双光纤同时接入使用,应该如何设置,非负载设置
2019-08-12提问
  • 1收藏,2006浏览
吴聃 零段
防火墙型号是SecPath F100-C-G,原来是1条光纤,后因业务发展又接入了1条光纤,原来的光纤绑定服务器及部分办公室使用,接入新光纤后,在公司外面访问服务器网站的时候发现经常掉线或无法访问的情况,请问是哪里没有设置的问题吗?
下附端口配置信息
10.10.10.1为固网IP
20.20.20.2是新接入的固网IP
192.168.4.200为内部服务器IP地址
 version 5.20, Release 5142P02
 sysname FW
 undo voice vlan mac-address 00e0-bb00-0000
 interzone policy default by-priority
 domain default enable system
 ip host oa 192.168.4.200
 telnet server enable
 qos carl 1 source-ip-address range 192.168.1.100 to 192.168.1.199 per-address shared-bandwidth
 qos carl 2 source-ip-address range 192.168.2.1 to 192.168.2.200 per-address shared-bandwidth
 qos carl 3 source-ip-address range 192.168.3.1 to 192.168.3.200 per-address shared-bandwidth
 qos carl 4 source-ip-address range 192.168.4.1 to 192.168.4.200 per-address shared-bandwidth
 port-security enable
 undo alg dns
 undo alg rtsp
 undo alg h323
 undo alg sip
 undo alg sqlnet
 undo alg pptp
 undo alg ils
 undo alg nbt
 undo alg msn
 undo alg qq
 undo alg tftp
 undo alg sccp
 undo alg gtp
session synchronization enable
 password-recovery enable
acl number 3000
 rule 2 permit ip source 192.168.4.0 0.0.0.255
 rule 3 permit ip source 192.168.3.0 0.0.0.255
 rule 4 permit ip source 192.168.1.0 0.0.0.255
 rule 5 permit ip source 192.168.2.0 0.0.0.255
 rule 20 permit ip
acl number 3001
 rule 0 permit ip source 192.168.1.0 0.0.0.255 destination 192.168.4.200 0
 rule 5 permit ip source 1.1.1.0 0.0.0.255 destination 192.168.2.253 0
acl number 3002
 rule 0 permit ip source 192.168.3.0 0.0.0.255 destination 192.168.4.200 0
acl number 3003
 rule 0 permit ip source 192.168.4.0 0.0.0.255 destination 192.168.4.200 0
 rule 1 deny ip
acl number 3004
 rule 0 permit ip source 1.1.1.0 0.0.0.255 destination 192.168.4.200 0
acl number 3100
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
pki domain default
  crl check disable
dhcp server ip-pool 1
 network 192.168.1.0 mask 255.255.255.0
 gateway-list 192.168.1.254
 dns-list 202.97.224.68 202.97.224.69 219.159.32.132 8.8.8.8
dhcp server ip-pool 2
 network 192.168.2.0 mask 255.255.255.0
 gateway-list 192.168.2.254
dhcp server ip-pool 3
 network 192.168.3.0 mask 255.255.255.0
 gateway-list 192.168.3.254
dhcp server ip-pool 4
 network 192.168.4.0 mask 255.255.255.0
 gateway-list 192.168.4.254
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$xgzsM4PK8fIViKHvxhtovT8kv9SIw5evIe8w
 authorization-attribute level 3
 service-type telnet
 service-type web
cwmp
 undo cwmp enable
interface NULL0
interface Vlan-interface1
interface GigabitEthernet0/0
 port link-mode route
 nat outbound 3003
 nat server protocol tcp global 10.10.10.1 www inside 192.168.4.200 www
 nat server protocol tcp global 10.10.10.1 8099 inside 192.168.4.200 8099
 ip address 192.168.10.254 255.255.255.0
interface GigabitEthernet0/1
 description 外网接口
 nat outbound static
 nat outbound 3100
 nat outbound 3000
 nat server protocol tcp global 10.10.10.1 7788 inside 192.168.4.200 7788
 nat server protocol tcp global 10.10.10.1 1089 inside 192.168.4.5 1089
