ACG1000-AE防私接功能误报率很高
2019-07-26提问
  • 1收藏,1100浏览
ACG1000-AE防私接,终端数量设置为3,仍然出现误报情况普遍,插U盘都能被识别终端共享
粉丝:28人 关注:2人
如果出现了误识别可以查看终端共享具体被什么机制识别为多终端
# display user-share check-info ip 192.168.1.100
TCP timestamp       count      ctime     uptime   duration
           100       1640    1214654    1215999       1345
wechat long connection                        sendpkts recvpkts    ctime   uptime duration      state     device
192.168.1.100:63496 -> 101.226.211.46:8080          13       18  1214654  1215904     1250  confirmed         pc
debug user-share可以查看共享识别过程
# debug user-share
basic   detail
# display log debug
<2018-09-28 17:02:16> 192.168.1.100 -> 101.226.211.46 ushare: wechat connection TCP 192.168.1.100:63496 -> 101.226.211.46:8080 update
<2018-09-28 17:02:16> 101.226.211.46 -> 192.168.1.100 ushare: wechat connection TCP 101.226.211.46:8080 -> 192.168.8.30:63496 update
<2018-09-28 17:03:39> 101.226.211.46 -> 192.168.1.100 ushare: wechat connection TCP 101.226.211.46:8080 -> 192.168.8.30:63496 update
<2018-09-28 17:07:28> 192.168.1.100 -> 120.52.33.34 ushare: application 360_Security_Centre ignored as audit_contentlen is zero
<2018-09-28 17:07:28> 120.52.33.34 -> 192.168.1.100 ushare: application 360_Security_Centre ignored as audit_contentlen is zero
出现误识别的时候可以查看对应ip地址被哪些机制阻断,阻断的时候看看识别情况
