刷wap712c遇到问题 后续处理
2019-08-03提问
  • 1收藏,1273浏览
BTx 零段
粉丝:0人 关注:3人
刷wap712c遇到问题
原贴 https://zhiliao.h3c.com/questions/dispcont/58820
我整理了下
一、用“console”线接wap712ccon
二、下载一个hyperterminal-v2.7_超级终端关闭“0”配置,接AP
三、下载3CDaemon_TFTP服务上传固件用。WA4300S-CMW520-R1509P01-FAT_WAP712C胖固件(上传时改成WA4300S_fat)
四、配置TFTP
电脑拉网线到AP
 电脑网卡设置为:192.168.0.1/255.255.255.0 ,如下例子打开TFTP服务器,把软件版本WA2600a_fat.bin放到电脑桌面上,TFTP服务器目录指向电脑桌面,然后点击确定。
五、进ap
*                   H3C WAP712C BootWare, Version 7.08                     *
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd.
Compiled Date       : Mar 21 2017
CPU Type            : ATHEROS AR9563
CPU L1 Cache        : 32KB
CPU Clock Speed     : 775MHz
Memory Type         : SDRAM
Memory Size         : 128MB
Memory Speed        : 560MHz
BootWare Size       : 512KB
Flash Size          : 16MB
PCB Version         : Ver.A
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Enter your choice(0-9):
Ctrl+B 进入BootWare
Ctrl+F: Format File System格式化flash,因为bin太大没有空间上传
|<3> Enter Ethernet SubMenu   格式化完成后,点3
==========================<EnterEthernet SubMenu>==========================
|Note:the operating device is flash                                        |
|<1> Download Image Program To SDRAM And Run                               |
|<2> Update Main Image File                                                |
|<3> Update Backup Image File                                              |
|<4> Download Files(*.*)                                                   |
|<5> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
Enter your choice(0-5): 5
==========================<ETHERNET PARAMETER SET>==========================
|Note:       '.' = Clear field.                                            |
|            '-' = Go to previous field.                                   |
|         Ctrl+D = Quit.                                                   |
Protocol (FTP or TFTP) :tftp   回车
Load File Name         :host
                       :wa4300s_fat.bin
Target File Name       :target
                       :wa4300s_fat.bin
Server IP Address      :192.168.1.1 192.168.0.1
Local IP Address       :192.168.1.253 192.168.0.50
Subnet Mask            :0.0.0.0回车
Gateway IP Address     :0.0.0.0
先设置好上下传的IP
Enter your choice(0-5): 1
上传到<1> Download Image Program To SDRAM And Run
上传后重起
出来H3C WAP712C BootWare, Version 1.06    说明已从v7 降到v5
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<8> Clear Super Password                                                  |
|<0> Reboot        |
Ctrl+Y: Change AP Mode
再格式下ctrl+F
Warning:All files on flash will be lost! Are you sure to format? [Y/N]Y.....
Format success.
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 3 进入网线更新模式
==========================<Enter Ethernet SubMenu>==========================
|<1> Download Application Program To SDRAM And Run                         |
|<2> Update Main Application File                                          |
|<3> Modify Ethernet Parameter                                             |
Enter your choice(0-3): 3 配置tFtp IP
|          Ctrl+D = Quit.                                                  |
Load File Name         :host 回车
                       :wa4300s_fat.bin
                       :wa4300s_fat.bin
Gateway IP Address     :0.0.0.0 回车
Enter your choice(0-3): 0 回到主菜单
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 0 重起
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing.............................Done!
*                   H3C WAP712C BootWare, Version 1.06                     *
Compiled Date       : Mar 27 2017
CPU L1 Cache        : 32KB
Memory Type         : SDRAM
Memory Size         : 128MB
Flash Size          : 16MB
PCB Version         : Ver.A
Press Ctrl+B to enter extended boot menu...
Starting to get the main application file--flash:/wa4300s_fat.bin!..........
The App file is self-decompressing..........................................
...........................................................Done!
System application is starting...
Startup configuration file does not exist.
User interface con0 is available.
Press ENTER to get started.
说明已更新成功,
AP默认 IP 0.50   可以开始进web页配置
完  2019.8.3
感谢贴子里帮过我的人,感谢广东的熊哥。
有不懂的人可以联系我272797539@qq.com
大屿 八段
粉丝:25人 关注:3人
优秀~
谢谢 众人拾柴火焰高
BTx 发表时间:2019-08-03