 nat server protocol tcp global 10.10.10.1 9999 inside 192.168.4.200 9999
 nat server protocol udp global 10.10.10.1 1089 inside 192.168.4.5 1089
 nat server protocol tcp global 10.10.10.1 12315 inside 192.168.4.200 12315
 nat server protocol tcp global 10.10.10.1 5222 inside 192.168.4.200 5222
 nat server protocol tcp global 10.10.10.1 5280 inside 192.168.4.200 5280
 nat server protocol tcp global 10.10.10.1 7777 inside 192.168.4.200 7777
 nat server protocol tcp global 10.10.10.1 12314 inside 192.168.4.200 12314
 nat server protocol tcp global 10.10.10.1 12345 inside 192.168.4.200 12345
 nat server protocol tcp global 10.10.10.1 1433 inside 192.168.4.200 1433
 nat server protocol tcp global 10.10.10.1 800 inside 192.168.4.200 800
 nat server protocol tcp global 10.10.10.1 3389 inside 192.168.4.200 3389
 nat server protocol tcp global 10.10.10.1 8888 inside 192.168.2.251 8888
 nat server protocol tcp global 10.10.10.1 8843 inside 192.168.2.251 8843
 nat server protocol tcp global 10.10.10.1 12300 inside 192.168.3.200 12300
 nat server protocol tcp global 10.10.10.1 6802 inside 192.168.3.200 6802
 ip address 10.10.10.1 255.255.255.248
interface GigabitEthernet0/2
 ip address 192.168.11.254 255.255.255.0
interface GigabitEthernet0/3
 nat outbound 3004
 ip address 1.1.1.1 255.255.255.0
interface GigabitEthernet0/4
 nat outbound 3000
 nat server protocol tcp global 20.20.20.2 7788 inside 192.168.4.200 7788
 nat server protocol tcp global 20.20.20.2 1089 inside 192.168.4.5 1089
 nat server protocol udp global 20.20.20.2 1089 inside 192.168.4.5 1089
 nat server protocol tcp global 20.20.20.2 8099 inside 192.168.4.200 8099
 nat server protocol tcp global 20.20.20.2 9999 inside 192.168.4.200 9999
 nat server protocol tcp global 20.20.20.2 12315 inside 192.168.4.200 12315
 nat server protocol tcp global 20.20.20.2 5222 inside 192.168.4.200 5222
 nat server protocol tcp global 20.20.20.2 5280 inside 192.168.4.200 5280
 nat server protocol tcp global 20.20.20.2 7777 inside 192.168.4.200 7777
 nat server protocol tcp global 20.20.20.2 12314 inside 192.168.4.200 12314
 nat server protocol tcp global 20.20.20.2 12345 inside 192.168.4.200 12345
 nat server protocol tcp global 20.20.20.2 1433 inside 192.168.4.200 1433
 nat server protocol tcp global 20.20.20.2 800 inside 192.168.4.200 800
 nat server protocol tcp global 20.20.20.2 3389 inside 192.168.4.200 3389
 nat server protocol tcp global 20.20.20.2 8888 inside 192.168.4.251 8888
 nat server protocol tcp global 20.20.20.2 8843 inside 192.168.4.251 8843
 nat server protocol tcp global 20.20.20.2 12300 inside 192.168.3.200 12300
 nat server protocol tcp global 20.20.20.2 6802 inside 192.168.3.200 6802
 ip address 20.20.20.2 255.255.255.0
vd Root id 1
zone name Management id 0
 priority 100
zone name Local id 1
 priority 100
zone name Trust id 2
 priority 85
 import interface GigabitEthernet0/0
 import interface GigabitEthernet0/3
zone name DMZ id 3
 priority 50
zone name Untrust id 4
 priority 5
 import interface GigabitEthernet0/1
 import interface GigabitEthernet0/2
 import interface GigabitEthernet0/4
