.252
 ip address 192.168.2.1 255.255.255.0
 combo enable fiber
 port access vlan 3
 combo enable fiber
return
粉丝:10人 关注:1人
工程导出来,然后重新提问,把工程作为附件付上来看下
已重新提问
zhiliao_rEKP2 发表时间:2019-07-24
水水 一段
老哥,你也搞调度数据网的?
你从哪看出来的
zhiliao_h5d7gY 发表时间:2024-01-29