switchto vd Root
 ip virtual-reassembly
 zone name DMZ id 3
 interzone source Local destination Trust
  rule 0 permit
   source-ip any_address
   destination-ip any_address
   service any_service
   rule enable
 interzone source Local destination Untrust
  rule 0 permit
   service any_service
   rule enable
 interzone source Trust destination Untrust
  rule 0 permit logging
   service any_service
   rule enable
 interzone source Untrust destination Trust
   service any_service
   rule enable
 interzone source Any destination Trust
  rule 0 permit
   service any_service
   rule enable
 ip route-static 0.0.0.0 0.0.0.0 10.10.10.2
 ip route-static 0.0.0.0 0.0.0.0 GigabitEthernet0/4 20.20.20.1
 ip route-static 192.168.1.0 255.255.255.0 1.1.1.2
 ip route-static 192.168.2.0 255.255.255.0 1.1.1.2
 ip route-static 192.168.3.0 255.255.255.0 1.1.1.2
 ip route-static 192.168.4.0 255.255.255.0 1.1.1.2
 dhcp server forbidden-ip 192.168.1.1 192.168.1.99
 dhcp server forbidden-ip 192.168.1.200 192.168.1.254
 dhcp server forbidden-ip 192.168.2.254
 dhcp server forbidden-ip 192.168.3.254
 dhcp server forbidden-ip 192.168.4.254
 dhcp server forbidden-ip 192.168.4.1 192.168.4.10
 dhcp enable
 load xml-configuration
 load tr069-configuration
user-interface con 0
user-interface vty 0 4
 authentication-mode scheme
粉丝:95人 关注:1人
做一下策略路由试试看
基于报文源地址的转发策略路由配置举例
通过策略路由控制从Router A的以太网接口GigabitEthernet2/0/1接收的报文:
·     源地址为192.168.10.2的报文以4.1.1.2/24作为下一跳IP地址;
·     其它源地址的报文以5.1.1.2/24作为下一跳IP地址。
图1-4 基于报文源地址的转发策略路由的配置举例组网图
(1)     配置Router A
配置接口GigabitEthernet2/0/2和GigabitEthernet2/0/3的IP地址。
[RouterA] interface gigabitethernet 2/0/2
[RouterA-GigabitEthernet2/0/2] ip address 4.1.1.1 24
[RouterA-GigabitEthernet2/0/2] quit
[RouterA] interface gigabitethernet 2/0/3
[RouterA-GigabitEthernet2/0/3] ip address 5.1.1.1 24
[RouterA-GigabitEthernet2/0/3] quit
定义访问控制列表ACL 2000,用来匹配源地址为192.168.10.2的报文。
[RouterA] acl basic 2000
[RouterA-acl-ipv4-basic-2000] rule 10 permit source 192.168.10.2 0
[RouterA-acl-ipv4-basic-2000] quit
定义0号节点,指定所有源地址为192.168.10.2的报文的下一跳为4.1.1.2。
[RouterA] policy-based-route aaa permit node 0
[RouterA-pbr-aaa-0] if-match acl 2000
[RouterA-pbr-aaa-0] apply next-hop 4.1.1.2
[RouterA-pbr-aaa-0] quit
[RouterA] policy-based-route aaa permit node 1
[RouterA-pbr-aaa-1] apply next-hop 5.1.1.2
[RouterA-pbr-aaa-1] quit
在以太网接口GigabitEthernet2/0/1上应用转发策略路由,处理此接口接收的报文。
[RouterA] interface gigabitethernet 2/0/1
[RouterA-GigabitEthernet2/0/1] ip address 192.168.10.1 24
[RouterA-GigabitEthernet2/0/1] ip policy-based-route aaa
[RouterA-GigabitEthernet2/0/1] quit
(2)     配置Router B
配置GigabitEthernet接口的IP地址。
<RouterB> system-view
[RouterB] interface gigabitethernet 2/0/2
[RouterB-GigabitEthernet2/0/2] ip address 4.1.1.2 24
[RouterB-GigabitEthernet2/0/2] quit
配置到网段192.168.10.0/24的静态路由。
[RouterB] ip route-static 192.168.10.0 24 4.1.1.1
(3)     配置Router C
<RouterC> system-view
[RouterC] interface gigabitethernet 2/0/3
[RouterC-GigabitEthernet2/0/3] ip address 5.1.1.2 24
[RouterC-GigabitEthernet2/0/3] quit
[RouterC] ip route-static 192.168.10.0 24 5.1.1.1
